Old 16th May 2009, 19:15   #31
rohan_fonseca's Avatar
Great DIY Shreyas. Just a Q though. Don't you feel that the pods will foul with the legs once fitted?
rohan_fonseca is offline   Reply With Quote
Old 16th May 2009, 20:39   #32
DerAlte's Avatar
Thanked: 2,879 Times
Originally Posted by shreyasma View Post
... This is the first layer of body filler. Looks pathetic to me
I have applied the second layer and let it to dry completely. The project resumes in the morning with more sanding, painting fitting. ...
Looking good already.
The body filler was too thick already when you applied it. As the name says, it should 'fill' all the surface unevenness. If you use very small quantities every time you pick up filler with the scraper, the scraper will ride on the high points of the surface and press the filler in the gap. If you pick too much, you will apply dollops and create more sanding work for yourself. Don't apply too much pressure on the scraper while applying the filler.
Use a wooden block to support the emery paper - it will cut better and get you a uniform surface. For the crevices, use a thin round stick to back the paper.
Scrape away more filler near the edges. Filler is brittle - thick bits near edges tend to chip off over time.
2 layers on the obverse side of the door pad should be enough to create the stiffness you need. No point in adding weight. See if you can manage some thin polyester rods or alu T or U profiles. If you stick them with super-glue before putting on FG, you will get better dimensional stability and stiffness. Put the FG over the stiffener to form a ridge.
Old 16th May 2009, 23:38   #33
akbaree's Avatar
Thanked: 50 Times
This is some great DIY stuff. Eagerly hooked to this thread now.
I am very much in hurry to finish the project as I am hating to drive with out the front stage.
Anyone wants to help??
Help? As in taking pictures? I can surely do that if you stay somewhere near BSK or Jayanagar.
Made the crossover housing in cardboard. I didnt want wood . Notice the gap at the base. We will not have a sealed enclosure if I dont fibreglass. I am looking at little perfection and quality in sound.
I too have Polk Momo components for my front stage (the 6.5" ones). As far as I understand they are designed for a door install (and not a small sealed enclosure). I will surely like to audition this setup if you allow me.
akbaree is offline   Reply With Quote
Old 17th May 2009, 16:40   #34
shreyasma's Avatar
Completed the pod as planned. Sorry folks, couldtnt update the thread yesterday as I headed directly to a party.
Well, I finished sanding by afternoon and started to get the pods painted.
On the way, a new idea struck me and I went to the upholstery guy instead of the painter. Selected some white art leather to match the body colour of the car. He he wrapped the pod in it for me. Price: Rs 200 for both pods)
My White Horse - Project BLING! BLING! BLING! - DIY ICE for Zen-p160509_17.3302.jpg
Came back home and stuck some rubber mat on the back of the pod to give some cusion. This also helps in eliminating any vibration of the pods when fitted.
My White Horse - Project BLING! BLING! BLING! - DIY ICE for Zen-p160509_17.34.jpg
Made holes on the doorpads using the template I had created earlier (Not able to fing the pic i took). Mounted the pod. Notice how the screws come out from the holes. Used a washer and nut to tighten it in place.
My White Horse - Project BLING! BLING! BLING! - DIY ICE for Zen-p160509_18.27.jpg
Finally, This is how it looks
My White Horse - Project BLING! BLING! BLING! - DIY ICE for Zen-p160509_20.0801.jpg
My White Horse - Project BLING! BLING! BLING! - DIY ICE for Zen-p160509_20.08.jpg
This is how it looks in the car. Will post some better quality day pics soon.
My White Horse - Project BLING! BLING! BLING! - DIY ICE for Zen-p160509_20.41.jpg
My White Horse - Project BLING! BLING! BLING! - DIY ICE for Zen-p160509_20.4101.jpg
There is absolutely no vibration in the door pads anymore. Its just crystal clear music.
This means no FG damping for the doors and this means still have all materials left over.
Hence, the project is not yet over.......
shreyasma is offline   Reply With Quote
Old 17th May 2009, 16:46   #35
chiragh_bir's Avatar
Thanked: 70 Times
looks good shreyas !!
now damp the boot with left over material
chiragh_bir is offline   Reply With Quote
Old 17th May 2009, 16:56   #36
shreyasma's Avatar
Thanks for the offer.
