Old 9th May 2009, 13:13   #46
karankapoor's Avatar
what is size (dimension) of the current sub enclosure. width,height,depth.
karankapoor is offline   Reply With Quote
Old 9th May 2009, 13:49   #47
Flying Bong's Avatar
Originally Posted by Gill View Post
Any inputs on new enclosure design?Min volume req is 1.3cuft,currently I am using 1.4 cu feet.
what if you kept the same enclosure dimensions but mounted the sub on the sloping face of the box?
Flying Bong is offline   Reply With Quote
Old 9th May 2009, 14:04   #48
@bong amazing idea there, will fit then i think.
Old 9th May 2009, 15:04   #49
Gill's Avatar
Thanked: 12 Times
Nice Idea, What if I just place the enclosure with sub facing towards the rear seat(Normally it's towards the boot lid) or I can place like Anup has,facing the roof).This way height problem can be worked out(I think)
Edit:-Just checked the other placement options,it doesn't work.Partial floor is the way to go u think!
Following are the dimension of the enclosure:-
Last edited by Gill : 9th May 2009 at 15:23. Reason: Checked the other placement options!
Gill is offline   Reply With Quote
Old 9th May 2009, 16:07   #50
hydrashok's Avatar
Taking FB's suggestion a bit further, if you design a new box (if you plan to make a new box) like the one shown below, the hatch-door might close, even if the floor is raised.
Here, you will have to increase the depth of the base a bit, and reduce the depth of the top a bit. The "face" of the box (where the driver is mounted) will slope backwards a bit. That should give enough clearance. I'm sure the area in front of the sub-box is not being used now, and there must be at least 2 inches clearance that can be used.
EDIT: To illustrate the concept a little better:
The angle of the slant (of the face of the box) can be chosen based on the requirement for space (and of course, enclosure volume requirement). In case a the box volume cannot be adjusted without changing any other dimension, I'm sure making the box 1/4 inch wider or 1/4 in taller (if possible) will do the trick.
EDIT again: Aaarrrrrgh! The words in the bottom of the pic should read "Blue = Old Box; Black = New Box"
Old 9th May 2009, 16:35   #51
abhibh's Avatar
Thanked: 34 Times
OT but damn that sub looks sexy!
Old 9th May 2009, 22:36   #52
nice work there hydra, or you can make a new enclosure and use it the way hydra has it in his car, what is the mounting depth of your sub ?
Old 10th May 2009, 14:12   #53
Gill's Avatar
Thanked: 12 Times
Thanks for inputs!I would be going for partial false floor!Will keep the thread updated about the progress!
Old 1st February 2010, 21:38   #54
Gill's Avatar
Thanked: 12 Times
Default Amp Install!
I am about to install the Audio equipment in the car.I tried few places to mount the amplifier.
First pic is of Amp under the rear seat.
+ total stealth, easier wire routing, no intrusion in already small boot space.
-Air cooling, have to cut some part of foam under the rear seat.
Second, is on the boot floor.In this case, I have to Build a False floor.
+Total stealth, Wire routing.
-Might have to compromise on boot floor height.
Third, On the side wall with fiberglass or wooden base.
+Cooling, won't intrude much into boot area.
-Wire routing the difference between the amp terminal and boot floor is quite minimal (Power wire and ground wire connection to amp would be quite hard as the wire is not enough flexible and would have to look out for a way to route them to the respective terminal in the amp.
Inputs plz..
Old 1st February 2010, 21:50   #55
abhibh's Avatar
Thanked: 34 Times
Check this http://www.team-bhp.com/forum/1211480-post225.html
OT again damn that iDQ looks sexy!
Old 2nd February 2010, 11:14   #56
Gill's Avatar
Thanked: 12 Times
I will install the amp in that area location only, can't go for full false floor.Just looking for idea's, that can make the location out of three options or install better.
Old 2nd February 2010, 11:45   #57
DerAlte's Avatar
Thanked: 2,879 Times
Vertically on the side of the boot, longitudinally oriented (front to back). Similar to the orientation in Pic 2 above, but not on the boot floor. Will be out of harms way, and there will be no problem of air circulation.
Modern SUVs : Spare wheel placement & interior / mechanical packaging smartcat Technical Stuff 22 16th August 2013 09:11
The Frankenbike Build: My Honda CBR 600 F3 Build-Off ap10046 Superbikes & Imports 16 16th July 2013 14:26
Intercooler placement question tsk1979 Technical Stuff 52 19th October 2008 22:53
2004 Zen: Rear speaker placement sansjunk In-Car Entertainment 4 8th March 2006 17:38
