Old 27th May 2009, 10:32   #1
Abhiranjan's Avatar
Default Problem with Pioneer Head Unit
Hi !
I have PIONEER DEH-6050UB in my car. Recently I had parked my car for a week and also had removed the head-unit panel (detachable).
I got it installed a year back ... from grey market
I didnt have any problems until now .. After I took out the car from garage, only the head unit is getting powered on but not the panel. This i know because when i key-off the car, the panel slides out automatically.
So no ICE !
What should i do now ?
Thanks,
Abhi
Last edited by Jaggu : 27th May 2009 at 11:47. Reason: Smilie usage is limited to 2 per thread. Thanks
Abhiranjan is offline   Reply With Quote
Old 27th May 2009, 11:51   #2
Jaggu's Avatar
Thanked: 8,685 Times
There is a connector in the face plate, and socket with tiny pins on the HU. Check if the contact is proper. Adjusting this contacts is tricky and delicate job, best handled by an expert, or ill advice extreme caution if you are doing a DIY.
Use head cleaning fluid/alcohol and ear buds to gently wipe them clean, if its dirty. If they are bent, then you will need hell lot of patience and tweezers and stuff to bring them back to shape.
Old 28th May 2009, 13:15   #3
mithun's Avatar
Thanked: 58 Times
Also read the manual on how to properly fit the faceplate. Sometimes it's really a headache to properly fit the plate.
Old 29th May 2009, 16:05   #4
Abhiranjan's Avatar
Smile thanks !
thanx for the suggestion Jaggu ! Cleaning the face plate worked !
There was no dirt though ...
Old 18th April 2010, 22:40   #5
Thanked: 36 Times
Guys!
I have this weird problem as of today.
I recently converted a lot of my songs (FLAC and all) to WMA 440kbps 48000Hz sampling rate. Now, when I tried to play this CD for auditioning this CD on some PIONEER head units at a store, all I could hear was very feable, botched up sound, all muddled up, nothing much audible, very low in volume. I tried this in a Sony Head Unit and it worked perfectly fine. I tried playing it in my own PIONEER head unit but again the same problem. What could be the problem?
Best regards
Abhinav Sharma
abhipuru16 is offline   Reply With Quote
Old 26th April 2010, 05:37   #6
mithun's Avatar
Thanked: 58 Times
Originally Posted by abhipuru16 View Post
Guys!
Best regards
Abhinav Sharma
Which converter did you use ?
From my experience, some software converters are having the history of converting files from one format to other with errors !
Pioneer Head Unit Errors. Error 11 and error 17 in pioneer MP3 rajivanoj In-Car Entertainment 33 8th March 2018 12:58
Need help in installing the Pioneer head unit(5950) in the dashboard(ac contols) Pras_gethigh In-Car Entertainment 3 27th February 2009 00:38
Front detachable face plate of Pioneer head unit stolen bkm In-Car Entertainment 4 1st December 2008 21:02
Pioneer 5750 Head Unit neverclever In-Car Entertainment 4 14th June 2005 07:09
