Old 31st May 2009, 03:54   #1
Thumbs up ICE for Ford Ikon 1.6 Nxt
Heylo Audiophiles,
I bought an used Ford Ikon 1.6 Nxt recently! (applause)
The previous owner had a HU, front co axials and rear ovals, all Sony XPlod. Sounded nowhere close to the sound I expect in my car, so ripped them all off and have installed these new ones.
HU: Pioneer DEH 4190SD - I play music from my iphone mostly
Front: Infinity 5020CS in stock location and tweeters just above the rear view mirror adjuster knobs.
Rear: Infinity 9623i on the parcel tray.
Autoshop in Koramangala did the honours. We used the existing wiring and spacers.
I mostly listen to modern/progressive rock, pop, bollywood music and radio. I am looking for clear vocals and crisp/tight bass at decent volumes.
This setup does not have the punch that I am looking for. Sounds very mediocre. I had a very similar setup in my Swift earlier and it sounded awesome.
With Fader and Balance to 0, the rear dominates and drowns the components. At fader set to F 2, its a little OK, but bass sounds pale and the components sound underpowered.
What could be the problem? Old wiring? Lack of amp? Settings/install? Do I really need a sub?
I can put in another 10K to get the sound right. Please help fellas.
Respect,
Naresh
Swift_ICE is offline   Reply With Quote
Old 31st May 2009, 12:32   #2
frankmehta's Avatar
Thanked: 2,334 Times
add an amp. something like the jbl gto 1004. very powerful, and an option to use 2 of its channels later, to power any sub.
amplifiy the fronts and rears and you will be more than happy with the punch!
make sure the hpf and lpf is done from the amplifier, since you will have to keep the hpf off from the head unit.
an hpf of about 80hz for the fronts, and NO hpf for the rears. you will be happy.
Old 1st June 2009, 23:42   #3
Smile Infinity Reference 475a
Thanks Frankmehta... How about Infinity REF475A? Or is the JBL 1004 CS better? inputs please... Also request all the gurus to please help me. Is 5.25 in components so less effective than a 6.5 in driver?
Old 2nd June 2009, 00:47   #4
audiophile's Avatar
Thanked: 23 Times
@swift ICE, I would definately suggest an amp and a good sub.
Try a JBL amp, heard that their really good.
Im currently using a setup as follows in my 1.6 and its great:
Pioneer DEH 5050UB HU with USB and iPod connection.
JBL GTO 508C component speakers---5.25".
Polk Audio DB690---6x9 oval 3 way speakers.
Sony XM-504Z 4/3 Channel amp.
Pioneer W306DVC---12" subwoofer.
Hitron RCA cables with Cadence 8 guage wiring.
Hitron fuse for 8 guage.
Damped boot.
Also...you really can't fit anything bigger than a 5.25" CS in an ikon..."buggers didn't give much space".
audiophile is offline   Reply With Quote
Old 2nd June 2009, 00:47   #5
abhinav.gupta88's Avatar
Thanked: 310 Times
The JBL 1004 is a more powerful amp than the Infinity but the infinity is really good too.
Its very balanced.
6.5 inch will definitely be better than the 5.25inch mid bass of the same product.
Old 2nd June 2009, 01:01   #6
greenhorn's Avatar
Thanked: 1,518 Times
were proper spacer rings used to mount the 5"ers on the 5x7 frame? if they are just held in place there, you will lose out on the mid bass in front
Old 2nd June 2009, 01:06   #7
audiophile's Avatar
Thanked: 23 Times
+1 to greenhorn, its very necessary to use the right size spacer rings so that you don't loose out on the mid bass.
Old 2nd June 2009, 03:38   #8
govigov's Avatar
Thanked: 531 Times
The stock front location in the ikon is 5.25", if you need to go in for 6.5", you need to use spacers and one needs to cut the front door pads. :(
govigov is offline   Reply With Quote
Old 2nd June 2009, 09:04   #9
sathee46's Avatar
The 1004 is a brutally powerful amplifier. The 475a though less powerful, is rated high in terms of SQ. For your listening taste I'd suggest you get the 475a.
The 6.5 is always more effective, but the 5.25 is not far behind. For the Ikon it is better to have 5.25.
sathee46 is offline   Reply With Quote
Old 2nd June 2009, 20:37   #10
Smile
Damped boot.
Wow, thats what I call business. I dont have so much money to blow at the moment, so will take a step by step approach. First an amp then maybe the sub...
Buggers Even I am not convinced with the idea of cutting the door panels AND I have already bought a pair of 5 inchers!
oh no.. no cutting, I would rather use the stock size.
Yes, made sure the correct size spacers were used. I suspect the wiring though, so will get it changed to OFC in the first chance.
Its very balanced.
I gather I should audition an infinity 475A and the JBL 1004 before settling on one.
Any idea where I would get the best deal in Bangalore and the price quotes for these 2 amps if someone has it handy?
Thanks a lot fellas for all the help!
Cheers,
Naresh
Old 2nd June 2009, 23:05   #11
nitrous's Avatar
Thanked: 285 Times
I think the Infinity References have a 2ohm (2.86) impedance.
Even a JBL GT5-A604 should suffice. It should give anything between 70-80W RMS @ 13.8V.
Old 2nd June 2009, 23:33   #12
Do you think the SQ will be same?
Old 5th June 2009, 13:06   #13
audiophile's Avatar
Thanked: 23 Times
Cheers,
Naresh
Hey Naresh, Check with Satya from Evo, he might be able to help you here.
You can reach him at 9845376094.
Old 5th June 2009, 17:40   #14
panky12345's Avatar
Thanked: 150 Times
audiophile.. please use the PM for phone numbers. Its a public forum. :-)
Old 5th June 2009, 18:22   #15
audiophile's Avatar
Thanked: 23 Times
Hey panky, My bad....will remember that from next time onwards.
Ford Ikon 1.6 Nxt ZXI - 6 years, 72,000 kms Damu Long-Term Ownership Reviews 135 24th April 2015 12:36
Starting Problem for Ford Ikon 1.6 Nxt obed5579 Technical Stuff 0 17th June 2009 13:25
ford fiesta SXI after Ford IKON nxt amolathalye Sedans 10 24th February 2009 10:19
Hello..I am from Mumbai owning FORD Ikon 1.6 Nxt daudani Introduce yourself 4 12th February 2009 18:50
2004 Ford Ikon 1.6 nxt repeated ECM Fuse blowout 1100D Technical Stuff 13 22nd February 2007 22:02
