Old 16th September 2009, 14:55   #256
Invinsible's Avatar
Thanked: 60 Times
Originally Posted by santosh.s View Post
A basic question, Invinsible- Are standing waves withing the box a real concern for a subwoofer? I mean aren't box dimensions much smaller than wavelengths?
Well it doesn't matter whether the enclosure size is big or small. If a sinusoidal travelling plane wave falls normally on a plane, totally reflecting surface, the incident and reflective waves will combine to produce standing plan wave.
The way I see it the amount of standing waves are present as per the shape and size of the box. In a sealed enclosure, the air inside acts as a spring to the woofer. With the reflective side wall standing waves could be uneven in the process make the sound more muddy. Standing waves, resonance and diffraction has always been an issue for almost every major Audio company. Standing waves could be higher is spherical enclosure compared to the usual rectangular enclosure but again the spherical enclosure offers better dispersion and reduces the diffraction that is caused by the edges of the enclosure. Incase of the FG enclosure the resonance would be much higher than the wooden enclosure. One reason is the density and the damping factor of using the wood/MDF if higher whereas the stiffness of the FG enclosure is higher. Damping can be used to cut down the resonance in an enclosure irrespective of the size and reduce the standing wave as much as possible in order to produce the bass as it was intended to listen too. The real benefit of this can be seen when subs are crossed higher than 60-80hz but not that it wouldn't be of use below that level. Various damping materials are found in form sheets, sprays, acoustical foams, deflex pads, fiberfill, polyfil, wool, many of them when used in conjunction can greatly help.
Here's the links to some of the different material used in cabinets or sub enclosure.
Parts-Express.com - Acoustic Noise Control: Audio Sound Dampening, Foam Baffles, Cabinet Dampening Material, Car Audio Noise Control
DynaXorb
ORCA Design & Manufacturing
Dampers: Deflex Sub Panel from Madisound
Some may believe or some may not. But from possessing my 1st sub in a car that was 15 years back until now. I have noticed that with some sort of filling in an enclosure does help the bass to sound a wee bit cleaner. Here's one of the article I have which would help in understanding it better. (sorry for the long post)
In answer to the question "does the shape of the cabinet matter" Yes it can matter a great deal, if you know enough to use it to your advantage - or you can just keep stuffing those boxes full of peanuts, fiber fill, black hole, or whatever the latest and greatest whiz-bang stuff the car audio store is trying to sell this week.
First you need to know a wee bit about what goes on in an undamped resonant space (your sub cabinet or any finite baffle transducer cavity.)
Of course, you are aware that the acoustical power of your bass transducer compresses and rarifies the air in your vicinity (including your eardrums and the neighbor's too, along with his windows and furniture and so forth) If you think about it, it also compresses and rarifies the air inside the sub box, right? Yes, but that's NOT all that's going on in there. There is another neat little gremlin in the box called "resonance". Now, resonance is word derived from Herman Von Helmholtz's coined term -"resonator"...Its' taken from his work "On the Sensation of Tone", which is the definitive work on the topic for almost a hundred years, by the way. You might check it out, but be warned that it is pretty tough sledding.
Anyway, to understand reasonance on the cheap, here's an easy illustration. Ever blow on a bottle of your favorite beverage and make it whistle? THAT'S a resonator. We engineers still sometimes call them "Helmholtz resonators". Guess what, transducers in finite space cabinets do about the same thing and that resonance is related both to cabinet volume AND shape. (negating the internal resonances of the materials themselves - which, compared to cabinet surface resonances and volume resonance, are puny variables.) With all due respect to the other posts here, within reasonable limits, the wall-material is the MINOR factor in cabinet resonance, compared to the acoustical albedo of the internal surfaces at their resonant peak frequencies. Sorry guys...that's just the way it is in acoustical engineering world where the real heavy lifting related to the audio sciences gets done. Yes, I know-your megadon 1500 made out of andalusian spruce sounds "awesome", yes, I know you made a sub out of eleven layers of marble and it was divine...yes yes YES! I've heard it all before. Hate to break it to you, but the resonance of your andalusian spruce is called a sympathetic secondary resonance. It induced by the energy of the primary resonance of the fundamental resonant peak of the cavity contained by said spruce! No primary? no sympathetic. So...
Now back to reality - the resonance of any rigid finite baffle sealed cabinet is primarily and overwhelmingly determined by the internal dimensions of the reflective surfaces as they sympathetically resonate at the frequency represented by that dimension (or that frequency's partial.)