The comps is the doors were louder. But in the pod, it sounds more clear and tight. You can audition my setup any time you feel like.
It all depends on the seat adjustment. One of my friends (6.2 feet tall) drove the car yesterday without problems. Before deciding the place for the pod, I had taken measurements to make sure everything is alright.
Old 17th May 2009, 17:45   #37
karankapoor's Avatar
great finally your work is finished it looks like, how will you cover it with paint or some cloth, is it the pic that making it look like that the edges are not perfectly round, but the over all work is fantastic.
karankapoor is offline   Reply With Quote
Old 17th May 2009, 22:27   #38
Thanked: 53 Times
Nice work shreya, are going to cover the mount? looks good. Now I am temped to try my hands at doing FG stuff for my car.
dinar is offline   Reply With Quote
Old 17th May 2009, 22:35   #39
abhayshanu's Avatar
Thanked: 168 Times
Wow, this really awesome, congratulations, was just waiting for it to get over, so that i could congrate you.
abhayshanu is offline   Reply With Quote
Old 17th May 2009, 22:45   #40
shreyasma's Avatar
yes the edges are not perfectly round because the cavity in the door pad isn't. I made the pod exactly to sit in the cavity of the door pad.
The pods are already covered with art leather. So..the pods part of the project is marked 'Completed'. I am thinking of more to be done. Will disclose when I finalize.
Old 18th May 2009, 10:09   #41
hydrashok's Avatar
Great work, Shreyas! The final product looks great!
Good call on the art. leather covering. Painting the pods would have been pretty much a lot of additional work, with all the extra sanding and additional filler work.
I'd personally have preferred to use art. leather of a colour more in sync. with the colour of the door-pads (so the irregularities of the edges get masked). But do post pics of the car showing the seats also. Maybe white does looks better when we see the entire interior of the car. And lots of luck keeping them clean
Old 18th May 2009, 10:41   #42
DerAlte's Avatar
Shabash, Shreyas, looks fantastic.
... The comps is the doors were louder. But in the pod, it sounds more clear and tight. ...
It would. Since the air volume behind the driver is reduced now in your 'sealed' box, much of the low end of the mid-bass would be suppressed. If ever you want the bass back, cut a hole in the back of the pod as well as in the doorpad.
Old 18th May 2009, 11:06   #43
shreyasma's Avatar
I will post pics in sometime.
I really dont need too much bass as the sub takes care of it. I have actually got the exact effect I wanted. And today, the normal 2 hours of commuting to office was a pleasure than pain.
Man! your signature has motivated me more. Now something at the back of my mind saying the rear fills also need the FG treatment
Old 18th May 2009, 12:29   #44
shreyasma's Avatar
Here are some good quality pics.
My White Horse - Project BLING! BLING! BLING! - DIY ICE for Zen-dsc03653.jpg
My White Horse - Project BLING! BLING! BLING! - DIY ICE for Zen-dsc03654.jpg
My White Horse - Project BLING! BLING! BLING! - DIY ICE for Zen-dsc03655.jpg
My White Horse - Project BLING! BLING! BLING! - DIY ICE for Zen-dsc03658.jpg
My White Horse - Project BLING! BLING! BLING! - DIY ICE for Zen-dsc03657.jpg
Old 18th May 2009, 18:20   #45
akbaree's Avatar
Thanked: 50 Times
It has turned out really well. Congratulations !!!
I will call you some day and drop by.
FINALLY GOLD NANO ! on its way to India ! BLING BLING gautamkhadse The Indian Car Scene 42 26th September 2011 00:50
Vento -- My Horse of Battle, Horse of Ballet! msprabhakar Test-Drives & Initial Ownership Reports 10 6th December 2010 09:06
Project : Making of a BLING BLING Santro - Suggestions required !! kpzen Modifications & Accessories 88 15th April 2010 15:28
Bling-bling! Sunday Photo Shoot!!! danlalan Shifting gears 39 23rd September 2008 10:40
Bling Bling!! Now Exhaust Tip Spinners. SPEED_DEMON82 Modifications & Accessories 11 16th October 2005 04:15
