Old 14th May 2009, 15:32   #1
Ajaybiz's Avatar
Thanked: 141 Times
Default Combination of 4 ohms and 2 ohms speakers.
Guru's is it ok to install Combination of 4 ohms and 2 ohms spekers connected to one 4 channel amp?
I have JBL components at front and JBL 3 ways at rear, now planning to put Illusions which are 4 ohms in front doors and JBL components at rear doors and removing JBL 3ways, all 4 spekers are driven by GTO 75.4 amp.
Woofer is going to be driven by GTO 301.1 so no issue in that department.
Thanks.
Ajaybiz is offline   Reply With Quote
Old 14th May 2009, 15:38   #2
karankapoor's Avatar
where are the 2 ohms speaker ? or you are trying to say that the jbl compo you have are 2 ohms one
karankapoor is offline   Reply With Quote
Old 14th May 2009, 16:06   #3
Ajaybiz's Avatar
Thanked: 141 Times
Yes the JBL's are 2ohms.
Old 14th May 2009, 16:11   #4
Sam Kapasi's Avatar
Thanked: 1,473 Times
No absolutely no issues. You will have independent channels driving each set of speakers and each channel is steady at 2 ohms.
You may find that the volume level may differ so adjust according to taste.
Old 15th May 2009, 09:32   #5
Ajaybiz's Avatar
Thanked: 141 Times
Yep sounds like i can control the sound level by gain and fader, thanks all.
Old 15th May 2009, 12:54   #6
esteem_lover's Avatar
Thanked: 451 Times
But won't this negate the advantage of the 2 ohms speakers ?
Which model are these 2 Ohms JBLs & how much did you pay for them ?
Old 15th May 2009, 13:02   #7
Sam Kapasi's Avatar
IMHO, Other than an increased sensitivity, increased current load (only advantageous in case of a small head unit amplifier or a low power amplifier) there are no real advantages to a 2 ohm speaker.
In any case that 2 ohms hype is just a marketing thing. Speaker impedances keep changing depending on the frequency of the sound being amplified through them.
The speaker average a little over 3 ohms, which a little lower than most speakers.
He probably has the GTO series.
Old 18th May 2009, 10:48   #8
Ajaybiz's Avatar
Thanked: 141 Times
Yes GTO 607 components and 936 or 937 forgot the model 3 ways both 2 ohms. Got them for very cheap dont remember the exact price, its almost 1.5 years back dont know the present prices and whether these models are available or not.
Old 18th May 2009, 11:14   #9
navin's Avatar
Thanked: 4,282 Times
Inside Joke (guys please dont PM me about this) but just for Sam. "Sam, I told you so! see your email 4/15/2006"
8 Ohms Amp 1420 In-Car Entertainment 16 7th December 2011 17:13
Maruti 800 Combination Switch and wiper washing Jehan-Sam Technical Stuff 0 20th February 2009 12:13
whether stable at 2ohms or 8 ohms? makanaka In-Car Entertainment 7 19th September 2008 18:37
Running 2.65 Ohms speaker impedence to 4 Ohms Amplifier kiran1103 In-Car Entertainment 13 2nd April 2008 11:30
Another Sub and amp combination , wiring doubt ? 929RON In-Car Entertainment 31 3rd November 2006 06:52
