Old 8th June 2009, 21:53   #1
jaibir's Avatar
Thanked: 48 Times
Default SQ sub with Eclipse XA1000
Folks,
Finally I'm getting to the last stage of my Swift's ICE upgrade: the mono amp and sub. Have already decided on the Eclipse XA1000 as I'm getting a brilliant deal on one. Now wondering which sub to put with it. My current install is: Eclipse CD3100, JBL 1004, Illusion 6.1 Electra, JBL GTO937. I mainly listen to rock (full spectrum from Simon & Garfunkel to moderately heavy metal like Iron Maiden) along with some bits and bobs of instrumental, pop etc. I'm looking for an SQ sub (no boom boom), preferably a 10". If there is an under-seat option, that would be ideal. My budget for the Sub + enclosure + wiring + install is 10-12k. The amp is outside this. Suggestions on which sub would be much appreciated.
Many thanks,
Jaibir
jaibir is offline   Reply With Quote
Old 8th June 2009, 22:01   #2
abhinav.gupta88's Avatar
Thanked: 310 Times
Ground Zero 30T is a good option for you.
rated 400w rms and is a 4 ohm SVC.
8k
Plus you should have the enclosure and wiring for around 4-5k. And you'll be good to go.
Contact Bass&Trouble.
Old 8th June 2009, 22:11   #3
akbaree's Avatar
Thanked: 50 Times
You may like to check JL. You can try JL 10W1V2-4. Your amp will have more power than this sub will ever need. If you are okay to stretch your budget, you cal try W3 as well. But W1v2 is the slimmer of two and may fit in most compact installations (as mentioned by you).
Note: Although I have heard W3, but I haven't heard W1. I am suggesting purely from my W3 experience, the brand value, and reviews from Crutchfield.
akbaree is offline   Reply With Quote
Old 9th June 2009, 00:19   #4
superbhikari's Avatar
Thanked: 154 Times
Congrats on the great Eclipse Mono Amp. I think you should audition the ID CTX 12" sub. It will be perfectly under your budget + will satisfy your requirements. Pure SQ it is on the Eclipse XA 1000. I just auditioned it on my setup yesterday.
Contact the ID dealer/distributor to find out if it's available in 10". I am afraid it is not.
superbhikari is offline   Reply With Quote
Old 9th June 2009, 12:05   #5
jaibir's Avatar
Thanked: 48 Times
8k
Thanks Abbinav. Considered that but would really prefer a 10 incher if possible
Thanks Akbaree. Any idea if its available in Mumbai? Also, how does it compare to the IDQ 10"?
Thanks Superbhikari. Any idea how this compares to the IDQ 10"? Thats available here for not too much more money (~2k extra).
Jaibir
Old 9th June 2009, 12:40   #6
abhibh's Avatar
Thanked: 34 Times
Jaibir
I am sure iDCTX is available in 10". Not sure of the price though. From what i have heard IDQ and iDCTX are different subs. Are you buying sub from US ?
Old 9th June 2009, 12:44   #7
Thanked: 310 Times
ID CTX 10 inch = 7800/7900
Old 9th June 2009, 12:53   #8
karankapoor's Avatar
IDCTX 10" is very much available and is priced 7800/- from what i have heard about it is a pure value for money sub.
Contact gunbir he can arrange one for you in mumbai.
karankapoor is offline   Reply With Quote
Old 9th June 2009, 16:14   #9
jaibir's Avatar
Thanked: 48 Times
The IDQ10 is available for ~10.5k in Mumbai. Wouldnt that be a better buy than a CTX at 7.8k? I wouldnt mind extending the budget if its a substantially better sub. If the differences are small, will stick with the cheaper option.
Old 9th June 2009, 17:10   #10
abhibh's Avatar
Thanked: 34 Times
Which IDQ version is available ? V2 or V3 ?
Old 9th June 2009, 17:31   #11
Abhi i think it is V2 version, Yes go for it and that's a good deal you are getting there (this model use to retails @ $160 in the US) . Is it with B&W.
Old 9th June 2009, 18:18   #12
jaibir's Avatar
Thanked: 48 Times
It is the V2 version. I'll have to check on the B&W - I think its with warranty but not sure
Old 9th June 2009, 18:58   #13
Thanked: 310 Times
It must be with warranty considering its with bill
Old 10th June 2009, 00:36   #14
Thanked: 295 Times
Audition a few subs before buying. You might end up with something else.
Old 10th June 2009, 00:50   #15
Thanked: 154 Times
That's too tempting price for an IDQ sub. Go for it if you like it. I find CTX more to my liking/taste than IDQ though. But that's me. Audition both and then decide.
NHC - JBLified in tune with Pioneer 5050UB to boom with Eclipse XA1000! superbhikari In-Car Entertainment 60 9th June 2009 00:22
Which one: Dual 8" sub V/s Single 10" sub? Invinsible In-Car Entertainment 53 28th May 2009 13:33
ground zero Sub vs image dynamics Sub rohanGT In-Car Entertainment 105 29th March 2009 05:01
Getz ICE upgrade - Alpine HU, IDQ sub and Eclipse mono PatienceWins In-Car Entertainment 29 23rd August 2008 20:59
Mitsubishi Eclipse & Plymouth Eagle highwayblaze The International Automotive Scene 4 12th March 2004 18:47