Resonance inside boxes with parallel surfaces is just an acoustical fact of life. So...ready to go outside the stupid zone, where everyone stuffs the sub cabinet full of turkey feathers? Ready to stop doing just like the kid who flunked out of math and now works at the stereo store tells you? Ready to apply your brain plus hard acoustical science? Have you chosen?
Great! Let's explore! First the principles -
Just for fun, let's imagine a 12" square cabinet, with a 10" transducer - built from say...MDF. No ports, no stuffing, just a transducer and a box. Let's say you've actually read the spec sheet and see that the transducer is rated at 88db efficiency 1watt/1meter. So, what do you suppose will happen when I put 1 watt worth of white noise power into our 1 foot cube sub? Why out will come something like 88db of white noise conforming to the performance curve of the transducer as the spec sheet rates it, right?
If you think so, then you don't understand resonance. You see, transducer is exciting air inside a 1 foot cube which has an internal fundamental resonance of 644 Hz. Each pair of resonant surfaces (top-bottom, side-side and to a lesser extent, front-back) will resonate at a particular frequency, in this case, 644Hz. Why? because parallel reflective surfaces bounce the acoustical energy back and forth between them...but not all the energy, a resonant cavity will re-concentrate a portion of all available energy at the acoustical wavelength that is best represented by the distance between those two parallel reflective surfaces! (plus, in descending order of efficiency, the harmonics) Are you starting to get it? Do you see how the idea that the shape of a sub cabinet (or any cabinet) can make a HUGE difference in the sound makes sense? Great, you're getting somewhere.
So returning to the foot-cube-sub...that 1watt of white noise in our 12x12x12 cabinet will have what we engineers call an emphasis peak at 644 Hz. That emphasis peak is generated (at the expense of energy stolen from other frequencies - there is no free ride) by the acoustical coupling of the transducer's output to the resonant peak of the cabinet.
So your sub is hotter than a pepper - at 644 Hz. Not exactly earth shaking...644 HZ is about the fundamental frequency of the second mounted tom on a drum kit. But at least you're not wasting that energy as heat with your horse feather stuffing!
Now, armed with your basic knowlege, let's imagine you get very ambitious and decide to make another sub cabinet. This one is bigger though. It is 36 inches on a side! Put the same signal at the same power through the same 10" transducer and you will now see a resonant bump of 12 db at 196 Hz. Why? Because the resonance of a 36 inch cavity is 196Hz. Ah...that resonance again!
If you made it twice again as big - 72 inches, can you guess what the resonant frequency will be? Multiple choice
1.) 19.6 Hz
2.) 12,000 Hz
3.) about 90 Hz
If you chose 3.) congratulations, you're learning.
You may notice that the calculated resonant frequency has roughly halved, though it is shifted upwards slightly. Why? As the cabinet gets larger, the relative displacment of the transducer motor itself becomes less significant, causing a slight shift up towards absolute values in the resonance. (the transducer motor is a smaller percentage of the total affected volume)
Now, let's make a sub 144 inches...wait, that's bigger than my car. So what gives? How do those guys get those gut thumping lows out of cabinets that fit in cars (sort of fit, anyway) For that matter, how come my semi-cheap little 18 inch square sub in a cube can still thump my car. That sure isn't 600 and something Hz I'm hearing, is it?
You are right, and there is a simple reason. While your little 18" square sub WANTS to resonate at 410Hz the sub builder stuffed it full of horse hair or fiber fill or whatever the heck they thought was best or found was cheapest that day...and that stuffing is absorbing the 410 Hz resonant energy and turning it into heat. (second law of thermodynamics) Since shorter wavelengths are more prone to absorption than long ones, the energy resonant at 410 Hz is wasted more efficiently by the stuffing than it's first sub-harmonic. See, there is what we call a lower partial at 205 Hz, and another one at 102.5 Hz, and yet another one at 51.25 Hz, and so forth, each is less affected by the absorption, though of course, each lower partial is down 3 db in acoustical power compared to the the one right above it, because each wave is progressively less of the total acoustical energy. Do you see why? The 18 inch resonant cavity can contain one 410 Hz wave, but only 1/2 of one 205 Hz wave, and only 1/4 of a 102.5 wave, and so forth. The total energy is therfore reduced proprtionally.
So your little sub box can sort of make thumps...but are you starting to understand why people sell you 1000 watt amps to get that low bass thumping? It is the stereo shoppe's version of Dr. Seuss's Star Bellied Sneeches. Wrong shaped, cheap to build boxes stuffed full of power robbing horse feathers or whatever need MORE AMPS... and who's going to sell you those amps? Why your friendly neighborhood stereo sneech!
