Old 3rd July 2005, 12:02   #16
srasania's Avatar
more into hindi and hip hop music..tend to push up the volume 50% of the time when i'm alone and ,not travelling with family members.
Also,wanted good music,so, front components are must.
I read on the Speakers FAQs thread on caraudio.com that components work best out with amps ,so, 4 channel amp for sure too..i tend to keep the treble at around 70% of max on head unit,and bass at about 50% of max of head unit..so,don't know whether to go in for sub...infact,i don't very high bass..
as for rear - im confused about components/co axials,and 2 or 3 way.
as for rs40000 budget(my dad just gave me the figure yesterday) which brands components can i consider?..I am planning to spend max Rs15,000 on a head unit,and Rs25,000 on everything else needed..
Suraj
srasania is offline   Reply With Quote
Old 3rd July 2005, 12:09   #17
iceman91's Avatar
Thanked: 22 Times
you can get a good setup for that price.
look at front components and rear tri-axials. can throw in a sub too
iceman91 is offline   Reply With Quote
Old 3rd July 2005, 12:11   #18
srasania's Avatar
iceman - which brands for components/amp can i consider?
Suraj
Old 3rd July 2005, 12:15   #19
iceman91's Avatar
Thanked: 22 Times
amp you can go in for sony,alpine,rockford
components go in for boston,focal or rockford
Old 3rd July 2005, 12:32   #20
srasania's Avatar
thanks navin,,icman,rjk and ajmat for the help .. will surely post if anything more i need to know about the audio setup..
suraj
Old 3rd July 2005, 20:44   #21
srasania's Avatar
hey guys..just wanted to know - if 2 sets of components are fitted in,is it necessary that both front and rear components should be of same RMS/Peak power??..or should the rear components be a bit better in RMS/peak power as compared to front components?..or vice versa?
Thanks,
Suraj
Old 3rd July 2005, 20:53   #22
iceman91's Avatar
Thanked: 22 Times
no not necessary if you are keen on front emphasis f=go in for good fronts andreare can be fill ins for this even a tri-axial will do.
Old 4th July 2005, 10:30   #23
navin's Avatar
Thanked: 4,349 Times
HU: 4V out, Subwoofer out with controls. Alpine 9830-9831-9833 and if you afford it Nak 500 would be my choice others prefer the Pio premier line and Sony.
Front: 6" components (ADS, Boston, Focal) or if you cant spend that much Alpine, JBL or Blau (I prefered Alpine over the other 2) have not heard Kicker, Soundsteam, MTX etc.
Amp: a good 4 channel amp (I'd look at Alpine or Blau's Velocity) but even a basic 4 channel amp like Sony's 504 (rs. 5000) will help
Sub: Active sub. Try a single 10" from brands like Kicker, MTX, etc.. they have been making subs since the 80s. if you cannot afford the space for a 10" box then try multiple smaller subs (I get by by tucking 2 smaller subs in the crevices of my trunk).
Rear: here you have 3 options
a) coax. if you cannot afford the subs at all I'd recoomend 6x9" like the Pio 6990 or Alpine 690A (again I prefer the Alpine) a 6x9 will require some metal cutting but void any guarntee.
b) 5-6" components with a sub.
c) stock speakers (if you are on a budget) you can always add these later.
In short. in ROUGH order of importance.
1. HU
2. Front speakers
3. Amp
4. sub
5. rear speakers.
2 way or a 3 way component system akbaree In-Car Entertainment 36 16th September 2008 13:26
Front component system for ALTO monty9991 In-Car Entertainment 20 26th August 2008 19:03
4-channel Soundstream Amp For Sale & MB Quart Q-Line 6.5" Component System QSD216 Bass&Trouble Shifting gears 7 19th March 2008 09:27
Component System for Esteem Flintstones In-Car Entertainment 7 5th February 2008 13:13
Component System for 10K amit_sound In-Car Entertainment 24 17th November 2007 15:50
