Old 10th June 2009, 10:54   #1
asejwal's Avatar
Thanked: 15 Times
Default Advice Required on ICEing my Safari Ex 4x4
Hello all brethren out there....I acquired a Safari 2.2Vtt Ex 4x4 early this year and mine was probably the first 2009 models on this forum. Well, I am pretty dissatisfied with the stock ICE HU and the stock speakers. I am jotting down my queries, please help..
1. What are the stock speakers in the Safari Ex model? Brand? Components/Co-axials? Size? Mounting Depth?
2. How many pre-outs do we have in this HU (Alpine 9870, if I am not wrong)?
3. I have the following equipment with me which I have 'collected' over the years and I plan to use this in my Safari.
Pioneer 7950 HU; JBL 75.4; JBL 300.1; JBL CS1204T
How should I go about it? Also, my beast is just about 2 months old. If I go in for such extensive upgrading/replacing of stuff, does it lead to the warranty going void? If yes, what are the options available for upgradation of the stock ICE?
4. Some good installers in the NCR region...I desperately want pointers on this.
Guys, please help. It is such a crappy system in a gem of a vehicle. I know you'll bail me out of this.....
asejwal is offline   Reply With Quote
Old 10th June 2009, 11:03   #2
navin's Avatar
Thanked: 4,286 Times
1. Damping
2. upgrade power cable (Big 3).
3. The 75.4 can be used to drive 4 speakers - 2 in the front and 2 in the rear. the CS 300 can be used to drive the sub (1204T).
if you do not cut the wirining harness but use the adapter then your warranty wont be Void. If you want to be doubly sure ask your dealer to claify this.
Old 10th June 2009, 11:05   #3
greenhorn's Avatar
Thanked: 1,519 Times
the alpine HU is far better than most setups that come OE. Unfortunately it has only 1 pre out. It does sound better than the pio 7950, but since you need 4 pre outs, will have to swap them.
the OE comps are blaupunkt
no, you wont lose warranty.
dealers/installers in the NCR, just search on team bhp, there are more than enough threads for the same
http://www.team-bhp.com/forum/ask-gu...delhi-ncr.html for ex!
Old 10th June 2009, 11:30   #4
asejwal's Avatar
Thanked: 15 Times
1. Damping
Thanx Navin on the inputs.
Do you really need damping on the Safari doors? They are already so heavy - damping them would mean further adding weight...
Also, do you think I need to change the stock speakers? Are they component speakers or co-axials - they lack bass; the sound is very 'phatphatiya', if you get what I mean...
Old 10th June 2009, 11:58   #5
karankapoor's Avatar
Damping helps even if the doors are heavy or strong its always advisable to get damping if you are running your speakers though an amp.
Mostly OE speakers are coax get them changed to components.
karankapoor is offline   Reply With Quote
Old 10th June 2009, 12:30   #6
greenhorn's Avatar
you need to damp the safari door panels, since the speakers are mounted on them, and not the door frame. They will rattle to no end if you dont damp them
Old 10th June 2009, 14:36   #7
DerAlte's Avatar
Thanked: 2,879 Times
No, greenie, surprisingly they neither rattle nor buzz, but one can feel the vibrations in the panel (energy lost -> less efficiency). Damping those massive FRP areas is not a simple job: first stiffness has to be increased (FG?) and *then* the panel has to be damped.
Are you sure the compos are Blau? Me think not, though whichever brand they are not bad at all.
@asejwal, perhaps the lack of bass that you are feeling is more due to a higher expectation, as well as the fact that engine rumble and body panel resonance (doors, roof, floor) is masking most of the usable bass from the components. The rear coaxials are good, though a bit muted at normal front volume.
Old 10th June 2009, 14:54   #8
asejwal's Avatar
Thanked: 15 Times
@DerAlte
Bro...I usually drive a Sierra and therefore, I find my Safari to be 'very silent' when it comes to ambient noise inside the cabin. There is, in fact, no bass at all in the speakers...
I have listed some equipment which I already have. Can guys please help me out in suggesting some good components (what brand and dia) and some good wiring? (budget of about 15k for the same)
Pertaining to the warranty issue, I sent a mail for clarification to info@safaridicor.com. After 2 days, yet to hear from them...
Old 10th June 2009, 14:56   #9
greenhorn's Avatar
I recall reading elsewhere here that the oe comps are blau. Will search and post where later
Old 10th June 2009, 14:56   #10
jkdas's Avatar
Thanked: 1,436 Times
from experience?
No rattle for me till now. Use a JBL GTO1000 ported box too with mono amp. Pretty happy with what I hear for a stock speaker (compo). I upgraded the HU though, big difference, to another Alpine.
Sad about the co-ax though.
And I am not sure about the brand; looked of a good quality( had posted pic somewhere here).
Old 10th June 2009, 15:00   #11
asejwal's Avatar
Thanked: 15 Times
What Alpine model did you upgrade to? Care to share...
Old 10th June 2009, 15:00   #12
Sam Kapasi's Avatar
Thanked: 1,473 Times
Fairly decent "collection" you happen to have lying around lol. Good luck.
Old 10th June 2009, 15:06   #13
asejwal's Avatar
Thanked: 15 Times
Thanks Sam. Help me put it up as a decent ICE system...
Old 10th June 2009, 15:21   #14
jkdas's Avatar
http://www.team-bhp.com/forum/sound-...ice-beast.html
9883
Old 10th June 2009, 15:57   #15
greenhorn's Avatar
from experience?
I guess mine alone. JK's safari's comps ( and doors) sound quite fine the way they are , but i suppose damping might be needed once he amps them
ICEing Safari LX ankitwanchoo In-Car Entertainment 6 1st June 2010 15:14
Need Advice: New Safari 2.2 LX VTT or Safari 2008 3.0 Top Model? alexnazim SUVs, MUVs & 4x4s 150 1st December 2009 11:20
Buying Tata Safari Lx - Black, Advice Required on 4x2 or 4x4(Ex) v&v Technical Stuff 48 6th February 2009 07:44
