Old 19th August 2009, 11:54   #1
DjNik's Avatar
Default Tighten the mirror?
Guys I have a 9 month old getz and recently it has started giving me a peculiar problem.As soon as I increase the volume knob and the bass goes up the rear view mirror starts vibrating making a very irritating rattling noise.If i hold the RVM firmly with my hand, its gone.Now my question to you guys is what can be done to permanently get rid of this problem?Anybody else ever faced a similar problem?Please help.
DjNik is offline   Reply With Quote
Old 19th August 2009, 12:40   #2
Akshay1234's Avatar
Thanked: 7,243 Times
have the same problem. just recently realised its the mirror. seriously irritating.
Old 19th August 2009, 13:10   #3
gpa
gpa's Avatar
Thanked: 282 Times
First try tightening the mounting nuts/bolts of the mirror. You'll be surprised how loose they get over a period of time. If that still doesn't work, why not try using some blue tack to make the mirror panels fit tight and true?
You could try using some foam to pack into the outside cowl (round curved plactic face) of the mirror. The foam will not impede the movement of the mirror adjusters, but should help damping the vibrations.
Old 19th August 2009, 14:32   #4
DerAlte's Avatar
Thanked: 2,879 Times
The inside RVM is easier - unmount the RVM and put a cork sheet at the base when mounting back. A thin sheet of thermocol will also do, unfortunately that is quite brittle to work with
For the ORVM, stuff some closed cell foam behind the mirror - just enough to damp the vibration, but not enough to prevent mirror adjustment.
Old 19th August 2009, 14:38   #5
pramodkumar's Avatar
Thanked: 947 Times
This is funny, I was trying to calibrate my ICE with the inside RVM vibrations.During my esteem days the RVM used to vibrate when i pump up the volume. in my lancer it does not happen, i had one pio sub then now i have 2 jbl subs. i thought my amp/ sub are not that powerful. anyways kind of funny i thought that way.
Pramod
Old 19th August 2009, 14:46   #6
shreyasma's Avatar
My was of addressing this is by a layer or rubber sheet (old tube). Remove the mirror, keep a layer of rubber and fix it back. And also tighten the screw next to the adjuster ball on the back of the mirror.
shreyasma is offline   Reply With Quote
Old 19th August 2009, 15:41   #7
DerAlte's Avatar
Sure, rubber inner tube also works, but cork is better at damping.
Old 19th August 2009, 15:56   #8
DjNik's Avatar
Thanks a lot for the suggestions guys.Ill try and see what works out the best for me.Thanks.
Old 19th August 2009, 16:15   #9
beejay's Avatar
Thanked: 109 Times
OT. Read some place here that the Verna mirrors fold on impact a full 180, does the same apply for the Getz. If that is the case, these must be the drawbacks. I am just guessing.
beejay is offline   Reply With Quote
Old 19th August 2009, 16:20   #10
DjNik's Avatar
Never tried folding them to 180 degrees.Anyway i dont have any problems with the ORVM, its just the inside one that is the irritant.
Old 19th August 2009, 17:59   #11
DocG's Avatar
Hmm similar issues. My accord's RVM (the one mounted inside) is utterly useless now, and I shudder to think that I made it a month without using it. The problem I face is that it's mounted on the windshield. These things aren't meant to come off right?
I was thinking about making a metal strut to hold it in place. I mean I don't mind some vibration, but this is ridiculous, now all I can see is my thighs and the gear lever!
DocG is offline   Reply With Quote
Old 11th June 2013, 07:44   #12
libranof1987's Avatar
Thanked: 4,221 Times
Default How to tighten the IVRM?
The IVRM on my Honda City has come loose; every time the car jerks through a pothole or speedbreaker, it shifts its position drastically.
How do I tighten it?
libranof1987 is offline   Reply With Quote
Old 11th June 2013, 09:45   #13
deehunk's Avatar
Thanked: 1,015 Times
Default Re: How to tighten the IVRM?
If I am not wrong the IRVM is fixed to the ceiling right? If it is screwed to the ceiling with a plate you can check whether screws have worn out or the plate itself has any wear. Incase the IRVM is glued to the windshield also there will be a similar problem. Check for screws which will hold the mirror.
deehunk is offline   Reply With Quote
Old 11th June 2013, 09:50   #14
raghu230506's Avatar
Thanked: 63 Times
Its bit strange that it deflects with the impact in pothole,
It normally has a rubber bush/cushion behind the bar, is it still in tact in your case? it shouldn't matter though. Is it the whole assembly that deflects or just the mirror. In case its mirror
One thing you can try is pasting some tape on to the roller and try fixing the IVRM
raghu230506 is offline   Reply With Quote
Old 11th June 2013, 10:35   #15
paragsachania's Avatar
Thanked: 12,364 Times
Usually you will have a tiny screw behind the IRVM which tightens the gap where the mirror is fixed to the main holder. I am not sure if this is the case with the Honda City too.
(above pic is of my WagonR's IRVM)
If you don't have this, you may have to get a new Mirror assembly itself as inserting anything between the gaps to secure the mirror may not sound like a good idea.
(Pic Courtesy: Respective site)
However, you may try applying Fevicol SR through the gap which would form a sticky later over the ball and make things better. Moreover, a small amount of SR wont cause any permanent damage to the mechanism as it doesn't form a hard layer like superglue or feviquick etc.
paragsachania is online now   Reply With Quote
Extra mirror for reverse sensor; what happens to OEM Day/Night Mirror? libranof1987 Modifications & Accessories 15 16th September 2016 18:14
Mirror Mirror On The Wall, Which Is The Ugliest Of Them All! LOVE HER(ALD)! The Indian Car Scene 87 26th December 2008 22:12
Where can I find this nut to tighten my woofer? low_bass_makker In-Car Entertainment 29 3rd May 2007 15:08
new e class mirror question lamborghini Technical Stuff 13 21st February 2005 18:42
