Old 29th July 2009, 12:52   #31
shreyasma's Avatar
Thanks for the Link, I will wait for your pictures
shreyasma is offline   Reply With Quote
Old 29th July 2009, 23:05   #32
mohang_j's Avatar
Thanked: 18 Times
Originally Posted by shreyasma View Post
Mohan can you post few pics of the material. I have a new idea after your post
Posting the pics. first two are Armaduct and others are Armasound super silence.
Sheryas let me know what is the idea
mohang_j is offline   Reply With Quote
Old 30th July 2009, 11:26   #33
shreyasma's Avatar
Thanks Mohan for the pictures.
4th pic: Are you taking any amp gut pictures??
What is the thickness of Armaduct and Armasound super silence. However, Armasound looks very thick to me.
Old 30th July 2009, 11:48   #34
mohang_j's Avatar
Thanked: 18 Times
Armaduct is available in 5 and 8mm, Super silence starts from 6mm and what i have is 10mm.
Are you taking any amp gut pictures--sorry i dint understand.
Super silence can be used for floors easily.
Old 30th July 2009, 12:38   #35
shreyasma's Avatar
AmpGuts - Car Amplifier Guts
I was refering to this
Old 30th July 2009, 12:46   #36
mohang_j's Avatar
Thanked: 18 Times
Its my GTA4 in protect mode. Could not spend time to repair and while taking the photo of entire Armasound roll it has come in the scene.
Old 30th July 2009, 16:18   #37
DerAlte's Avatar
Thanked: 2,876 Times
Mohan, take your GTA4 to Bosch service. Ask Mandovi Motors (Wilson Garden) whom to contact. I don't think they will charge anything to set it right.
Old 30th July 2009, 16:31   #38
gigy's Avatar
Thanked: 41 Times
This looks promising. so as soon as i get free let me try my hands on damping too before going to professionals for help. Any link to local suppliers?
gigy is online now   Reply With Quote
Old 30th July 2009, 17:09   #39
mohang_j's Avatar
Thanked: 18 Times
I have already replaced the output transistors, its waiting for replacing driver transistors and i have them already.
Old 9th August 2009, 13:30   #40
shreyasma's Avatar
Mohan, Did you install this in the car yet?
Old 9th August 2009, 17:25   #41
mohang_j's Avatar
Thanked: 18 Times
Not yet Shreyas, material qty what i have may not make noticeable difference i need some more and will take some time for me.
Old 20th September 2009, 14:31   #42
hrsraghav's Avatar
Thanked: 24 Times
Best way is to rebuild the firewall with FRP and damping. Heatlon+Wurth spray on the engine side and DE/NK on the cabin side. If it worked on the noisy '74 Triumph Spitfire it will work on most modern cars.
Sometimes I really wish I had taken pics when I was active in audio. A picture = 1000 words.
My car is in its bare minimum at service staion for repair work.
Whole engine bay empty, seats removed, mats too removed.
Only the roof have the factory fitted fabric.
I am planning to use this opportunity to do the damping.
The engine bay has a Black thick sheet covered by some silevrish metal, I suppose hats for heat shielding. In the inside od car behind the dash board and on overalll floor, a thick green colored fabric is there, which is removed now. Below it there are few patches of some black sheets of rubber.
Please let me know, what all can be done to have a more silent cabin, and as the car is at serice station, so all the work has to be done by me only. I can't take it somewhere else.
Harish Raghav
FIAT Adventure 1.6 Sports
hrsraghav is offline   Reply With Quote
Old 20th September 2009, 14:56   #43
shreyasma's Avatar
Looks like the car has taken a hit. Hope the people travelling are alright.
You can stick some damping sheets on the firewall from indise the the cabin. If you are okay budget wise, then you can stick the sheets completely on the floor, dorrs, firewall pillars to have a dead silent cabin.
Stick foam sheets if you need a VFM option
Old 20th September 2009, 15:20   #44
hrsraghav's Avatar
Thanked: 24 Times
Yuppp people are alright.
My prime concern is to reduce the road noise and engine sound. Palio 1.6 is a bit noisy engine.
Also as there is already a firewall installed at the dashboard side of engine bay. So do i need something more for Heat shielding, or is it enough.
And coming to Sound damping, few patches of some rubber sheets are already installed, so should i put the new sheets on just above them or I have to remove the earlier ones.
I am planning to spend mot more then 5-6 K and will keep the car atleast for 3-4 years, so the material have to be long lasting.
I enquired about Dynamat sheets, they are 1600 per sheet of size 1 feet by 1 feet. I think I have to look for other options.
Kindly suggest some other brands.
Harish Kumar Raghav
Old 23rd September 2009, 10:54   #45
shreyasma's Avatar
Buy noiske kill. Its about 140 per sqft (Can be procured from Bass&Trouble)
Stick it on the firewall metal directly behind the green mat. For the floor, doors etc, stick directly on the sheets that are there as an additional layer. Heat shielding is not required as its already provided.
Dynamat is an expensive option.
Building a Racing Seat ? (out of carbonfire / fibreglass) Rehaan Shifting gears 22 30th October 2015 13:18
Damping Safari 2.2 - My Experiments with in-cabin Noise/ Vibration Reduction Ishlesh In-Car Entertainment 13 9th February 2011 15:47
Punto - Fibreglass A Pillar for Speakers Crimson In-Car Entertainment 11 18th September 2010 00:41
FibreGlass Raw material in Pune? Crimson In-Car Entertainment 5 5th September 2010 22:18
Found- Fibreglass sheets retailer in Hyd absynthguzzler In-Car Entertainment 20 30th December 2008 18:41
