Old 14th June 2009, 16:31   #1
Thanked: 161 Times
Default Eclipse CD7200MKII Preout 8V
Hi Gurus...
I read that the Eclipse CD7200MKII has a pre-out voltage of 8v. Now amps like JBL 75.4 have a max input voltage of 5.8V. So does this mean that the Eclipse CD7200MKII is not compatible with JBL 75.4 ??
Thanks in advance
jinu_joseph is offline   Reply With Quote
Old 14th June 2009, 19:24   #2
frankmehta's Avatar
Thanked: 2,334 Times
i have a 7200MKII paired with 2 amps, one which has a max input sensitivity of 4V only, and the other, which has a max input voltage sensitivity of 7V. both amps have their gains turned down to almost zero (the 7V one is slightly turned up, since the fronts have to blend with the rears well).
worry not about that banter. just make sure you dont turn your gains too high up and you will be a happy man..
by the way, very good choice of head unit ;-)
Old 14th June 2009, 20:42   #3
Thanked: 161 Times
Thanks.. Actually was deciding on the clarion DXZ 785 but then heard about this and realized not only is it supposed to be better than the 785 but also has bluetooth.. :-).
But I still dont know how much it costs in Mumbai and availability.. any ideas on those. I currently have the following setup:
JBL GTO 75.4 amp
JBL GTO 607c - front - powered by amp
JBL PS552 coax - rear - powered by HU
JBL CS 1204B Sub - powered by amp
I plan to add one more amp for the SUB and then power both the front and rear from the 75.4 amp. I will not be changing the amp and the sub, but i plan to upgrade the front comps and rear coaxs... with something that will match the Eclipse .. any suggestions ?
Old 14th June 2009, 22:09   #4
akbaree's Avatar
Thanked: 50 Times
Originally Posted by jinu_joseph View Post
Hi Gurus...
Thanks in advance
Jinu, I have Eclipse CD7100 and had similar question. I had posted on the advice section and here's the reply @Deralte
http://www.team-bhp.com/forum/ask-gu...ml#post1345036
Refer post 9487 & 9486
akbaree is offline   Reply With Quote
Old 14th June 2009, 22:16   #5
nitrous's Avatar
Thanked: 285 Times
Cheapest 30,000 bucks! Abhinavgupta got it at this price.
I believe retail is some 44,000 bucks.
Old 14th June 2009, 23:30   #6
Thanked: 161 Times
Hey thanks for the pointer... but what happens to the amp if it does receive more that its max limit, does it simply clip in the input or does it blow a fuse.. to be more specific what will happen in case of JBL GTO 75.4 ??
Nitrous.. thanks for the price indicators.. will speak to FM Drive tommorrow regarding availability and pricing in Mumbai as of now.
Any suggestions on Comps for the front that will go with this.
Note from the Team-BHP Support Team : Please take the time to use proper punctuation as per Team-BHP rules. Avoid...typing...like...this. Thanks.
Last edited by Technocrat : 16th June 2009 at 13:26. Reason: Please read the note in post, thanks
Old 14th June 2009, 23:33   #7
frankmehta's Avatar
i got mine for around 30k and it costs about 42k in the grey market i guess..
Old 15th June 2009, 00:10   #8
Sam Kapasi's Avatar
Thanked: 1,473 Times
Absolutely nothing. Take my word for it.
Turn the amp all the way down to 6V input and you will be perfectly OK.
Old 15th June 2009, 01:00   #9
Thanked: 161 Times
Thanks Sam..
I am also looking for good Comps to replace my current JBL GTO 607c, but i dont like the highs to be tinny, loud or over powering,... I am not sure if this was how the 607s were or just a problem of tuning the amp ??
Old 15th June 2009, 11:48   #10
panky12345's Avatar
Thanked: 150 Times
jinu, if you find treble on a higher side.. just make use of the eq in your HU and you'll be all set!
Old 15th June 2009, 11:59   #11
Thanked: 161 Times
Well found out that the Eclipse 7200 MKII is available in Mumbai with B&W for Rs. 44k from Preethi Trading company, Mumbai.
I was reading reviews of the 7200 and found the following complaints:
1. Display is very bad. Visibility issues in daylight.
2. Another common complaint is that the HU user interface is very complicated and not easy to use.
3. USB implementation Poor. File/Folder/Album abbreviated to an extent that renders its display useless.
4. No List function to browse thru folder/songs on USB drive
So comments please.. for me most of my listening will be from USB drives.
Also would appreciate suggestion for Comps that would go with this HU
Old 15th June 2009, 12:02   #12
Thanked: 161 Times
I dont know how to explain it.. its not that the treble is high.. its to sharp, tinny.. I have kept treble at 0. If i reduce it, the high frequencies just disappear making the track sound dull.
Old 16th June 2009, 06:52   #13
Bass&Trouble's Avatar
Thanked: 71 Times
The 7200's pre-out level can be trimmed so as to not exceed the amp's sensitivity range.
Old 16th June 2009, 13:12   #14
nitrous's Avatar
Thanked: 285 Times
How to do it, Hermit ji?
Old 16th June 2009, 13:20   #15
DerAlte's Avatar
Thanked: 2,879 Times
Who is this Harmeet now?
Eclipse, Rockford Fosgate or Alpine navin In-Car Entertainment 20 28th July 2006 11:35
mitsubishi eclipse amogh Super-Cars & Imports in India 24 23rd May 2006 19:56
New Mitsubishi Eclipse amit The International Automotive Scene 6 16th January 2005 18:28
mitsubishi eclipse spyder......2 fast 2 furious gTr The International Automotive Scene 6 8th May 2004 15:08
Mitsubishi Eclipse & Plymouth Eagle highwayblaze The International Automotive Scene 4 12th March 2004 18:47
