Old 27th August 2009, 10:36   #16
DjNik's Avatar
Please let the Connection stay as it is, it is the best connection possible at this time.All manufactures recommend that both coils be connected at all times, connecting only one coil may be harmful.
DjNik is offline   Reply With Quote
Old 27th August 2009, 10:45   #17
navin's Avatar
Thanked: 4,286 Times
arey baba I think we cleared this...
most manufacturers are afraid that if people connect only one voice coil the T/S specs will change and the user will blame the manufacturer for supplying wrong specs however other than the fact that the Qts changes there is no harm.
I am not good at google but since I knew the background I found this. I cannot find Mike Dzurko's statements on the same topic. The gurus who are good at google might be able to (if they have been puiblished). Mike told me this over the phone when ACI was still a small company.
http://www.adireaudio.com/Files/Dual...oilDrivers.pdf
Old 27th August 2009, 11:31   #18
DerAlte's Avatar
Thanked: 2,879 Times
... (with one voice coil shorted) ...
Navin, look closely - it is a (rather artistically drawn but technically confusing) diagram with simple series connection of the VCs! Even I thought one VC was shorted.
Old 27th August 2009, 11:48   #19
LionX's Avatar
Thanked: 646 Times
DA, which diagram you are referring to? The one posted by DjNik is wrong as he has mistaken the sub as 2ohm DVC.
LionX is offline   Reply With Quote
Old 27th August 2009, 13:01   #20
DjNik's Avatar
Though I had mistaken yor sub as a 4ohm DVC the diagram posted earlier still stands correct as it is a simple series connection.Here is a simpler pic-
Old 27th August 2009, 13:09   #21
LionX's Avatar
Thanked: 646 Times
I got it correct DjNik and my sub is connected in this way right now.
But now I got one more way to try as navin explained. In that way I can provide 4ohm load to the amp and utilize it completely .
Old 28th August 2009, 08:51   #22
akbaree's Avatar
Thanked: 50 Times
That's a beatifully written article. It has so much depth but still is easy to understand. Thanks Navin for sharing.
Please correct me if I have understood incorrectly - you will bridge the two channels of your amp and will power one VC of your sub with that bridged power. Each VC is 4 Ohms and so it would be match. And you would be able to pump 320RMS to the Sub. Correct?
Please do share your feedback with us. And thanks for raising these questions. I have learnt something new and interesting.
akbaree is offline   Reply With Quote
Old 28th August 2009, 10:06   #23
LionX's Avatar
Thanked: 646 Times
Yes anant, that is what I am planning for. I have to keep gain at 0 level since one VC is rated as 300Wrms (600Wrms DVC, so each coil is 300W).
I will install the clarion and this sub configuration next week, so will update all of you after that.
Old 28th August 2009, 11:13   #24
akbaree's Avatar
Thanked: 50 Times
Yeah, on the amp there's marking for 6V. The Clarion has 6V pre-out and so you can keep the gain at 6V. But still you will be providing 320 RMS to the VC. So if you feel the Sub is boomy, you can reduce the non fader gain from the HU.
Old 28th August 2009, 12:08   #25
LionX's Avatar
Thanked: 646 Times
Yes I will do that and hope the VC can take 320Wrms. Another thing remaining is the polyfilling of the enclosure, but dont know how effective it is for a sealed enclosure.
Please advice the effectiveness of polyfilling a sealed box for better SQ .
Old 28th August 2009, 16:34   #26
akbaree's Avatar
Thanked: 50 Times
I am too grappling to find answer to this question. Gurus please help.
Only thing I have understood about polyfill is that it creates an illusion of larger volume. I want to experiment with it soon. As the actual volume of the Sub will not change I feel the only difference would be to tonal quality of sound and may give an impression of deeper bass. But I need to put it in and experience what it really is.
Old 28th August 2009, 17:04   #27
abhinav.gupta88's Avatar
Thanked: 310 Times
Polyfill is generally added to the enclosure to make the sub feel that the enclosure is bigger
Old 28th August 2009, 19:57   #28
Invinsible's Avatar
Thanked: 60 Times
Addition to that it depends on how much you add in. Adding as little as 10ounce around an inch on the inside wall of the enclosure also helps cutting down the standing waves and resonance.
Invinsible is offline   Reply With Quote
Issue with JBL GTO 1004 Amp Trust_In_Thrust In-Car Entertainment 7 21st June 2014 20:20
6 ohm or 8 ohm speaker?? arjithin Gadgets, Computers & Software 12 27th November 2011 16:11
JBL 1004 vs JBL PX300.4 vs GZ TA 4.120MK2 vs Infinity 475A St. Anger In-Car Entertainment 12 13th August 2009 15:26
JBL GTO 1004 Amplifier Woes!!! EDIT - Now resolved rider60 In-Car Entertainment 10 27th July 2009 23:36
JBL 12" DVC, your opinions ? s0uljah In-Car Entertainment 33 5th May 2006 13:25
