Old 30th May 2008, 13:51   #1
greenhorn's Avatar
Thanked: 1,518 Times
Default Stock Locations for mounting Speakers in Different Cars
Hi, Was thinking about making a thread to know about the stock as well as other possible install locations in indian cars. Since there is no comprehensive source of info for this.
My contribution
Indica
4" in dash
5.25" (6.5" with spacer possible) in front door
Rear parcel shelf
Indigo CS
4" in dash
5.25" in rear shelf, 6x9's can be installed after cutting.
I'd appreciate if someone posts the stock locations for the Chevy Spark
EDIT: never mind. Found that Spark has only 4" dash locations + rear parcel tray :(
Old 30th May 2008, 14:40   #2
praveen_v's Avatar
Thanked: 120 Times
Here goes
Fiesta:
stock locations
5x7 at the front doors
tweeters in(side) the ORVM adjustment pods
5x7 at the rear tray
praveen_v is offline   Reply With Quote
Old 30th May 2008, 14:56   #3
redfire's Avatar
Swift:
6.5" at front doors
6.5" at rear doors
Tweeters should be mounted at A pillar or dash or doors (no provision with grilled cavity. you need to screw/stick mount them)
Parcel tray is only for higher model (ZXi). So for other models need to buy parcel tray if planning to mount on them.
Sub can be inside boot.
redfire is offline   Reply With Quote
Old 30th May 2008, 15:06   #4
Technocrat's Avatar
Thanked: 2,589 Times
Good thread, will be very helpful.
Alto\Wagon R\ Spark
4 inch speaker on Dashboard facing upwards.
In Alto there are only two mount points diagonally, so the other two brackets are either folded or need to be cut to accommodate the speaker
Santro
4 inch speaker on dashboard facing the occupants i.e. at the end of dashboard at either ends
p.s. Please read the thread before posting to avoid duplication
Old 30th May 2008, 15:09   #5
greenhorn's Avatar
@ redfire - i saw some kind of vent like arrangement above the AC vent in the swift dash. What's that for ?
Old 30th May 2008, 15:30   #6
Mr. boombastic's Avatar
Hyundai Accent
6.5" Front
Hyundai Verna
6.5" Front
6X9" Rear Parcel Shelf
Hyundai i10
6.5" Front and back doors with spacers
Skoda Octavia
6.5" Front doors with provisions for tweeters on the door
5.5" on the sides of the parcel tray
Honda Civic/ Accord (Old Now)
6.5" front with provisions for tweeters at the front of the dash
6X9" rears
Mr. boombastic is offline   Reply With Quote
Old 30th May 2008, 17:47   #7
hemanthisgreat's Avatar
Hyundai getz 6.5" in both front and rear doors.
no stock provisions for tweeters. can be mounted on the doors itself by making holes.
hemanthisgreat is offline   Reply With Quote
Old 31st May 2008, 08:51   #8
Default Maruti 800
Hello guys,
Can you please let me know as to what size of speakers can mounted in the stock locations in Maruti 800. I want to replace my old Sony speakers. Thanks in advance.
maktags is offline   Reply With Quote
Old 1st June 2008, 22:37   #9
agspins's Avatar
Thanked: 311 Times
Hyundai Accent Viva
5" front
5" rear
agspins is offline   Reply With Quote
Old 3rd June 2008, 11:42   #10
mav2000's Avatar
Thanked: 123 Times
Cedia
6.5" front
6.5" rear
mav2000 is offline   Reply With Quote
Old 3rd June 2008, 12:21   #11
redfire's Avatar
Hey Green, it is a scoop type vent which is tapered to inner and going deep inside in a curvy fashion. Not just a grill with space inside meant for tweeters. Don't know how to put it better, but hope you understood .
Old 3rd June 2008, 12:37   #12
praveen_v's Avatar
Thanked: 120 Times
I think it's a Vent which will blow air onto the front windows to prevent fogging.
Old 3rd June 2008, 15:16   #13
leadf00t's Avatar
Thanked: 12 Times
Originally Posted by maktags View Post
Hello guys,
the newer maruti 800 dash ,post 2001 , supports a 4" speaker. the left speaker is located between the left front door and glovebox. the right speaker is located just below the steering column.
4" fronts in-dash
6"x9" in the sidepanels above the wheel well of the boot.
don't know what size can fit in the doorpads though.
leadf00t is offline   Reply With Quote
Old 3rd June 2008, 16:16   #14
manikjeet's Avatar
Thanked: 110 Times
4" fronts in-dash
Even the older type had it
and the boot can take a 6x9 with spacer rings
manikjeet is offline   Reply With Quote
Old 3rd June 2008, 18:02   #15
ragzv's Avatar
Swift Dzire:
6.5" front door (with spacer rings)
5.25" rear parcel shelf
Unlike the rear door of the smaller Swift the Dzire does not have provision to fit speakers on the rear door.
ragzv is offline   Reply With Quote
Maruti to set up 'Brand Centers' at upmarket locations across India mints21 The Indian Car Scene 22 13th March 2014 19:26
Custom rear speaker installation Lancer LE sreejeshmp In-Car Entertainment 9 28th December 2009 14:20
Need help upgrading stock speakers vvvinod In-Car Entertainment 1 24th October 2009 21:19
Sony CDX-GT460US for WagonR - Advise on price / speakers / installation peppyabhi In-Car Entertainment 6 30th July 2007 10:38