Ports - We're not going to talk about ports here - except to say that ports are nothing more than resonators. Just like the hole in the top of your favorite beverage bottle is a port. Same principles apply. Ports are wonderful high-Q (narrow bandwidth = high Q) resonators, and I'm going to presume that you can do the math to get there on the port part of the design I'm about to hint at.
Yes, there is a better way (TRUMPET FANFARE)- but it requires some for-real engineering. I mean the kind you fell asleep for during geometry and physics class. It requires that you understand acoustics a bit, plus have some math skills, patience with carpentry, and the guts to go against the parking lot wisdom of the ignorant masses. You will have to go out and find the resources. They're out there - Theile and Small's work on resonances is still a standard work. Helmholtz is good background too. There are plenty of resonance calculators for free on the web, too. A college physics book and your little sister's t/i 83 calculator can come in handy as well.
O.K. I'm not going to do all the work for you, but here are the critical hints...
Imagine two surfaces that are parallel on only one axis. Think of a "V". Can you visualize that these two surfaces are in fact a wide-band resonant cavity? Each single axis parallel surface represents a small amount of opportunity for resonant coupling, expressed over a range of dimensions that create a "bandwidth resonator". Got it? If one end of the V resonates at 400 Hz (and 200 and 100 and 50, in partials) then the other larger end might resonate at 500 Hz (and 250 and 125 and 62.5) are you starting to get it. Use this design reality to your advantage to TUNE your sub cabinet to deliberately resonate at the partials of the desired efficiencies.
1. determine the desired bandwidth performance of your sub cabinet. Be realistic. Determine the bandwidth of the low frequency spectrum of the music to which you listen. (this is for music, right? not noise and bragging rights in the parking lot wars...right?) Do NOT get into an idiotic contest over how low can you go. Kick drums are NOT 5 Hz, o.k? A five string electric bass' lowest note is 30 Hz. BE REALISTIC.
2. Now build your bass cab around an entire set of strictly one-axis asymetrical surfaces which dimensionally represent the range of desired resonances. (or their first subharmonic partials - if you want it to fit in your vehicle). You'll have to do some figuring to determine these exactly. DO NOT ALLOW ANY TWO AXIS PARALLEL SURFACES.
3. Build, brace, seal and wire but DO NOT DAMP THE CABINET (yet)
Now install your transducer in your asymetrical cabinet, put your cabinet in your car, and carefully and slowly sweep the cabinet with a calibrated sweep sine wave. You'll find that the cabinet is now capable of producing vastly more acoustical output in the desired frequency range than exactly the same transducer / amplifier combination that is suffering from the stuff it like a Christmas turkey syndrome that they recommended at the stereo shop. As you sweep the performance bandwidth, you'll note the out-of bandwidth frequencies that still jump out at your ears. Don't fret - these are the frequencies that require still require what we call "critical damping". We'll get there, but DON'T damp yet. Now, do your Theile/Small parameter calculations and install a properly calculated port. Leave it movable, for by-ear tuning adjustments...don't just cement it in at the recommended dimension. Even the best calculators don't have adequate input from you to account for every brace, the vagarities of transducer dimensions, etc.
NOW, sweep it again - See how your port has changed the swept efficiencies of the various frequencies? fine tune the port to the desired primary LF resonant point. (the window thump point, for your brainless types :-)
No, DON'T GLUE IT YET!
Now, noting the swept frequencies you wrote down (you did write them down, right?) and those undesired upper resonances (the ones above your design's preferred bandwith output) calculate, build, and install inside your cabinet parallel absorptive surfaces placed at those precise dimensions which will absorb that resonance and only that resonance. Clever designers with multiple resonance issues may be able to use both sides of an internal damper plate and place a single damper at the distance representative of the two critical frequencies. These dampers will be free-standing flat surfaces with highly absorptive surfaces. They'll representing a percentage of your total cabinent interior surface area which remains undamped. These tuned dampers will absorb the stray resonances (and ONLY the stray resonances, without wasting acoustical power by the stuff the turkey method the stereo shoppe wants you to use so they can sell you some more amplifiers, and wire and terminals and really cool neon glow tubes, etc.) Congratulations - you now have a critically damped subwoofer cabinet.
Listen again. You should be close to happy. You may still need to install a small amount of additional damping, to make up for the corners you cut in your cyphering. Remember non-critically applied damping wastes power! Avoid it.
