Old 12th May 2009, 16:36   #46
karankapoor's Avatar
where in India or abroad ?
edit: 2 subs will sound better compared to 1 sub
karankapoor is offline   Reply With Quote
Old 12th May 2009, 16:56   #47
Invinsible's Avatar
Thanked: 60 Times
here in india. As well as have the option of getting it from abroad.
Invinsible is offline   Reply With Quote
Old 12th May 2009, 17:43   #48
frankmehta's Avatar
Thanked: 2,229 Times
abhishek, the idq is much more musical than the id, but the price difference is quite a bit.
these graphs dont reveal much. and let the stats business be. in reality, what sounds better is what you will want.
you might like the cheaper id better than the idq, who knows?
why not compare the 2 by listening to them? and then take the call.
(this means, ID users in Mumbai must PM abhishek and allow him to audition their subwoofers. Please)
Old 12th May 2009, 22:59   #49
Invinsible's Avatar
Thanked: 60 Times
Had emailed Eric Stevens of Image Dynamics, USA regarding the dual ID8 / IDQ10V2 / IDQ10V3. Here's what he has to say in context to clean, deep low, tight bass. Very interesting and makes me lean more towards the dual ID8.
"The ID8 will play low and you would think it was an 10 or 12" actually. I do recommend a little larger enclosure though for best performance in the 20 to 40 range. I recommend .35 cuft per subwoofer with polyfil. In .25 each they will have decent low bass but be a little dry.
The IDq10 V2 would be in its optimum enclosure with .55 and the V3 would need to be very well stuffed with polyfill and would be on the small side of volume. The id10 v3 would be probably your best choice at this volume of our current subwoofers, it is actually quite like the IDQ and better than the V.2 in most ways.
You will get good results no matter which way you decide. I would steer you towards the 8" if you can increase the volume or if not towards the IDQ10 or ID10V3"
Old 12th May 2009, 23:07   #50
this is the best answer one can get and that to from the owner for the company, now i think you got your answer, decided or still have some question in mind. its now on your part to decide which way to go.
Old 12th May 2009, 23:41   #51
Invinsible's Avatar
Thanked: 60 Times
You bet, now all I have to figure out is how to get the two 8's in an enclosure. Whether together or two separate enclosure or go for 2 fiber glass enclosure on the sides of the boot.
And if I find the enclosure too big will go in for IDQ10V3
Old 12th May 2009, 23:49   #52
Thanked: 294 Times
Go for a 10 inch driver you will not regret it.
Old 28th May 2009, 13:22   #53
Invinsible's Avatar
Thanked: 60 Times
After a long wait and reading various threads and forums and various discussions have finally decided to go for a Single 12" Sub.
Now it's not an ID Sub. Something that I came across all thanks to the our very own FrankMehta. Thanks buddy.
I know all this while I was keen on getting a dual 8" setup. Would have definitely gone for it until I came across with this unique 12" sub. Dual 8" is always gonna be something I would go for some day in my other car. But as for now settled for 12" complete SQ sub.
It's something very different than anyother sub, unique in it's own way. Considered to be cut above the ID subs too. I should be getting it within couple of weeks.
Old 28th May 2009, 13:33   #54
jaibir's Avatar
Thanked: 48 Times
Invinsible, which sub is this? I am looking for an SQ sub for my Swift and been exploring the different options available.
jaibir is offline   Reply With Quote
ANHC- Another New Honda City! One" H" to Another "H" mkh Test-Drives & Initial Ownership Reports 246 22nd December 2010 17:12
DUAL SUB SETUP, any suggestions? GT500 In-Car Entertainment 6 8th November 2010 13:43
suggestions to connect a dual coil sub makanaka In-Car Entertainment 12 14th August 2008 16:30
2 Subs - Dual Mono or Stereo - "Kb ka dB" kb100 In-Car Entertainment 847 1st October 2007 07:52
