Old 11th June 2009, 09:53   #16
chiragh_bir's Avatar
Thanked: 70 Times
JBL 1004 now costs 9grands in grey , i would say stretch your budget a litlle and get it , am sure you won't regret later !!
and about placing amp , place it on rear parecel tray!! or custom work in boot!!
chiragh_bir is offline   Reply With Quote
Old 11th June 2009, 10:19   #17
phamilyman's Avatar
Thanked: 3,526 Times
abbey akshay,
you had the 5539 already - why the 6539 now?
Old 11th June 2009, 10:21   #18
Thanked: 70 Times
^^ because of ICE keeda (ice bug) ... lol !!
though it made hell lot difference in SQ and bass !!
Old 11th June 2009, 13:33   #19
abhibh's Avatar
Thanked: 34 Times
abbey akshay,
He upgraded few weeks back
You want him to expose the amp ?
Old 11th June 2009, 13:39   #20
Thanked: 70 Times
if he doesn't have any problem.. work similar to ramiee's install amps on side rack !!
Old 15th June 2009, 02:21   #21
thelord's Avatar
Guys, sorry for going AWOL for a few days.
Was busy bringing the baby home and putting in new shoes and alloys.
Anyways, I received my Illusion Audio 4.1 components late Saturday evening, so couldn't get the install done that day.
Now am facing a small problem of sorts. The mid-woofer speakers have four mounting brackets due to which they can't be fitted as it is in Alto's dash. From the install pics I've seen at t-bhp forums, I understand that I'll have to cut two brackets for the mid-woofers to sit comfortably in the dash pocket. Now my question is, are these brackets easy to cut? I mean, will a normal installer be able to do a decent job without damaging the speaker wall?
I've seen the Blau 4" co-axials and they have a slightly easy-to-cut mechanism at the bracket joints but the Illusion Comps seem to be made of pretty solid material and there is no "easy" spot so to speak, to cut the brackets.
So, any recommended technique to get the cutting done?
Am not in a hurry. The research on tweeter placement follows next after I get the mid-wooofers ready for install
Thanks!
thelord is offline   Reply With Quote
Old 15th June 2009, 10:48   #22
Thanked: 70 Times
no need to do any cutting.. just take it to good installer he will solve the problem for you.
Pm me your number and i will get back to you , don't worry about the install so much its pretty simple..
Just get the amp if possible JBL 1004 or atleast Blaupunkt GTA 480 or Blaupunkt MKII special..
Some pics of illusions please !
Old 15th June 2009, 11:33   #23
thelord's Avatar
@chiragh
Thanks bro. I'll give you a call in a couple of hours.
Here are a few pics of the Illusion components. Will post some more when I get home.
Old 15th June 2009, 12:53   #24
panky12345's Avatar
Thanked: 150 Times
congrats thelord.. technocrat is using the same and think he's pretty happy with these. INMO, you should've gone in for 6.1
Old 15th June 2009, 15:47   #25
Technocrat's Avatar
Thanked: 2,589 Times
Yes I have the same one but now I have shifted to 6.1 in my Alto
Old 15th June 2009, 16:35   #26
Thanked: 70 Times
Go for Blaupunkt GTA mk2 amp with 6539 or atleast 5539 head.. you will be more than satisfied..
And try Pioneer Sub in sealed box which produce more low end bass than JBL
Old 16th June 2009, 02:58   #27
thelord's Avatar
Thanks guys.
@panky12345
6 inchers open a lot of options for the components. But no cutting of doors, so am limited to stock 4 inch solutions.
@Technocrat
Your thread on Illusion 4.1 in an Alto helped a lot.
@chiragh
Veer, thanks a lot for recommending the shop. Very knowledgeable fellow.
Am quite confident the install will go fine.
Anyways, here are a few setups that have me confused now
Setup A
HU - Pioneer 5150B
Amp - JBL S644
Sub - JBL CS1205
Setup B
HU - Pioneer 5150B
Amp - Kenwood 8401
Sub - JBL CS1205
Setup C
HU - Kenwood 6539
Amp - Kenwood 8401
Sub - JBL CS1205
From what I've read about Blaupunkt Special MKII amp, looks like its not possible to set HPF beyond 80 Hz. For the Illusion 4 inch components, I need to set the HPF to around 110-125 hz.
My taste in music boils down to Lounge / Chill-Out genres.
I prefer SQ, and usually listen to music at moderate volume,
Bass I prefer low, soft and consistent and definitely not dominating the mids and vocals.
So is the Kenwood 8401 a better buy in my case?
For the head-unit, am getting 5150B for 7.8k and Kenwood 6539 for 8.8k. Is it worth the extra 1k?
Budget for AMP + SUB is 10k max. Any other sub that I should consider in this range?
Phew, so many options...
Old 16th June 2009, 12:49   #28
Technocrat's Avatar
@thelord : Glad to be of help, even if indirectly
Old 16th June 2009, 13:11   #29
amit_mechengg's Avatar
Thanked: 1,556 Times
you need to cut the 2 diagonal ears for fitting them in alto. its a easy job. you could have asked B&T to cut them and send it to you
nice choice of ICE. but you will want more as time goes on. have a look at my ice in the alto too.
http://www.team-bhp.com/forum/sound-...d-nice-sq.html
Old 16th June 2009, 13:18   #30
abhibh's Avatar
Thanked: 34 Times
i would go with Setup C. Get a sealed enclosure.
Chandigarh - Mumbai - Chandigarh : Route Queries ankit_chd Route / Travel Queries 34 26th February 2018 17:06
Alto - ICE Upgrade with DLS, Kenwood, Blaupunkt. Updated pics on pg 3 thelord In-Car Entertainment 89 9th October 2010 21:44
Chandigarh-Dehradun-Chandigarh YC.BALENO.CHD Travelogues 2 25th May 2009 02:32
To All Alto Owners / Experts: Need suggestion about Alto ICE Installation. nitin.dangayach In-Car Entertainment 12 19th August 2008 11:22
