Old 2nd June 2009, 18:07   #1
Awaiting Email Confirmation
Thanked: 9 Times
Unhappy Sound Problem in ICE Setup
Namaste Guruji(s).
Given below is the ICE setup in my new Ford IKON.
- Kenwood 6539 HU
- Front 5 1/4" JBL component speakers
- Rear 330 W 6" GTO series oval Speakers.
The sound is crystal clear with minute details in the low to mid volume level. (settings are with mid bass and fader level set to 2)
But when I pump up the volume on highways, the speakers tend to make a "grrr" "grrr" sound. It completely turns me off what I enjoy in the mid volume.
Could any of the gurujis advice me on the problem and course of action?
B.T.W i got the ICE setup done bu Autoshop in Koramangala.
Thanks in advance
-Vinay
catchvinny is offline   Reply With Quote
Old 2nd June 2009, 18:44   #2
panky12345's Avatar
Thanked: 126 Times
Just install an amp and you'll be all set!
Old 2nd June 2009, 18:53   #3
Thanked: 9 Times
Default Thanks Panky
Well pankyji, that addresses my course of action. but I am unable to understand the problem . Help me in understanding the problem [tech stuff also will do ]
Old 2nd June 2009, 18:54   #4
m4ugr8's Avatar
Thanked: 123 Times
Does your HU have HPF/LPF Feature?? If yes check at what settings these are set at, If the settings are THROUGH, Take the HPF to 80Hz and the voice will not crack at high volumes. Take all the EQ settings to FLAT!!
EDIT: Its a 6539, lovely, just set the LPF and HPF and you should be good to go.
m4ugr8 is offline   Reply With Quote
Old 3rd June 2009, 15:29   #5
Sam Kapasi's Avatar
Thanked: 1,453 Times
Vinny,
The reason you have those sounds is because you are overdriving the puny amplifier inside your head unit.
If you really want to play loud, an amplifier is your only answer.
Old 3rd June 2009, 17:05   #6
DerAlte's Avatar
Thanked: 2,876 Times
(Sam's answer is quite complete, but still...) At the volume level you are using, the internal amplifier of the HU (usually 18W RMS) is going into 'clipping', which is producing harmonics which were not there in the original music. The speakers are faithfully reproducing these unwanted harmonics. External amps, which are capable of handling at least 40-50W RMS, do not go into clipping at such volumes. Not that such amps are slouches, if you intend to go still louder, you will need to put in amps which can pump closer to the safe wattage of the speakers (say at least 80W RMS).
Old 8th July 2009, 13:52   #7
Thanked: 9 Times
Thumbs up thanks
Thanks deralte and sam... and also to m4ugr8 for his inputs on handling the noise... As per m4u's inputs, the HPF and LPF settings have helped considerably.... Sound is much better and safe higher volumes... as others have stated and since I am aware of the unavailability of the amp in my car, I have not gone to too much high volumes... will get a amp installed soon...
Anyways, the ICE setup what I have right now keeps me completely happy for what I was craving for...
All the guru's out here.. please suggest me the right amp for my ICE setup...
Old 8th July 2009, 14:22   #8
greenhorn's Avatar
Thanked: 1,318 Times
if you are not a sucker for bass, reduce the bass levels (via EQ or LPF). You'll get cleaner sound, but with less bass
Old 8th July 2009, 16:21   #9
shreyasma's Avatar
@catchvinny, dont play components below 80HZ. components are not meant to produce lower frequencies
shreyasma is offline   Reply With Quote
Old 13th July 2009, 18:05   #10
Thanked: 9 Times
Unhappy the confusion
@Shreyasma,
I am confused a bit on the part of playing the compos below 80Hz.
Here are the settings available in my HU.
HPF with front and rear settings separately: Through, 80Hz, 100Hz, 120Hz, 150Hz and 180 Hz.
only one LPF option: Through, 60Hz, 80Hz, 100Hz and 120Hz.
Right now the settings are with HPF - front at 80Hz, HPF -rear at Through and LPF at Through.
Now I am not sure what is happening with the LPF setting. Does it apply to front or rear? In anycase what should my settings be with the available options?
Old 13th July 2009, 20:10   #11
Invinsible's Avatar
Thanked: 60 Times
try the front with HPF: 80 / 100hz
This means it will play the frequencies above 80hz / 100hz
For the rear: keep HPF at '80hz' and the LPF should be 'through'.
This should make some difference in sound but as everysaid adding an external amp will deffinitely help.
Not true, my Morel comps plays good and clean at even 50 or 63hz.
It all depends how the driver is designed.
Last edited by Rehaan : 14th July 2009 at 13:11. Reason: Posts merged. Please use the EDIT button to add to an existing post within 20mins instead of making another post. Thanks.
Invinsible is offline   Reply With Quote
Old 13th July 2009, 21:06   #12
shreyasma's Avatar
Well actually, mine plays good at all through and at 63HZ (never tried 50Hz).
But isnt the components supposed to be for mid bass and highs?
For all low frequencies it should be the sub. I may be wrong in my understanding.
Originally Posted by catchvinny View Post
@Shreyasma,
Post #11 by Invisible is fair enough and should make difference. Try that out and see if your ears feel good
Old 15th July 2009, 01:20   #13
thelord's Avatar
@catchvinny
Kenwood 6539 has 3-RCA out, for front,rear and sub-woofer respectively.
I am not sure but I think the LPF setting comes into play when you have configured the HU to a Subwoofer (with an amp of course).
I'd say keep the HPF for fronts at 80-100Hz depending on your music taste and set the Rear HPF to 'Thru' as you don't have an sub-woofer and you would need some bass from the rear coaxials.
Great HU by the way, Kenwood 6539.
thelord is offline   Reply With Quote
Sound Setup Tuning for my Aveo arup10 In-Car Entertainment 12 14th June 2010 13:02
Problem with surround sound setup COUGAR Gadgets, Computers & Software 4 16th May 2009 12:49
Woofer from a computer sound system possible in a car audio setup? Deeps In-Car Entertainment 2 5th August 2008 22:51
Sound Quality not good on new ICE setup. Help! maverickzCar In-Car Entertainment 24 28th December 2007 15:15
Surround Sound Setup in SX4 deusex In-Car Entertainment 3 3rd September 2007 19:31
