Old 10th June 2009, 00:54   #16
Sam Kapasi's Avatar
Thanked: 1,473 Times
Listen to the IDQ - it is an excellent subwoofer and you might like it. But listen to it first - one man's meat and all that.
Old 10th June 2009, 09:46   #17
arpandiv's Avatar
Thanked: 27 Times
Originally Posted by jaibir View Post
The IDQ10 is available for ~10.5k in Mumbai. Wouldnt that be a better buy than a CTX at 7.8k?
Jaibir, where in Mumbai is the IDQ available ? i would love to audition an IDQ sub.
arpandiv is offline   Reply With Quote
Old 10th June 2009, 09:56   #18
jaibir's Avatar
Thanked: 48 Times
Thanks for the advise guys. Will do the mono install this weekend and start auditioning subs. Have already borrowed a friend's JBL 12" to kick things off (the one that use to come in a sealed box). Others on the list are the IDQ, Polk 8" and JBL 10". Will also try to see if I can get hold of a JL audio one.
@arpaniv, its available at FM Drive in Khar
jaibir is offline   Reply With Quote
Old 15th June 2009, 15:16   #19
jaibir's Avatar
Thanked: 48 Times
Got the mono installed this weekend and plugged in the JBL 12". Unofrtunately, there was no box ready for the IDQ so couldnt demo that (hopefully next weekend). The JBL sounds ok but doesnt seem to suite my tastes. Its response to different bass tones in quick succession (something like a bass guitar solo) seems to be unable to keep up with the music. For my needs, something that can do that and blend in the music would work - even if it doesnt go as low. The JBL seems to work very well for more beaty music, where the bass is more prominent but simpler . Have a couple of weeks to demo some other stuff so should be able to find something that suits my tastes.
Old 15th June 2009, 17:34   #20
Invinsible's Avatar
Thanked: 60 Times
Default Polk Audio Db Series
How Good are the Polk audio db series 10" subs? Can anyone give any feedback on this?
Invinsible is offline   Reply With Quote
Old 15th June 2009, 18:25   #21
I second your observations mate! I tried listening to DT's hollow years from live at budokan and it sucked big time. Let's not even get into Opeth. But then I was running the cs1204 on a kenwood 8401 which had 6db/octave crossover slope so I guess I couldn't say that definitively. Will watch this space for sure.
BTW, whats the LPF set @?
wannabe loser is offline   Reply With Quote
Old 15th June 2009, 18:29   #22
jaibir's Avatar
Thanked: 48 Times
Its currently set at 100. Will lower it at the next tweaking session - 70-80 should do. Have the HPF set for the rear ovals. Will try and match that.
Old 15th June 2009, 18:46   #23
Yeah, 70-80 should make a difference me thinks. Whats the crossover slope on the Eclipse XA1000 again?
And what are the compos crossed at?
Old 15th June 2009, 19:34   #24
jaibir's Avatar
Thanked: 48 Times
This is what the specs say for the mono:
"variable low-pass filter (50-200 Hz, 18 dB/octave)"
Have left the compos at flat (no hpf/lpf) from the amp. Tried the hpf but it makes them sound a little muffled. I dont play them too loud so decided to leave it off.
NHC - JBLified in tune with Pioneer 5050UB to boom with Eclipse XA1000! superbhikari In-Car Entertainment 60 9th June 2009 00:22
Which one: Dual 8" sub V/s Single 10" sub? Invinsible In-Car Entertainment 53 28th May 2009 13:33
ground zero Sub vs image dynamics Sub rohanGT In-Car Entertainment 105 29th March 2009 05:01
Getz ICE upgrade - Alpine HU, IDQ sub and Eclipse mono PatienceWins In-Car Entertainment 29 23rd August 2008 20:59
Mitsubishi Eclipse & Plymouth Eagle highwayblaze The International Automotive Scene 4 12th March 2004 18:47
