Old 27th August 2009, 01:21   #61
abhinav.gupta88's Avatar
Thanked: 310 Times
I get it. Congrats Frank.
Waiting for your complete installation plus ice pics.
Old 27th August 2009, 02:42   #62
Invinsible's Avatar
Thanked: 60 Times
Can't wait to see things going. I would also add a 2 farad cap along with those amps, enough reserve power juice for those amps.
Invinsible is offline   Reply With Quote
Old 27th August 2009, 07:22   #63
Thanked: 13 Times
Let go of your lover Lucy did you??
Lots of XXX in here, things going to get dirty or what
Old 27th August 2009, 11:09   #64
frankmehta's Avatar
Thanked: 2,334 Times
Thanks guys. I dunno about the cap. Will I need one? Its just 2 amps. Both are efficient. The mono is more efficient than even a class d one.
frankmehta is online now   Reply With Quote
Old 27th August 2009, 11:39   #65
Invinsible's Avatar
Thanked: 60 Times
Frank it's not about just 2 amps it's the amount of current they would need or take up. With total of 1500W those 2 amps will be throwing out, its not that there will be an issue without cap, but I say why not have for that power surge and since you already have such a great system shaping up, why not add one..just incase. It's like what would happen if no sound damping material used at all, not that drivers need damping for them to play, but we all know how much it could help.
Old 27th August 2009, 17:13   #66
frankmehta's Avatar
I did a little research. A cap is not needed for this system. I will add one if the current draw from the battery is too high.
Old 27th August 2009, 17:54   #67
Thanked: 310 Times
There's no need for it frank.
The car is new.
even i was drawing 300 off watts from the 4 channel and around 1500 watts off the jbl mono initially without a cap.
Old 27th August 2009, 19:21   #68
Thanked: 294 Times
No need for cap....I am running a (2400 + 300 + 240) watts rms setup..no issues faced till now.
Old 27th August 2009, 20:22   #69
frankmehta's Avatar
LBM, have you upgraded any of the BIG 3?
Old 27th August 2009, 21:15   #70
Thanked: 310 Times
I had done BIG 2 Upgrade.
You can go for that.
Old 28th August 2009, 00:22   #71
frankmehta's Avatar
Alright fine. My components have been ordered. Most probably shipped from Amazon to the venue from where, delivery will happen to India.
Cheers!
Old 28th August 2009, 10:16   #72
Thanked: 294 Times
I have done the big 2, that is battery to chassis and engine to chassis. Not done the alternator to the battery. And would recommend you not to get it done because it will void warranty in your case as you will be tampering the alternator wiring.
Old 28th August 2009, 10:24   #73
frankmehta's Avatar
Thanks. The big 2 is anyways mandatory since we are adding 2 amplifiers that have a current draw of about 100A at any given time.
Not touching the Alternator wire for now!
Old 28th August 2009, 13:03   #74
Thanked: 39 Times
Frank, which components? DLS Reference?
greenh0rn is offline   Reply With Quote
Old 28th August 2009, 13:14   #75
frankmehta's Avatar
Nope. Dls reference I've not heard. Heard the iridium and didn't like them much.
Finalized Audio for Swift VDi Prabhu In-Car Entertainment 4 16th August 2009 13:08
A-star or Spark? EDIT - Finalized Spark ritz830 Hatchbacks 67 18th July 2009 09:17
spark or palio for 3.3 lakhs? Edit - Finalized Spark ritz830 Hatchbacks 37 13th December 2008 16:12
Finalized Swift: How useful are Rear Sensors? lambuhere1 Hatchbacks 3 12th July 2007 22:46
