Old 18th June 2009, 14:05   #1
Default High Level Peak Scratchy Sound. Please Help!!!
Hi Guys
I am hearing High Level Peak Scratchy Sound from newly installed Pioneer DEH 4190 SD. This irritating sound started coming after almost a week, i got it installed.
Basically the sound comes when I play MP3 / WMA / AAC format songs by using SD card or USB pen drive. They worked well (absolute no problem) for a week but then after it started giving scratchy sound.
I reported and got it tested by Autocop India (Authorised Distributor in India) but NO LUCK. They said that it s first time they have faced this problem so solution might time.
Please help if any of you have faced this kinda problem.
-dpk
dpkanj is offline   Reply With Quote
Old 18th June 2009, 14:10   #2
bblost's Avatar
Thanked: 6,663 Times
Remove speakers and visually inspect the magnets for any metal clinging on it.
Old 18th June 2009, 14:38   #3
Are you sure it something to do at Speakers' end??? not at at Source end (Stereo).
Old 18th June 2009, 17:31   #4
chiragh_bir's Avatar
Thanked: 69 Times
check some wiring is shorting some where.. open and check each wiring joints if problem presists then force them to replace head
chiragh_bir is offline   Reply With Quote
Old 20th June 2009, 14:02   #5
valhallen.282's Avatar
Thanked: 141 Times
does the sound come when you play a specific track? or track set? if yes then first check the track on pc on headphones. if track is fine then burn the same tracks to a disk and check if it happens again. if it does not repeat the sound then issue is card reader. if sound repeats check by disconnecting one speaker at a time. if it persists even then then replicate the sound on their test bench and ask for replacement.
if you don't have consistency in reproduction of sound then verify if its also happening in the other sources like cd and radio. if yes please check with installer with a different head. if the sound persists the problem is speaker. thats as simply i can think.
valhallen.282 is online now   Reply With Quote
Old 20th June 2009, 21:03   #6
DerAlte's Avatar
Thanked: 2,876 Times
Does the scratchy sound come while playing FM or CD too? If so, the HU or speakers are at fault. If not, it is the storage or file or looj kaneksan in the HU. You haven't mentioned which speakers you are using and at what volume level this happens. Yes, swapping the HU would also be a good diagnostic step.
Zen pollution level high rohit_dce Technical Stuff 11 4th January 2014 02:22
Amps with high-level inputs VS Line output converters TNAWAYAJ In-Car Entertainment 12 8th November 2013 12:08
PLEASE HELP - Deciding entry level sedan for parents ashwin_seattle Sedans 7 9th December 2009 19:47
Sound Level Meter low_bass_makker In-Car Entertainment 26 2nd July 2007 11:13
scratchy Sachin Surprise Shifting gears 15 13th April 2005 19:58
