Old 18th August 2009, 12:55   #31
rjstyles69's Avatar
Thanked: 795 Times
Shreyas and ananth interesting stuff guys. On a lighter note, shreyas you seem to have a fetish with subwoofers eh, especially big one's ? Lovely pictorial man, think its time I get help from you to damp my vehicle too.
Old 18th August 2009, 13:16   #32
jkdas's Avatar
Thanked: 1,436 Times
Damp what? You got a new one?
Old 18th August 2009, 13:23   #33
rjstyles69's Avatar
Thanked: 795 Times
Need to damp the doors to be precise. Was posted in a hurry, adjust maadi please .
Vehicle's come its huge , basic ICE gone in and awaiting a few more things. Photo session pending will do so this weekend and write my review .
Old 18th August 2009, 13:41   #34
Awaiting Email Confirmation
Thanked: 11 Times
One word of caution with Silicon glue if anyone wants to use it. Always use it in open space and take break after 10 - 15 minutes of work to breath fresh air else you will get severe headache and dizyness. Let the sealant dry fully before you close the door pads.
also if you use it in the sub box, let it dry overnight before putting the sub in cos those fumes can affect the foam on certain types of speaker surrounds, it can make the surround brittle - and that would lead to premature failure of the speaker
one great method to ensure it fills in the gaps properly for subwoofer boxes is to wear some surgical rubber gloves then try to press it in by running your finger with some pressure along the edge of the two surfaces you are trying to seal, the rubber gloves are to ensure that your hand wont smell funny nor will it get the chance to stick your body hair together
Last edited by naughty001 : 18th August 2009 at 13:43. Reason: adding the proper quote
naughty001 is offline   Reply With Quote
Old 18th August 2009, 14:05   #35
DerAlte's Avatar
Thanked: 2,879 Times
Correct, @naughty001.
Actually the silicone glue is inapproriate (way too fluid) for sub box sealing, other than the wire outlet (hole). The sub and connector plate is better sealed with soft rubber sheet (not foam) like cycle tube, or cork gasket material etc. Seams are better sealed at box construction time with a mix of Fevicol and sawdust pressed into the seams.
... Vehicle's come its huge ...
What?
Which vehicle, Riju?
Old 18th August 2009, 14:31   #36
LionX, sorry but cannot see any of your posted pictures, can you re post them.
vijaythacker is offline   Reply With Quote
Old 18th August 2009, 14:33   #37
shreyasma's Avatar
Thanks guys.
I didnt damp as that is stage 2 as per the plan. The vehicle is not rattling as its new
We should be doing it in a couple of days. With a lot of Tbhpians who want to learn FG. May turn out to be a mini-meet.
Naughty boy. Naughty boy!
He reposted here
http://www.team-bhp.com/forum/sound-...ml#post1436876
shreyasma is offline   Reply With Quote
Old 18th August 2009, 14:52   #38
stefanm's Avatar
You have used spacers, but as far as I can see have not mounted the speakers to the door skin, i don't really understand why go to all that effort and not do that, it makes a big difference to the accoustics in the Safari even before damping the door skins, after damping inner and outer door skins the difference is phenominal, trust me have done my installation myself on my Safari, including all carpentry, I built my dual sealed sub box myself and all wiring etc. the only thing i didn't do was the damping as the price difference was minimal. No offence intended just giving my inputs.
stefanm is offline   Reply With Quote
Old 18th August 2009, 15:06   #39
shreyasma's Avatar
@ Stefanm, I appreciate the input. I kind of like the way it sounds when mounted like this. After Sumith heard to another safari of my friend, he also liked it. On top of all, we didnt want to cut metal and plastic and wanted stock look.
Yes, damping surely makes a difference. We will be doing that in a couple of days. We finished the install around 11.30 pm and didnt have any energy left
Old 18th August 2009, 15:31   #40
LionX's Avatar
Thanked: 646 Times
The work area looks neat, no cig or water bottles
And wasnt damping done? And how much did the sub cost? And its fed from the 1004?
We took only 10 min break in the entire session and it was for the Dominos.
The sub costed me 8K and it is in bridged mode with 1004 for now. But I really like the way its firing now as I don't prefer that 'BOOOOM' for long run.
Wonderful DIY kudos to three of you , waiting to see the interior pics.
As Shreyad already mentioned, I need to clean the car first. It is in a total mess now and I have to give it to Concorde Motors for the retro-fitting tomorrow. Will be posting once its done .
Last edited by Jaggu : 18th August 2009 at 15:49. Reason: Lets keep the bottles and its contents away, Thanks.
LionX is offline   Reply With Quote
Old 18th August 2009, 17:12   #41
stefanm's Avatar
I didn't need to cut any metal, as for plastic that's another story, I have kept my install as stealthy as possible only the subs can be seen in the dicky, though at some point i want to mount them in place of one of the jump seats.
Old 21st August 2009, 15:37   #42
vedagiri1983's Avatar
Talking
@Naughty001, Its not that its expensive, we didnt invest as we thought the sealant is just one-time used in the box. Only when used we came to know the pressure it requires to come out of the tube.
I have made a small list of items that will be procured as and when time permits and the gun is one of them.
I would have arranged one for time being if you had informed.It is really hard to get that paste out.I have my personnel experiences with it.
vedagiri1983 is offline   Reply With Quote
Old 21st August 2009, 16:01   #43
LionX's Avatar
Thanked: 646 Times
Thanx for the offer bro, will keep in mind for the next install.
Just finished the photoshoot of the ICE and interiors, will post it tonight.
Old 21st August 2009, 16:08   #44
shreyasma's Avatar
This was a last min thingy. Sumith actually needed it to seal the sub enclosure and then Ananth.
But I need it sometime soon in my tool box.
Old 21st August 2009, 23:10   #45
LionX's Avatar
Thanked: 646 Times
Default The final pics
Posting the final pics of the install .
1. Tweeter mounted on the front door.
2. A view of the boot.
3. Amp installed behind the seat.
4. Crossover install on the side of the front seat.
Name:  Crossover install.JPG
5. The fuse mount.
Ford Figo DIY for USB cable! How do I DIY? fedexp In-Car Entertainment 51 27th February 2013 21:22
ICE ICE baby. Punto"ICE"fied Soccerfan In-Car Entertainment 45 10th March 2012 21:40
DIY: An attempt to Reduce Noise in Tata safari abbey4u DIY - Do it yourself 13 26th July 2011 15:23
DIY : How to secure a Tata Safari Spare wheel cover from theft dadu DIY - Do it yourself 25 14th June 2010 12:19
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever In-Car Entertainment 21 23rd September 2009 20:25
