Old 28th August 2009, 13:29   #76
Thanked: 39 Times
Can i keep the gassing game on? Pioneer Premier? JL Audio Evolution ZR?
greenh0rn is offline   Reply With Quote
Old 28th August 2009, 13:36   #77
Thanked: 294 Times
Originally Posted by frankmehta View Post
Thanks. The big 2 is anyways mandatory since we are adding 2 amplifiers that have a current draw of about 100A at any given time.
Not touching the Alternator wire for now!
The average current draw would be quite less. The peaks will be 100 amps.
Old 28th August 2009, 13:48   #78
DerAlte's Avatar
Thanked: 2,876 Times
Originally Posted by greenh0rn View Post
Can i keep the gassing game on? ...
Is it already winter in Delhi???
Old 28th August 2009, 14:40   #79
Thanked: 39 Times
Agreed such games produce a lot of hot air, but Delhi winters don't get cold like it used to be any more :(
Old 28th August 2009, 20:01   #80
nitinralli's Avatar
Thanked: 634 Times
Oh i think its Sony Explode series. Right Frank
nitinralli is offline   Reply With Quote
Old 28th August 2009, 20:42   #81
abhinav.gupta88's Avatar
Thanked: 308 Times
No, He's getting Hollywood Speakers.
Best
Old 28th August 2009, 20:54   #82
jkdas's Avatar
Thanked: 1,389 Times
Originally Posted by low_bass_makker View Post
No need for cap....I am running a (2400 + 300 + 240) watts rms setup..no issues faced till now.
What would be the I value of these in total if used to max?
Old 28th August 2009, 22:55   #83
mohitd's Avatar
Hey Frank why dont you go for these CS 360.30 Reference - Rainbow Reference 6.9" 3-Way System
mohitd is offline   Reply With Quote
Old 28th August 2009, 23:05   #84
DerAlte's Avatar
Numerically, from LBM's figures it is, at 12V, 200 + 15 + 20 = 235A + (thermal factor). But, practically one can never reach that current since those currents can be reached only by feeding pure sine wave, that also at a frequency that would consume the largest current (frequency dependent impedance). In actual usage, the signal is a random mix of sinusoids, many of which consume very less current even at peak.
Old 29th August 2009, 00:45   #85
frankmehta's Avatar
Thanked: 2,231 Times
Pioneer Premier. Hmmm. VERY good guess. I was a few inches close to pulling the plug on the TS-C720PRS. It's one of the BEST component sets ever made. But the tweeter was a slightly weaker link, and the Xover was rated @ 50w. I needed 2 more channels to go active OR I would have to make do with the measly crossover.
JL? Naah. Too expensive.
Great GAS nonetheless!!
One amp does 1551*1 and the other does 120*2. Also, the Clarion Mono DOESNT COME WITH INBUILT FUSES. Amazingly, one has to use a 200A () inline fuse to do the job.
Sony Xplod series xploded in my car about 7 years back. I am going to make sure there is NEVER an xplosion ever again!
Best
More like speakers FROM hollywood!
What would be the current draw from MY amps, if the above given figures are taken for the calculation.
Originally Posted by mohitd View Post
That's it? Only $10000?
I have a budget of 10000 rupees, not dollars!!!!!!!1
Cheers. Great explanation!!!!!!
Old 29th August 2009, 14:22   #86
frankmehta's Avatar
Let the games begin.
100W RMS
Old 29th August 2009, 15:01   #87
DjNik's Avatar
Are they rockford compos by any chance???
DjNik is offline   Reply With Quote
Old 29th August 2009, 17:51   #88
frankmehta's Avatar
No mate. Not Rockford fosgate
One more clue:
2 Way Component system
Old 29th August 2009, 19:18   #89
Thanked: 308 Times
Haha.
Can i play the Game too
Old 29th August 2009, 19:38   #90
Thanked: 294 Times
Hmm..it would be this one...
The Image Dynamics Store, The BEST Way To Buy Image Dynamics Car Audio! - Image Dynamics High-end car loudspeakers and signal processors, CTX5X7 - Image Dynamics 5"x7" Coaxial System with Titanium Tweeters, CTX4 - Image Dynamics 4" Coaxial System wit
RMS Power Handling: 100 Watts
Peak Power Handling: 200 Watts
Frequency Response: +/- 3 db 58hz-22khz
Efficiency @ 2.83 volts: 93dB
Impedance: 4 Ohms
Mounting Depth: 2.75
Poly-mica cone with butyl rubber surround
1" (25mm) silk dome tweeter with neodymium magnet and swivel eyeball mount
Crossover made with audiophile components utilizing air-core inductors and poly film capacitors
Finalized Audio for Swift VDi Prabhu In-Car Entertainment 4 16th August 2009 13:08
A-star or Spark? EDIT - Finalized Spark ritz830 Hatchbacks 67 18th July 2009 09:17
spark or palio for 3.3 lakhs? Edit - Finalized Spark ritz830 Hatchbacks 37 13th December 2008 16:12
Finalized Swift: How useful are Rear Sensors? lambuhere1 Hatchbacks 3 12th July 2007 22:46
