Old 2nd June 2009, 12:57   #16
DerAlte's Avatar
Thanked: 2,879 Times
Originally Posted by jobinjv View Post
So, under seat is out and side wall is in. Now I think i will have to take up the project my self. In which case how should the sub be pointing, towards front, back or straight. I would seriously like it straight.
Attaboy! You have crossed the first hurdle already. Can't really figure out what you meant by straight, but here is a pictorial based on your first pic.
Name:  Stock 1 modif.jpg
Found a pic on the net for what you should expect:
... Don't I have to mold the complete ABS on the right, think it is a single unit and the keep the legs and rings on that and then complete the FG. ...
What legs & rings? You will only need, apart from the FG materials, a square sheet of MDF large enough to mount the sub. This sheet will get incorporated in the box you will build.
... how much space should be there from the base of the sub to the side wall.
Better to get the sub first to know the mounting depth. Based on that you can decide how much the front mounting plate should bulge out.
... Any other suggestions. Any in JBL or Hertz. Are Hertz subs expensive?
Hertz subs are comparatively expensive and more difficult to find. JBL and other brands have 10" subs but availability you have to check.
... What prices are these being sold ? If you where to choose any one, money over performance, which would it be and which would it be if it where to be performance over money ?
I would choose the Blaupunkt GT4 Spl Mk2, JBL A604 and Kenwood 8404 in that order in either of your use cases, but that is me. Prices vary - should be around 6K with b&w.
... Oh and would I need to do damping.
If you manage to make the box yourself, damping will be a breeze. Yes you will need damping, first and foremost behind that grey FRP side claddings of the boot (there are many cables etc. which start rattling) and the hatch.
... Any idea yet ?
Found the thread - here.
Old 7th July 2009, 14:30   #17
UniqueMods's Avatar
Thanked: 50 Times
Sorry to bump this thread,
I would like to install my sub - jbl gt5 s12 in a similar way in my santro.
where can i get this done in Mumbai? fiber glass specialist ?
also will a 12" woofer fit above the wheel well ?
UM
UniqueMods is offline   Reply With Quote
Old 7th July 2009, 14:45   #18
Invinsible's Avatar
Thanked: 60 Times
UM
You can contact Zohir of Boom at Bandra.
Invinsible is offline   Reply With Quote
Which one: Dual 8" sub V/s Single 10" sub? Invinsible In-Car Entertainment 53 28th May 2009 13:33
ground zero Sub vs image dynamics Sub rohanGT In-Car Entertainment 105 29th March 2009 05:01
Santro Xing XL - car audio advice needed... smartindboy In-Car Entertainment 3 12th October 2007 11:17
planning to build car sub amp, help needed clipto333 In-Car Entertainment 204 17th August 2007 16:25
Needed Help in Connectiong a Mono Sub Out to a AMP j_j In-Car Entertainment 20 31st July 2007 11:41
