Old 8th August 2009, 15:42   #31
frankmehta's Avatar
Thanked: 2,334 Times
cant even get the Gz Hydrogen. 2*2 Ohms, which means I will utilize only 350W RMS.
Here is the thing:
1. Gz Hydrogen: Out
2. Shiva-X: Out
3. SSA Dcon: Out
4. ID: Tempted to get the 2 ID V2 d2's.
5. ID15: Out due to the fact that I can almost get 2 ID12's for the price of one ID15.
Old 8th August 2009, 16:03   #32
Invinsible's Avatar
Thanked: 60 Times
Here is the thing:
1. Gz Hydrogen: Out
2. Shiva-X: Out
3. SSA Dcon: Out
ID15.v3 is for about 21-22K. How much are the ID12 for ?
Instead of infinity I suppose ID's stand better.
Why not consider these instead of Infinity Rockford Fosgate Punch P3SD212 Shallow-mount 12" Component Subwoofers Car Subwoofers Car Audio Car Audio, Video, & GPS Navigation - Sonic Electronix
Invinsible is offline   Reply With Quote
Old 8th August 2009, 16:05   #33
frankmehta's Avatar
Punch series not known for their SQ abilities.
idq15v3 in India is for how much????? 21-22k?
Old 8th August 2009, 16:17   #34
abhinav.gupta88's Avatar
Thanked: 310 Times
There is no IDq15v3 Frank.
It used to come in v2 but not in v3.
Its the ID v3 which is available in the 15" version. Which is for around 24 i guess ( don't know new prices)
Old 8th August 2009, 16:20   #35
karankapoor's Avatar
IDQ 15 they only come in 10" and 12", I doubt they ever came in 15" v3. You get IDv3 in that size.
karankapoor is offline   Reply With Quote
Old 8th August 2009, 16:22   #36
Thanked: 310 Times
Frank must be assuming on the basis that the v2 came in 15"
Old 8th August 2009, 16:28   #37
V2 use to come in 15" but not any more and are not available in India through the distributors maybe he can find one from the old stock.
Old 8th August 2009, 16:51   #38
Invinsible's Avatar
Thanked: 60 Times
Last I heard about IDQ15v3 was when it was in making. Not sure whether it is released or not.
Will check on this.
Old 8th August 2009, 18:04   #39
What i know IMAGE DYNAMICS will first launch the ID MAX 15" and then the IDQ15V3 see when they launch them but i know one thing when ever they launch them they will give tuff time to their competitors.
Old 8th August 2009, 19:29   #40
frankmehta's Avatar
sorry, my baad. I meant IDQ15V2 in india. Is it still available? What was the last price it sold for?
Old 8th August 2009, 21:49   #41
Hmmm may be may be not, Contact Gunbir may be he can help you with this. Get your self a IDMAX will give you best result with both sq and spl.
Old 8th August 2009, 23:45   #42
Thanked: 310 Times
But he doesnt have a budget for that KK.
Old 8th August 2009, 23:51   #43
greenhorn's Avatar
Thanked: 1,519 Times
frank, if you want two subs , but dont have the space to mount them side by side , why not try the isobaric route
Old 8th August 2009, 23:55   #44
frankmehta's Avatar
i really dont have a thing for 2 subs. i just felt, 2 Luccents were required to sound the way I wanted. If i do find a sub that does as well as that, using a single driver, I shall buy!
Old 9th August 2009, 00:25   #45
navin's Avatar
Thanked: 4,286 Times
Option 2: would need a lot of boot space.
Option 4: Looks interesting, but how much would we be looking to spend????
There IS a lot one can do!
1. Option 2 can be made pretty compact if one goes in for a dual siobarik config. One option I have used (using Peerless 10" 831727 drivers) is a 3 chamber dual isobarik. The 2 woofers that radiated into the cabin/room were facing each other. Since this system was corner loaded it did not have to be tuned very low, corner re-inforcement extended bass to the low 20s.
Now if you port the boxes (assuming the drivers are suitable) you can effectivly simulate a coupled cavity box (Neat Speakers makes speakers with coupled cavity bass so you can get the pics from them). I have never used this config but am told that it allows one to pretty low in a rather small box.
2. A TL in a car has been done. Ask B&T. Be prepared to sacrifice a lot of trunk space. If however trunk space is a premium then forgetaboutit.
Originally Posted by abhinav.gupta88 View Post
I would really like to see the last option somewhere. Navin ji, any directions ?
The only person I know who has done this is me in my 1988 Contessa. That was 20 years ago.
Infinity Kappa 122.7w (1227w) 12" Component Subwoofers Car Subwoofers Car Audio Car Audio, Video, & GPS Navigation - Sonic Electronix
2 of these. These are known for their light weight and sound like the luccents. ...and they can easily fit into fibre glass enclosures on 2 sides of the boot.What say????
1. Untill we see T/S specs BL, Mms, etc.. we cant tell much except from the reputation of these drivers.
2. If you are looking at 2 subs; one on either side of the trunk be aware that one side (the sinde with the petrol tank) will end up with a smaller box and also angle the subs so that they do not directly face each other but maybe more towards teh rear windshield.
2 x 12" is the safe method. 1 x 15 will not give you more bass than 2 x 12 but may go lower depending on driver used and box tuning.
Given your limited power availability I'd not recommend isorbailk. Given you need your trunk space lets eliminate the 15" options too. That sorta leaves with your tried and tested dual 12" in sealed boxes option.
The SAGA of Low_Bass_Makker low_bass_makker In-Car Entertainment 1400 5th January 2009 01:32
