Old 4th May 2009, 02:07   #16
Invinsible's Avatar
Thanked: 60 Times
Originally Posted by karankapoor View Post
is this comes as sheet like mdf and what about the price can you share it.
6 years back I had bought the plexiglass for Rs.250 per sq.ft or a ft. (don't remember exactly) for a 15mm size. that time had got the complete parcel tray done up for a palio out of it so that it's ICE gear could be seen under neat it wear neon's hiding.
They are expensive but they also carry a lot of resonance in it if not build properly. Also, get one air tight would be a difficult job. But, there some who use in the box for a view of the magnet. It does look cool. But, still MDF are the best way to go, sound wise. I use to get my boxes build in High density fiber-particle board years back. They are stronger than MDF but are not easily available and was twice the cost of MDF. The advantage was it was stronger than MDF and one can go .50" of it against the .75" MDF. Building a box is an art, better you build better the results.
Invinsible is offline   Reply With Quote
Old 4th May 2009, 10:39   #17
Thanked: 294 Times
Originally Posted by sudev View Post
A bit OT but...
LBM as a manufacturer of MDF I have interacted with lot of people here and abroad and essential concclusion is MDF also has much better acoustic charactertics. I am sure about Aluminum though.
Can you opine?
By a sub enclosure there is no need for acoustic properties which comes in the picture it is the stiffness and ability not to flex which is important and no air leak if it is a sealed one and if it is a ported one proper air channel is needed for the air to pass so that it does not add to distortion.
The Aluminum is stiffer and does not flex like MDF that is the reason I choose it. MDF is the best and cheapest alternative for a enclosure material. Even I use it and I am satisfied with it.
Old 4th May 2009, 11:18   #18
navin's Avatar
Thanked: 4,286 Times
mdf boards are compressed particle board
Originally Posted by frankmehta View Post
so basically chiragh needs to go for one inch think mdf board.
Originally Posted by chiragh_bir View Post
what will go wrong with particle board?
particle boards are not meant for sub enclosure, it is not as strong as mdf
Originally Posted by abhibh View Post
Why not to use particle board:
- it will flex too much specially with the sub you are using
- it can contract and expand due to weather changes
- its is not as strong as MDF.
Originally Posted by low_bass_makker View Post
I would go for Alternate material like....Aluminum.
guys what you say on Plexiglas
my dad is into plexiglass, and he says the acoustic properties of plexi are brilliant.
1. MDF is not stronger than Plywood. Void free (Marine grade) ply wood is technically stronger. MDF is better damped due to the resin used to bond the "fibers" together.
2. MDF is not compressed ply wood. Ply wood is compressed "plys" of wood sheet bonded together with some phenolic compound such as "Urea Melamine Formaldehyde". UMF is made using Benzene and Polyproplene which is then decomposed in a controlled manner (using Hydrogen rich acids). A by prodct of UMF is Acetone - the kind your wife/GF uses to remover her nail polish.
3. thickness for thickness ply can bend more than MDF but if both are prestressed ply can infct withstand greater bending moments than MDF and is hence able to made much stiffer (if prestressed).
4. As far as alternate materials are concerned there are some I have tried.
a. Aluminum - resonant. you can damp Aluminum using rubber compunds which is what JBL did for it Pro III (now called the Control 1)
b. Stainless Steel - resonant but not as bad as AL. However SS is 3 times as dense as AL and hence the whole structure can become very heavy. Weight is not good (unless it's presennse can be justified by the material's ablity to be damped or stiff) as it stores more energy which is relased later
c. Fiberlgass - diffcult to work with. Needs some special tools to make it thick enough and not de-laminate under long term use.
d. Carbon fibre - expensive. Not WAF friendly in looks. This might be the best material for car subwoofers though.
e. Glass and Ceramics - stiff but resonant. Must be used along with a second non resonant material
f. Plexiglass - too much flex but can be used in small panels (20cm-30cm square) for looks.
g. Bitumen (tar) - used primarily as a damping compund for ceramic tiles but horribly messey to work with in liquid form. You can get Bitumen sheet (or bitumen soaked sheets) and many roofing companies use the same (in corrugated form).
Guys this might look authoritative but it is not. I am willing to stand corrected but what I have stated above is only from my personal experinces.
My choice of materials today is a laminate of MDF-FRP-MDF-FRP-Ply. MDF layers are 4mm, FRP 3mm, Ply 6mm. This gives me a total thickness of 20mm. This gives me a limited degree of mess, easy to DIY (no special tools required), and adequate stiffness, damping and weight. I am sure that using more modern techniques and materials can lead to better results.
navin is offline   (1) Thanks Reply With Quote
Spider Diesel Tuning Box VS. Pete's Tuning Box - Spider Box feedback on pg 2 Endeavour333 Modifications & Accessories 130 11th September 2017 01:24
Fiberglass Vs Mdf Enclosure DjNik In-Car Entertainment 13 29th April 2011 18:16
Custom Sub Box - Your Views Please vigsom In-Car Entertainment 11 6th February 2009 17:42
Custom MDF enclosures : Install / Cost info needed (pics enclosed) s0uljah In-Car Entertainment 74 13th February 2008 02:44
For sale: MDF Subwoofer Enclosure nitrous Shifting gears 4 11th September 2007 13:05
