Old 21st May 2010, 22:22   #91
ghpk's Avatar
Thanked: 193 Times
its little cheaper now.
check more from zotac
Old 21st May 2010, 23:48   #92
nisarg86's Avatar
Thanked: 12 Times
Yup. Nice VFm motherboard. this one retails around now 4-5K.
ST. Hows the Asus Xonar ? Did you test it ? I am ditching USB soundcard and getting new mobo, cpu and sound card. have you used any preamp ? Output voltages are very low on xonar. something like 2v.
is it DIY CASE ? or u purchased it from somewhere ?
nisarg86 is offline   Reply With Quote
Old 22nd May 2010, 21:34   #93
ST7677's Avatar
Thanked: 45 Times
I have not yet connected the Asus DX to the car amps yet. But tried it at home and it sounded good. However many people abroad have been using it.
Asus D2x and DX are considered amongst the best sound cards lately, comparable to M-Audio but better VFM.
The case is a Winsis Wi-08
Before this I was considering Mocoso case. But I bought this one as it was best size for me. It neatly fits under the Civic front seat even at full low height. Has PCI half profile card provision, Optical drive provision, etc. and plenty of space inside to allow good ventilation.
Also it came with a PSU which works from 110-220v so I am using it at home to set it up.
ST7677 is offline   Reply With Quote
Old 23rd May 2010, 02:56   #94
ST7677's Avatar
Thanked: 45 Times
Is it recommended to install the HDD in horizontal or vertical (perpendicular to the road)?
It is presently installed horizontally (standard position) and I am worried about the Bangalore potholes and speedbreakers!!!
My Laptop (not carputer) HDD keeps going into temporary protection mode every now and then, when I use it in the car while driving. I don;t want that to happen on my carputer, as the music/media might start stuttering.
Old 23rd May 2010, 11:45   #95
Thanked: 41 Times
well as per my view the HDD should be in standing position. it avoids the skipping of the HDD.
monty9991 is offline   Reply With Quote
Old 23rd May 2010, 12:50   #96
lalitk25's Avatar
Hi ST7677
I have not read the entire post but at one point you have mentioned about placing your PC below drivers seat which means it will block the rear ac vent below your driver seat and it will create problem for rear side cooling in auto and manual mode (air on feet)........
I think you might have thought about it earlier but just a Food For your Thought.
lalitk25 is offline   Reply With Quote
Old 23rd May 2010, 13:30   #97
ST7677's Avatar
Thanked: 45 Times
Under the front seat, if you notice there is a partition and the a/c vents are towards the rear passenger. My carpc will be on the other side of the partition, under the front passenger thighs, so it will not interfere at all with the a/c vents.
Old 23rd May 2010, 14:57   #98
ghpk's Avatar
Thanked: 193 Times
yes that looks ok, and having a carputer under seat would be better cooled than one boiling CPU in the trunk.
However care should be taken for cabinet top (which faces unseat area) if you have open vents on it, any water/drink spill can get inside chassis, use vents on sides for perfect Air-flow.
Old 23rd May 2010, 21:19   #99
lalitk25's Avatar
Oh thats fine then... as mentioned earlier you should have taken care of about this point and you did
Just one more observation to keep size small you could have used a laptop instead of a desktop components everything could have squeezed a lot...... may be I am missing something here....
Old 24th May 2010, 12:35   #100
ST7677's Avatar
Thanked: 45 Times
I have 2 spare laptops at home, and one is being used as Carpc, while the carpc is actually being built. So, It can be used, but it is not a suitable option.
There are following issues:
1. Expandability - adding sound cards / video cards, connectivity
2. Power management - powering from car battery and switching on / off with ignition, amplifier power control, Battery voltage protection, etc
3. Adding tons of accessories required for car - Cameras, OBD, GPS, etc (laptops have very limited connectivity, here we are talking about 12+ USBs, 8 outputs for Audio, 3 for videos, ++)
Most importantly a laptop is designed and built around a different purpose, and a carputer has to be designed and built around a different purpose. Changing the purpose of laptop, is possible but expensive.
Also it is not the computer per se which is expensive, it is the car pc specific needs that mostly add to the cost like - PSU, Touchscreen, peripherals, etc, so why compromise your options with a laptop. With custom approach you can decide on your objective and simply build towards it, keeping your costs low and features high.
The objectives of my carpc are defined somewhere towards beginning of this thread.
My carpc can play 192khz/24 audio on 8 channels, manage 3 different videos simultaneously, run full HD videos along with managing 16 DSP (VST) audio Plugins. Now, find me a laptop which can do all this and is cheaper / more convenient than my car pc
Finally its the journey of dreaming something and then piecing it together, with the help of wonderful fellow bhpians, that is so enjoyable and satisfying
Old 24th May 2010, 13:30   #101
ashthedivx's Avatar
Thanked: 22 Times
Exactly my thoughts too
I would also like to build up a CarPC someday with lots of features GPS, OBD, FM & lots of music/videos onboard. Though I would love to control the stuffs with Voice. However on holidays, would be picking up the Netbook attached to CarPC, check mails sitting in my hotel room and then attaching it back to CarPC next day morning.
It's not a question of Budget or How will I do it, It's something I'll love to do it 1 day
I know lots of research and hardwork is required but still I'll be game for it someday.
Old 26th May 2010, 15:09   #102
ST7677's Avatar
Thanked: 45 Times
One quick question – what are you guys using to decouple the PSU (and the carputer) from the car. i.e. if I have to take the Carpc out of the car I will need to unplug PSU from the power wire from the battery, ignition turn on wire and peripheral (LCD) power wire (that also uses regulated power from the PSU). So what connectors are recommended?
I know the PC can be opened and power connector can simply be removed from the PSU, but that may not be a very convenient approach.
Old 26th May 2010, 15:29   #103
Thanked: 41 Times
this is what i used in my earlier setup.
you can find this at any computer shop. or get nay burnt power supply and pull off one.
easy plug and play thing.
Old 26th May 2010, 17:47   #104
ST7677's Avatar
Thanked: 45 Times
I was thinking of this, but for a 120W PSU that would be 10 AMP load and for a 360W PSU (which I have) that would be a 30amp load, will this thing be able to take that much load? Agreed I will not be pushing it that much, but asking this from Safety viewpoint.
Old 26th May 2010, 18:17   #105
gigy's Avatar
Thanked: 41 Times
use automotive connector 4 pin one or more as per requirement, which has a lock on one side.
Polaris Slingshot: Part car, part motorcycle, all excitement ashkamath The International Automotive Scene 0 2nd September 2014 17:12
ICEing Honda Accord Swift_ICE In-Car Entertainment 3 5th December 2010 17:33
Honda City Vs Honda Civic E Vs Honda Civic V (pre-owned) drkunaldas Sedans 4 31st October 2010 18:07
Yay- My Carputer project just got off the ground abhi182 In-Car Entertainment 31 16th February 2009 13:47
