Old 31st May 2009, 10:16   #16
DerAlte's Avatar
Thanked: 2,880 Times
Originally Posted by abhijitaparadh View Post
... Sorry if I hurt someone, but I am just trying to gain some knowledge about car PC.
You are being overly rational, and not using much EQ. If 'reason' and 'logic' were to be the basis of all decisions, no one would have bought an iPhone but bought a Nokia 1100 instead.
CarPC is used by a driver, not passengers, and not in the same paradigm as using a conventional PC even if the hardware and much of the software is the same. The main uses are:
* Complete personal media library on one device
* Navigation system on the same device
* Engine diagnostic / monitoring system also on the same device
Old 31st May 2009, 23:07   #17
ghpk's Avatar
Thanked: 193 Times
Originally Posted by nisarg86 View Post
@ ghpk. you are on right track buddy. Like you signature. Lots of ppl use same siggy on mp3car.
Thanks Buddy, With you experts onboard, Iam sure to be in right track
Old 1st June 2009, 10:31   #18
chiragh_bir's Avatar
Thanked: 70 Times
shreyas now as zen.. so please update !!
chiragh_bir is offline   Reply With Quote
Old 12th June 2009, 22:16   #19
ST7677's Avatar
Thanked: 45 Times
st7677 - Research, planning & Procurement stage
ST7677 is offline   Reply With Quote
Old 13th June 2009, 22:35   #20
Thanked: 41 Times
hey nice to see more bhpians in carpc setup. all the best for your setup
Last edited by DerAlte : 13th June 2009 at 23:24. Reason: Please use Classifieds to sell, not threads
monty9991 is offline   Reply With Quote
Old 14th June 2009, 10:27   #21
shreyasma's Avatar
My name can be excluded as I no longer have a carputer.
Successfully blew the PSU. Thinking of rebuilding it soon.
shreyasma is offline   Reply With Quote
Old 15th June 2009, 00:36   #22
ghpk's Avatar
Thanked: 193 Times
Can you be more specific, what did you do, to BLOW it.
Old 15th June 2009, 15:18   #23
Thanked: 41 Times
not to worry about the excluding your name from the list. let it be there.
and yes please be more spceific about the blown PSU.lol
Old 15th June 2009, 15:44   #24
shreyasma's Avatar
Was fiddling around and didnt notice a piece of metal wire had fallen on the PSU circuit.
I turned on and Boom! Some smoke and it was dead. Never tried to get it repaired.
But want to rebuild the PC soon. Saving for it.
Old 16th June 2009, 11:24   #25
arpandiv's Avatar
Thanked: 27 Times
So i was wondering if i can build an el cheapo DIY carPc.
My requirements : Must have touchscreen interface.
Rest is all flexible, if it plays the same audio quality as a pio HU i would be satisfied.
Any pointers?
arpandiv is offline   Reply With Quote
Old 16th June 2009, 14:21   #26
ghpk's Avatar
Thanked: 193 Times
Any pointers?
I don't think it would be a "el cheapo" as power supply and LCD itself is expensive,
so sound better you would need a good soundcard and at least a
2 channel amplifier to drive the speakers.
Old 16th June 2009, 14:49   #27
shreyasma's Avatar
Even building a basic carpc gets set back when you have a budget.
as ghpk mentioned, the PSU and the display itself will cost 16-18k approx
You can try with the car inverter and a normal VGA display without touch screen.
But it will not give the ease of use the PSU and touchscreen provides
Old 16th June 2009, 15:31   #28
nisarg86's Avatar
Thanked: 12 Times
@Arpan. Create a new thread. pour in you requirements. You will get your all answers.
btw. you can not set budgate in carpc. .
nisarg86 is offline   Reply With Quote
Old 16th June 2009, 15:34   #29
Thanked: 41 Times
if you want your setup to be cheaper then buy off the lilliput EBY-701 and PSU from ebay. that will be cheaper but may be difficlut to replace the fualty parts(international postage).
you can save about Rs.2-4k
Old 16th June 2009, 15:38   #30
esteem_lover's Avatar
Thanked: 451 Times
Any pointers?
The touchscreen alone will set you back by 12k.
Only your PSU is to be replaced, right ?
Happy Fiftieth Birthday : Many Many Happy Returns Jaguar 'E' Type issigonis Beyond Borders 7 8th March 2011 13:52
ANHC and DIY CarPC monty9991 In-Car Entertainment 54 26th March 2010 20:36
My Baleno (I)ride - CarPC / Carputer install spadival In-Car Entertainment 40 21st March 2009 03:04
Many Many Happy returns Of the DAY SRK!! SohailPistawala Shifting gears 4 31st March 2008 18:17