Properly executed, this method can produce 9-12 db gains in the desired performance range...all other things being equal, without a single watt of additional electrical power. Remember 6db is a doubling of acoustical power! Put that in perspective, 6db of gain requires a ten-fold increase in electrical power. Does the work on a critically damped sub cabinet sound more appealing now? Imagine how much more thunder you can make with a tuned-resonant critically-damped cabinet!
Science is fun!
Invinsible is offline   Reply With Quote
Old 16th September 2009, 15:35   #257
shajufx's Avatar
Thanked: 491 Times
Ufff, reminds me of my college days I used to bunk the literature classes ! Even if I attended, I would be snoring on the back benches. Sorry for being sincere !
shajufx is offline   Reply With Quote
Old 16th September 2009, 15:53   #258
frankmehta's Avatar
Thanked: 2,334 Times
Hahahah. Shaju is the new sit down (and type) comedian in our ranks ;-)
Old 16th September 2009, 15:54   #259
Invinsible's Avatar
Thanked: 60 Times
Snoring on a bench was still good, but what about snoring sitting back home
Old 16th September 2009, 16:11   #260
shajufx's Avatar
Thanked: 491 Times
LOL, but the information is very well written though. I dont get any head or tail out of that stuff. When its time for me to install an amp and sub in my Fiesta, I would walk-into an audio shop and ask "one amp and sub please" ! Deal is over, pay the money and enjoy the DINCHAK all the way ! Doesnt that sound simpler ?
Franky, I never knew your 'tree' has become so famous throughout India ! I read a comment on your facebook yesterday "please take your tree outside your house and shake it well". I was almost vomiting blood out of the 'laughter in its extreme' stage of mine. It has come to a stage, I remember YOU whenever I look at a tree full of leaves !
Eagerly awaiting the final installation !
Old 16th September 2009, 16:19   #261
Invinsible's Avatar
Thanked: 60 Times
Surely but what makes the money well worth while, is taking care of some tit-bits.
It's always better to wrap the gift up and present, makes it look presentable, in this case it would make it sound delicious
Old 16th September 2009, 19:58   #262
frankmehta's Avatar
i would love to be the owner of that store. I would stick NICE sony exploding stuff, and make a living out of your 'deal.'
The freakin tree is shaken bare, leave the poor plant alone.
It's now time to plant saplings for the new, larger tree.
When do you plan to ICE your car, shaju? I will surely 'assist' you in getting good (ahem) deals on it
Kyunki picture ABHI bhi baaki hai. LOL. I just wanted to say this. Actually, the install is almost complete.
Today saw the carpeted sub woofer enclosure (sorry abhishek, no alcantara this time) and an amp rack being built and carpeted.
I am not a fan of those racks that cover the amp in its entirety, or expose the internals of the amplifer. I like it simple and plain. So my amp 'rack' will be a wooden plank installed in a strategic location, showing off the stuff that is actually meant to be shown off. And that is the amps, in all their glory.
Both amps looks smashing when kept next to each other, and the similar build and choice of materials work in making the duo look like distant cousins.
The subwoofer enclosure looks small when fitted (flush into the right side), but is larger than 1.2 cu ft. And that is awesome news. My only worry now, is whether the 1300W + JBL W12GTi + poor Fiesta boot+ even poorer FG enclosure will be a good combination. You know what I mean. The sub might just tear the enclosure apart.
I know. It's the installation that matters. you can make a 1 lac rupee system sound like CRAP if not installed/tuned well.
And you can make a 30 k system sound BETTER than many lac rupee systems if tuned well.
In my case, its touched over 200 RED ones.
And Ajay Kamath (God) is doing the installation and tuning.
Let's see how this effort pays off.
I know for a fact that this is going to be special. HOW special, now only time can tell.
Old 16th September 2009, 20:06   #263
Invinsible's Avatar
Thanked: 60 Times
Good to know Franky waiting for the final pics and auditon before and after break in period which is gonna be another difficult time to pass it by.
Old 16th September 2009, 20:42   #264
frankmehta's Avatar
Break in.. Hmmm. I will be playing the SAME music when it breaks in too.
So there's not much of a wait to be observed. Yes, the levels will have to be kept down.
But it's ok. I shall enjoy it nonetheless!
Old 16th September 2009, 21:27   #265
shajufx's Avatar
Thanked: 491 Times
Originally Posted by frankmehta View Post
When do you plan to ICE your car, shaju? I will surely 'assist' you in getting good (ahem) deals on it .
