Old 11th May 2010, 07:43   #46
gigy's Avatar
Thanked: 41 Times
Thanks.
The white one is usb fm receiver.
There is no problem with heating in this setup. i am running cpu at full speed and it is as cool as it was in test setup at home.
gigy is online now   Reply With Quote
Old 18th May 2010, 22:23   #47
StreetAddict's Avatar
Thanked: 45 Times
Originally Posted by gigy View Post
Thanks.
Details on it
StreetAddict is offline   Reply With Quote
Old 19th May 2010, 08:27   #48
gigy's Avatar
Thanked: 41 Times
Amazon.com: ADS RDX-155-EF Instant FM Music: Electronics
A D S ADS Technologies RDX-155-EF Instant FM Music RDX155 Cable Review
nothing great about it dose its job only if car is not moving, so not recommended buy
Old 19th May 2010, 20:09   #49
Thanked: 45 Times
So what do you recommend ?
Old 20th May 2010, 18:47   #50
gigy's Avatar
Thanked: 41 Times
if possible retain the head unit to have quality fm and control over music. some references are available in mp3car forum but a costly affair, i dont think its worth the effort for the contents in fm.
Old 20th May 2010, 23:08   #51
Thanked: 45 Times
Got no plans of buying a new HU just for FM as well! The setup would be done in a brand new car which does not come with a HU. Any other suggestions ?
Old 14th June 2010, 15:20   #52
gigy's Avatar
Thanked: 41 Times
Carputer is off the baleno now. Getting rebuild with a SSD, HEX USB + CAN for VAG-COM 908 and Double DIN LCD Frame with IRV-070GL with rest of the configuration remaining same.
Thinking of using this small htpc cabinet in car instead of the metal cabinet.
Old 6th July 2010, 13:43   #53
gigy's Avatar
Thanked: 41 Times
Little update of work in progress
Old 14th November 2010, 21:52   #54
gigy's Avatar
Thanked: 41 Times
I have been struggling with this vagcom setup and pc was not booting up last two days. now found if vagcom is connected then pc refuses to boot. what could be the problem?
I am still to get any data out of it to centrafuse although vagcom through laptop with win xp is working
Old 15th November 2010, 10:46   #55
DerAlte's Avatar
Thanked: 2,879 Times
Where does it stop in the boot phase? Try disabling in BIOS the booting from USB. Perhaps the VAG-COM cable connection is being sensed as a bootable device and hence nothing happens after that.
Old 15th November 2010, 12:18   #56
NetfreakBombay's Avatar
Thanked: 402 Times
Maybe it is drawing too much power from USB.
Does it work if you attach carputer to AC power supply via a normal PC SMPS.
Old 15th November 2010, 13:06   #57
just came across this thread n have to say awesome setup!!
a couple of thoughts crossed my mind or rather have been thinking about implementing them in my carpc...hope you can shed some light
  1. is it possible to transfer music to your carpc hdd via Wifi??
  2. does Centrafuse support multiple video/audio (eg. main screen on Navigation+songs while rear screens on independent movies with audio being handled by headphones)
  3. are there any amps that support optical inputs?
peace,
~kg
kapilvgupta is offline   Reply With Quote
Old 15th November 2010, 13:21   #58
DerAlte's Avatar
Originally Posted by NetfreakBombay View Post
Maybe it is drawing too much power from USB ...
That shouldn't disturb anything else, especially while booting. On overcurrent, the internal hub will disable the port. The VAG-COM 908 cable is not expected to draw more than 100 mA.
Old 16th November 2010, 05:21   #59
Thanked: 45 Times
Yes! You can transfer anything you want over WiFi.
Dunno about independent audio streams, but Centrafuse does support independent screens provided you have the necessary hardware.
Yes, there are! 5.1 Amplifiers with Optical inputs - MP3Car.com
Old 17th November 2010, 17:22   #60
gigy's Avatar
Thanked: 41 Times
Thanks for the inputs, will check the bios settings.
Earlier the vagcom cable was connected directly to motherboard with extension usb cable. now i have put in a belikn 4 port usb hub after which the problem started.
Not just another CarPC Carputer Setup. HarneetBarmy In-Car Entertainment 17 20th May 2011 20:23
