Old 4th June 2009, 13:58   #31
Bass&Trouble's Avatar
Thanked: 71 Times
Originally Posted by BmwAddict View Post
http://www.dynaudio.com/eng/pdf/Esotar2_1200.pdf
JBL Car & Marine Audio
How should we compare the products ? I mean in general I should have an idea to differentiate them.
Comparing on paper will be an arduous task for all the various items that will comprise your setup. It could also be misleading since some brands do have ways to hype up what the product looks like on paper. If it is possible, you should check out some good installs in person and then decide what you want to go in for. It is not always necessary that two fellows with a 10L budget will end up using identical gear.
Old 4th June 2009, 14:01   #32
zucchero's Avatar
great budget.go through the forum.i am sure you will find many installs.audition and then buy.
zucchero is offline   Reply With Quote
Old 4th June 2009, 14:37   #33
akbaree's Avatar
Thanked: 50 Times
Amps: Steg, Audision (VRx), Sinfoni, Tru C7, and this one (ok it aint made anymore) Car Audio - ADCOM
Will adding McIntosh a good idea to this list?
Speakers: Dyn, SS (you have to DIY a a bit), JL (subs), ID (subs), GZ (subs), DLS, Rainbow, Illusion, Kappa Perfect (Infinity), etc..
Dyn or Morel? I am not sure why we don't have Focal here.
akbaree is offline   Reply With Quote
Old 4th June 2009, 14:44   #34
Try sundown/US AMPS/Zapco for amplifiers !!
VOiLA is offline   Reply With Quote
Old 4th June 2009, 16:53   #35
navpreet318's Avatar
Thanked: 894 Times
zucchero!! you have only that much to say.BMWaddict this is the only man in on Tbhp to have Dynaudio.ask him for his review.
He and I both are totally biased towards Dynaudio.
Why? because there is simply NO other comparable speaker in this class.
And regarding comparing speakers.Well Dynaudio Esotar is for some 2 lakhs for a single set of speakers.So comparing it to anything available in india as of now would be the biggest criminal offence in the whole world.lol.
the dynaudio coupled with the Steg Masterstroke or one of those Tube genesis amps and you'll his the sweet spot of music.
Now since you have stated that you have liked the JBL system then you have an option of bringing down your budget to 1-2 lakhs total.because using somehting like the steg masterstroke for the JBL would be an overkill.actually it would be like installing a jet engine on a cycle.lol.
But then if you're happy with the JBL then go for it and you can use the rest of the money to get more accessories or maybe a superbike or maybe you can gift it to me so that i can get myself a dynaudio audio system.
navpreet318 is offline   Reply With Quote
Old 4th June 2009, 17:47   #36
BmwAddict's Avatar
I think I may go for 12" Esotar 1200,it's classic
BmwAddict is offline   Reply With Quote
Old 4th June 2009, 18:08   #37
greenhorn's Avatar
Thanked: 1,509 Times
BMWaddict, I'd seriously recommend that you set out and find a good installer before making up a list of equipment. I'd say installer > equipment, and find out what he can source for you
Old 4th June 2009, 18:09   #38
BmwAddict's Avatar
I am done with Sub and Amp
Sub: DynAudio Esator 1200
Amp:Steg MasterStroke 3000
any companies for the components,illusion audio are good but any other company ?
Old 4th June 2009, 18:16   #39
sathee46's Avatar
Why not components from the same family, the Dynaudio System 362!
sathee46 is offline   Reply With Quote
Old 4th June 2009, 18:36   #40
Thanked: 294 Times
You can look for other brands like Morel, Alpine F-1 Series, Scanspeak(will be needing good installer for the same), Focal Be.
Old 4th June 2009, 18:36   #41
akbaree's Avatar
Thanked: 50 Times
Great choice. Not that I have heard any of these, but I have read that Dyn Audio Esotar 1200 are great subs.
Did you even considered Focal Berilium or Morel Ultimo subs? Your choice is great, but your budget offeres so many high end possibilities.
Old 4th June 2009, 19:55   #42
zucchero's Avatar
you want to have illusion audio comps with esotar2 1200 and steg masterstroke
sathee even the dynaudio esotec 362 is not any worth for the esotar.an absolute waste of money.
Old 4th June 2009, 20:10   #43
BmwAddict's Avatar
No.I did not start with components.Sir,I am here to take an advise and members like you should guide me in the right way if you think that I am wasting my money.Why would I start topic here ? I can ask any local guy in my accessory shop and get that done ? I trust the members here.
Please guide me.
Am I good with the sub and amp ?
Old 4th June 2009, 20:11   #44
frankmehta's Avatar
Thanked: 2,318 Times
I would recommend the following:
Dynaudio Esotar seems a very good choice, even though I havent heard them. But, then again, they are known to sound orgasmic. Hence the frontstage and the subwoofer/s can be Dynaudios. The rear fills can be Dynaudios too, albeit a slightly lower range. Esotars as rear fills would be slightly overkill, unless you plan to be chauffeured around.
Links:
Subwoofer/s:
Dynaudio - Authentic Fidelity
Midbass:
Midrange:
Tweeter:
OF course, you will be running them active, since the amps in question will be having a lot of potential to cross these speakers over.
The
Steg MSKs are definitely the chosen ones here. I doubt anyone makes them like these!
1 for the fronts and rears
1 for the subwoofer/s
STEG Audio-System
The Head unit should be an Eclipse AVX5000... PERIOD
ECLIPSE DVD Receiver AVX5000 | Fujitsu Ten
There's not much this head unit CANT do, and it's the king of all. It's beautiful looking too.
Wiring, cabling, RCA's must be TOP NOTCH.
You should zero in on the major stuff at first, and then the fine details like a bling install and the wiring, cables and rca's will be sorted out.
Old 4th June 2009, 20:31   #45
Thanked: 71 Times
I'm quite baffled at a lot of the suggestions on this thread.
Nowhere has BMWAddict mentioned that he is looking for a "textbook" SQ system. In fact, he has said that he likes the sound of JBL, and finds Bose to be 'macho for techno'. Let's face it, Bose and JBL while sounding very different from one another, are very far from the sound that a Dynaudio Esotar + Steg MSK combo can produce. Unless the JBLs he heard are the GTi series ones.
A budget of 10L does not necessarily point down the path of HX-D2s and Steg MSKs. I suspect he might be looking for something that is powerful yet clean. Anyone taking up this install should make sure that BMWAddict gets to listen to a variety of setups, and then scale it according to request. The setup might even end up significantly under the allocated budget.
TATA Aria Pride 4X4 - Heart over Mind or Mind in the Right Place? EDIT : Now Sold! ACM Test-Drives & Initial Ownership Reports 322 16th September 2015 15:51
Soda Blasting in Bangalore: Strip any coating from any surface GTO Technical Stuff 15 10th June 2015 17:22
Soda (sodium bicarbonate) Blasting Gill Technical Stuff 6 21st July 2014 13:27
MMSC Circuit Advanced Driving and Race Instruction ajmat The Team-BHP Meet Section 20 17th April 2006 22:49
