Old 20th June 2009, 00:05   #31
mustang89's Avatar
sirji ne finally apni thread start kar hi di.
hmmmm..i must say the boy has travelled a long way,i listened your setup on the neemrana drive and i had to take disprin because of that boooooommm.
but now the setup has gone to absolutely different level,now you actually feel like spending more time in the car.
and this setup finally help me decide what i want from my setup-SQ
mustang89 is offline   Reply With Quote
Old 20th June 2009, 00:19   #32
live2drive's Avatar
Thanked: 25 Times
lol. gone are those days with ts20's hissing in the ears and the sub booming away to glory.
And yes i have spent a lot of time in the car and wasted a lot of fuel idling, just to listen the setup.
Glad you liked the setup and thanks for the kind comments.
live2drive is offline   Reply With Quote
Old 20th June 2009, 01:07   #33
nitinralli's Avatar
Thanked: 798 Times
Originally Posted by live2drive View Post
Don't know the number of sheets. Actually pieces were cut from a roll of damping material.
Where all did you got this applied? I mean front doors and did you get the boot done also? If so then how much in total did you pay for the damping?
nitinralli is offline   Reply With Quote
Old 20th June 2009, 10:16   #34
panky12345's Avatar
Thanked: 150 Times
..true the HU gives the overall a very stock look. Great!
Old 20th June 2009, 10:47   #35
DerAlte's Avatar
Thanked: 2,879 Times
The damping material has not been applied well on the outer panel - should have used a roller to press the sheet to the panel. Otherwise, the adhesive will gradually fail and the sheet will come off.
The install looks really good otherwise. Enjoy, @live2drive!
Old 20th June 2009, 12:00   #36
abhinav.gupta88's Avatar
Thanked: 310 Times
Congrats for the upgrades Abhinav.
Need to audition it again.
Obviously the weak part is the sub!
Cheers!
Old 20th June 2009, 12:27   #37
live2drive's Avatar
Thanked: 25 Times
Got the front doors and the doorpads damped. Paid around 2.8K.
Thank you.
Thank you sir. I'll check that again with the installer. The pic shows damping in process. I forgot to click the final pic.
Cheers!
Thanks mate. Audition anytime. Yes the only weak part in the setup is the sub.
Old 20th June 2009, 12:31   #38
frankmehta's Avatar
Thanked: 2,334 Times
nothing is weak if you like it.. keep enjoying the music, and upgrade the sub ONLY if you think its absolutely necessary!
Old 20th June 2009, 12:35   #39
live2drive's Avatar
Thanked: 25 Times
Very true frank. Yes i like the sub. But it actually acts funny at times. The poor sub gets confused with two consecutive quick beats and ends up in an extended bass note.
Old 20th June 2009, 12:40   #40
m4ugr8's Avatar
Thanked: 123 Times
Thats Why I am telling you to change the sub. The subwoofer is not controlled, Its just going BOOM BOOM BOOM
BTW gurus, The Box is a 2.15 Cu. FT one ported, Will changing the box help him?? I feel the box is very big for this particular subwoofer.
m4ugr8 is offline   Reply With Quote
Old 20th June 2009, 12:45   #41
Thanked: 310 Times
2.15 Cu. FT.
I think thats way too big.
Try something smaller.
Old 20th June 2009, 13:00   #42
live2drive's Avatar
Thanked: 25 Times
Yes the box is indeed HUGE. 2.15 sq ft. Pic attached for reference.
Gurus, will a sealed box help? Bass is li'l boomy now. Will a sealed box help to get tighter bass? Specs say 1.25 sq ft for a sealed box and 1.65 sq ft for a ported box.
Old 20th June 2009, 13:12   #43
Thanked: 310 Times
Try both boxes according to the specs.
You might (not) need to upgrade the sub.
Old 20th June 2009, 13:13   #44
panky12345's Avatar
Thanked: 150 Times
yep the sealed box would give you a tighter, cleaner bass.. refer to the maual and build a box as per specs!
Old 20th June 2009, 15:12   #45
live2drive's Avatar
Thanked: 25 Times
Can anyone help me out with the dimensions of the 1.25 cu ft sealed box?
Hyundai Verna VGT: 50000 kms in 5 years. Pleasant experience at Trident Hyundai SantoshPV Long-Term Ownership Reviews 1 25th June 2013 14:50
Notorious's Verna Iced NOTORIOUS In-Car Entertainment 117 4th March 2013 22:18
Iced up my Verna CRDI monochrome In-Car Entertainment 27 1st December 2009 00:56
Hyundai Verna the beast iced mohitd In-Car Entertainment 24 23rd January 2009 12:58
Hyundai Verna Stolen with the Original Key Stolen from Hyundai Service Station .anshuman Indian Car Dealerships 56 3rd October 2007 23:46
