Old 18th March 2009, 15:26   #16
chiragh_bir's Avatar
Thanked: 70 Times
i got mine for unbelievable price
chiragh_bir is offline   Reply With Quote
Old 18th March 2009, 15:30   #17
tsk1979's Avatar
Thanked: 16,421 Times
Note from mod: Please post in existing thread
Old 4th May 2009, 13:20   #18
Thanked: 70 Times
Default Kenwood 8103D Amp
Guys i need a monoblock & 2channel amp.
Am selling off my JBL 1004 cause am adding a monoblock + 2 channel
For monoblock i can pay upto 10 grands in grey
2 channel can pay upto 4-5 grands in grey
For 2 channel i have my eyes on Blaupunkt GTA 280 , is this a good amp?
Monoblock not able to find any good amp around 500w-600w rms 2 ohm stable !!
What will be the major difference on woofer if played with 2 channel amp or monoblock
Old 4th May 2009, 13:42   #19
abhibh's Avatar
Thanked: 34 Times
for 4-5K you can get 4 channel Blau Amp. I think MKII retails for 5-5.5K with Bill now days.
Why 2 ohm stable MONO ? Changing sub ?
Old 4th May 2009, 15:37   #20
karankapoor's Avatar
as abhibh said for 4 channel go with the blau mkII retail for 5k with b&w, and for mono i doubt you can find one (good one) at 10k ask frank recently he has done some good searching for a mono and decided to go with genesis maybe he can tell you.
the 2 amp that he shorlisted were jbl 7001 and kenwood 9104.
karankapoor is offline   Reply With Quote
Old 5th May 2009, 14:28   #21
Thanked: 70 Times
as usual again found a amp from Blaupunkt Stable
VPA 1500 Pro Monoblock which produce
1100w RMS @ 4 ohms
1900w @ 2 ohms
should this amp be considered?
Price am still finding out but it looks it will suit my pocket !!
Old 5th May 2009, 14:40   #22
Thanked: 294 Times
1100w RMS @ 4 ohms
1900w @ 2 ohms
Do not go for this amp. It has a bad repo in the market. A shop in Chandigarh has two of this amps which were blow in few mins of running.
Old 5th May 2009, 14:43   #23
abhibh's Avatar
Thanked: 34 Times
1100w RMS @ 4 ohms
1900w @ 2 ohms
The power rating you have posted are MAX power ratings.
550W RMS @ 4 OHM
950W RMS @ 2 OHM
1500W RMS @ 1 OHM
Old 5th May 2009, 14:51   #24
this doesn't means if chirag buy this his will also go kaput.
and could be possible the installer did something wrong
Old 5th May 2009, 16:22   #25
Thanked: 70 Times
i think my 1004 doesn't want to leave me
Old 5th May 2009, 17:14   #26
Thanked: 294 Times
No offense but this MISTRI is in the market since a long time.
Old 12th May 2009, 12:33   #27
Thanked: 70 Times
Hey Guys
I just picked kenwood 8103 D Mono amp for trying it in my car which produce roughly 500w RMS at 2 OHMS.
This amp will be used to Power my Blaupunkt V SPL 15 inch Sub that is 600w RMS 4/4 OHMS.
How good is this amp?
Am little confused about wiring which will go from amp to sub.
There ae 2 points like 2 channel amp ( from where out put of speakers goes out ) but all diagrams on net shows only 1 point diagram .
Can anyone explain correct wiring procedure
Thanx
Old 12th May 2009, 12:40   #28
Sam Kapasi's Avatar
Thanked: 1,473 Times
Don't be confused
Your subwoofer is a dual 4 ohm sub. You will have 2 pairs of wires coming from the sub. Red/black coil 1, and red/black coil 2.
Now your amplifier is monoblock, but has 2 sets of speaker outputs in parallel. Most installers call this Pyarelal.
Take one coil and connect it with the right polarity to one + and -
Take the second coil connection and conect it to the other + and -.
This should give your amplifier the effective load of 2 ohms, which the manual says should be OK.
Now take an RCA cable and connect it to the subwoofer Pre-out of your head unit. Adjust the gain to your taste. The low pass filter should be anywhere between 80 to 120 Hz as an approximation. - this is neither hard nor fast.
Keep yourself clean by washing your entire body regularly, paying extra attention to your underarms and crotch area and you should have some good hygienic bass in your car.
Cheers,
Sam
Old 12th May 2009, 12:54   #29
Thanked: 70 Times
is it that simple?
but it also has 2 RCA points !!
Old 12th May 2009, 12:58   #30
Sam Kapasi's Avatar
Yes. All audio is that simple. We purposely confuse laymen for monetary and personal satisfaction.
And 2 sets of RCA posts are also in pyarelal. So that you may connect another monoblock if need be. You just use a 2 RCA cable and connect it to where it says "input"
Cheapest good SQ Sub with Kenwood 8401 amp vebmetal In-Car Entertainment 119 5th December 2008 12:21
Kenwood KAC-9104D amp vs Pioneer PRS-D2100T amp nura In-Car Entertainment 7 19th August 2008 17:11
Wanted: New or Used Kenwood 8401 Amp MillionSwords Shifting gears 0 31st January 2008 17:24
Kenwood AMP/ICE advice plz plz cuteavaya In-Car Entertainment 9 10th January 2007 11:52
Kenwood 10 CD Changer and 800watt amp for sale (Pune) shrivz Shifting gears 5 9th May 2006 12:46