You will be the first one to be consulted when the time comes, I promise. I am learning a lot from your thread for sure. Thanks for all the infos.
Wow, thats another info for me. Seriously there is a break-in period for the ICE ? Hope you guys are not pulling each others' leg ! If its true, is it based on the number of hours some knobs have to be in control ?
Old 16th September 2009, 23:09   #266
frankmehta's Avatar
my pleasure shaju
now there is a long thread and loong discussion on break in. It's a debated topic. Many believe that breaking in of speakers 'opens' them up and gives one more output. Many take it as a teaspoon of horse urine, and just get on with their setup.
Either way, there is some psycho acoustics involved, and it's hard to tell which speakers require break-in, and which do not.
Hell, even car amps need breaking in (so people think)!
I am of the opinion that breaking in does better for the longevity of the speaker (since its made from moving parts,that need to be slightly run in before playing to their full potential, with the least wear) than it actually does for quality.
Some amount of psychosis was present when one day, after using my luccents for a month, suddenly, I felt that the midbass was more pronounced than before. Must have broken in gradually OR, I was in a good mood that day, and i enjoyed my music more!
After that day, I had nothing to compare the sound to. My mind might have led me to think that I was listening to something 'better.'
So, take break-in as you want it. Some companies DO say that it's good to break in your speakers before using them to their highest potential.
Old 17th September 2009, 00:35   #267
nitinralli's Avatar
Thanked: 798 Times
PIC'S please franky bhai.
nitinralli is offline   Reply With Quote
Old 17th September 2009, 20:16   #268
frankmehta's Avatar
The install has now gathered some pace.
The following things have been completed.
1. Damping of front doors and Boot. Woofers have been fitted on to the doors. Look at the neat fit and finish, the (included) trim ring with the speakers helps achieve!
2. Sub woofer enclosure (fibre glass) carpeted and ready.
3. Amp Rack has been made. Carpeting still remains.
4. RCA cables have been passed on the right hand side of the car. Power cables (left side) remain.
5. Head unit removed from the stock position (had to go to Shaman for that, and they have removed the head unit with the special key that is available at the dealer end. One of the 4 locks was stuck, and a screwdriver used to pry the lock open slightly spoilt the cheap plastic on the bezel edge. Nothing too significant, but a shame since the entire install is going to look stock and unintrusive.)
6. Wiring harness fitted and RCA's passed behind head unit console. Head unit itself needs to fitted onto the dash kit and connections will be done soon.
7. 150 A fuse and 35 sq mm. Polycab wiring for the MONO procured, and will be using LBM's fuse holder for the fuse(thank you once again, sir)
8. Tweeter pods remain. Will work out the tweeter position first, and then have them made.
Pictures now. A lot of them!
ICE frankmehta's Fiesta: All Equipment Finalized-p1020770-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020771-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020772-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020773-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020774-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020767-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020768-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020769-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020777-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020786-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020775-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020787-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020792-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020795-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020798-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020799-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020800-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020803-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020804-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020813-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020805-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020806-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020808-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020809-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020814-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020816-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020817-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020820-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020832-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020834-desktop-resolution.jpg
Old 17th September 2009, 20:21   #269
frankmehta's Avatar
some more photos of the speaker in the door, and the battery and alternator
ICE frankmehta's Fiesta: All Equipment Finalized-p1020822-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020823-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020824-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020825-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020826-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020827-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020828-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020829-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020830-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020841-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020842-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020843-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020845-desktop-resolution.jpg
ICE frankmehta's Fiesta: All Equipment Finalized-p1020846-desktop-resolution.jpg
Old 17th September 2009, 23:44   #270
Invinsible's Avatar
Thanked: 60 Times
Way to go Frank. I like the way the midbass is installed, looks completely stock fitment. Also, the sub enclosure looks really neat. When will the system be fired up ?
One suggestion, you could try to do some carpeting on the boot lid too, may be use a black carpet. Can hide all the aluminium look of the noisekill.
Finalized Audio for Swift VDi Prabhu In-Car Entertainment 4 16th August 2009 13:08
A-star or Spark? EDIT - Finalized Spark ritz830 Hatchbacks 67 18th July 2009 09:17
spark or palio for 3.3 lakhs? Edit - Finalized Spark ritz830 Hatchbacks 37 13th December 2008 16:12
Finalized Swift: How useful are Rear Sensors? lambuhere1 Hatchbacks 3 12th July 2007 22:46
