Old 31st July 2009, 18:29   #1
Ritzman's Avatar
Default Need help for my Ritz ICE set-up
Hi Gyanis,
I'm planning for an ICE for my baby, Ritz VXi. After going through the treads I've decided on the following set-up. Since I'm not going for any amp at this moment, I would like to know you input on my choices with price.
HU - Pioneer DEH-P5150UB - 7.5k w/o B&W
HU - Pioneer FH-P6050UB - 8.6kw/o B&W
Still undecided on the above
Front components - JBL GTO608c - 4.8k with B&W
Rear Oval - JBL GTO947 - 4.2k - with B&W
Plank, spacer & harness - 1.2k
Few of my friends say I should go for JBL GT5-S265C as 608c works better only with an amp since it has got only 2 Ohms impedance (S265c is 4 Ohms). Is it true?
Can I go ahead with the above set-up? Or which is the best for a budget of 20k.
Looking forward to your valuable guidance.
Thanks,
PS: I've dropped the idea of purchasing Xenos XCT-RAU-100 which I had posted earlier. Thanks for the help.
Ritzman is offline   Reply With Quote
Old 31st July 2009, 20:08   #2
shreyasma's Avatar
See the below threads for info.
http://www.team-bhp.com/forum/ask-gu...-ice-ritz.html
http://www.team-bhp.com/forum/ask-gu...eing-ritz.html
shreyasma is offline   Reply With Quote
Old 31st July 2009, 22:34   #3
abhinav.gupta88's Avatar
Thanked: 310 Times
Originally Posted by Ritzman View Post
Hi Gyanis,
If you are self driven , you can have a better setup than this.
HU - 5150UB 7.5k as mentioned by you.
Fronts - JBL 608c - 4.8k.
4 Channel amp Blaupunkt GT4-MKII Amp - 5.5k.
Wiring + Harness + Install 2k.
You can add to this a sub later. This will be louder.
The JBLs will play to the potential and you can add a sub later ( JBL / Pioneer) - 3k.
Its better to avoid rears if self driven.
Maruti Ritz: My wheel & tyre upgrades - settled down after 4th set of rims PSM_360 Tyre & Alloy wheel Section 18 21st September 2015 20:35
ICE Set-up for a Punto Emotion Pack : Need gyan on right speakers aqualeo2040 In-Car Entertainment 15 6th July 2010 13:30
Ritz ICE - Need to change components, please suggest a brand lucksin In-Car Entertainment 12 17th April 2010 14:48
Need help with ICE for Ritz Kannan In-Car Entertainment 18 15th January 2010 14:52
