Old 24th October 2005, 22:08   #46
Thanked: 157 Times
Originally Posted by filcord
Thanks Buffetfan, but would this be a single s/woofer fitted in a hole made in the rear deck or a s/woofer in it's own box placed in the trunk (something like Soomoku advertises)? I would prefer the latter if the sound is good, since it avoids cutting the rear deck.
My subwoofer is placed in the boot (have not cut the rear tray)..thoug I did cut the rear tray to fit the 6*9 speakers and the sound is pretty good...
this is what I have in my baleno
http://www.team-bhp.com/forum/showpo...6&postcount=62
Buffetfan is offline   Reply With Quote
Old 25th October 2005, 20:30   #47
vivek_pinkoo's Avatar
Originally Posted by Sam Kapasi
Oy Pinkoo... where are those photos?
Sorry for the delay.
Pictures are ready now
Right Speaker
Left Speaker
Complete Rear view
JVC HU
Little bit off topic here (just wanted to put picture thats all)
Front car view
Wheel
vivek_pinkoo is offline   Reply With Quote
Old 25th October 2005, 22:28   #48
Thanked: 157 Times
Originally Posted by navin
You have to buy the adidtional 6x9 spacer tray. In fact if i were you i'd get one made so that the 6x9 fires a bit forward into the passenger cabin this means the spacer tray will have a tapered thickness. You can get a slight 5-10 degree advantage with this technique and it would help your HF response.
Navin,
I had the initial installation on my 936 done with the spacer tray....but did not like the trable much and the bass was also muted...I went for the tray cutting after that and it sounds much better now
Old 26th October 2005, 09:12   #49
navin's Avatar
Thanked: 4,282 Times
vivek pinkoo you could use better speaker wire. even a cheapie like me does! :-)
Old 26th October 2005, 10:14   #50
Is there any problem with this wire?
Old 26th October 2005, 10:53   #51
navin's Avatar
dont look very nice. something like belden speaker wire would help.
Old 26th October 2005, 11:41   #52
Sam Kapasi's Avatar
Thanked: 1,473 Times
OK Pinkoo, I dont mean to burst your bubble here, but this mounting is not right.
You were right, the car is uncut and unmodified. But the hole aboive the speaker is smaller than the speaker itself. Ergo, some parts of the speaker are firing straight into the metal. The very point of having a larger cone surface area (the advantage of a 6X9 over a 6" speaker) is lost.
Secondly, the rubbers are used as spacers just to lower the speaker over the natural curves () of the metal. But the speaker is not insulated at all.
I mean, for a speaker to work in an IB (Infinite baffle) mode, the front has to be reasonably insulated from the rear for any sort of bass to be generated. Otherwise the low frequency generated from the front is simply cancelled out by the rear.
Because of the aperture (6" circular) over the 6X9, i am sure you get a reasonable amount of mids and highs from the rear but little or no bass.
My suggestions: Either cut an oval hole in the metal and mount the speakers correctly.
Or if you are averse to cutting the car, use a small baffle board that will raise the speakers slightly and enable you to mount them on the rear correctly.
Or replace those speakers with a 6" round speaker. Trust me, it will sound better than the way it is currently mounted.
Cheers. (somebody stop me! I think I've got Navinitis!)
Old 26th October 2005, 12:01   #53
Thanx Sam for the observations and suggestions. Will do the needful and get back to u with new changed installation.
Old 26th October 2005, 23:33   #54
jkdas's Avatar
Thanked: 1,436 Times
Originally Posted by Trident
Are there any reliable Sony/JVC/Pioneer head units that play cassettes, audio CDs and MP3s? I have a good collection of audio cassettes and hate to loose them.
clarion ABB341MP
check autocar, oct issue
Old 27th October 2005, 10:42   #55
navin's Avatar
I think Sanyo also makes some...
http://www.onlinecarstereo.com/CarAu...roductID=13414
http://www.onlinecarstereo.com/CarAu...roductID=14073
Old 27th October 2005, 10:43   #56
navin's Avatar
and there are plenty of 2 DIN alternates too....
Old 27th October 2005, 12:14   #57
jkdas's Avatar
i saw the clarion one on autocar advt. and hence posted it as it should be easily avaiable in india. and yup, ther 2 many alternatives for din units.
Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q! Sam Kapasi In-Car Entertainment 13665 19th July 2018 10:01
Pioneer exits from Home Audio-Video & DJ Business. To focus on Car Audio iVento Gadgets, Computers & Software 2 23rd September 2014 12:52
Audio in TV less costlier than car audio? LNG In-Car Entertainment 4 2nd August 2010 12:11
Alpine Audio package for Baleno skumarit In-Car Entertainment 49 9th November 2005 09:10
