Old 20th March 2006, 19:06   #3076
Sam Kapasi's Avatar
Thanked: 1,473 Times
The Denser and heavier the wood you use, the better it is. MDF is easy to work with, well, easier than Plywood anyways. But a good heavy marine ply is a better bet for making a nice box.
However for the parcel tray, honestly MDF is just fine.
Old 20th March 2006, 20:38   #3077
Bass&Trouble's Avatar
Thanked: 71 Times
Originally Posted by airfoil
What is recommended, an MDF sheet or a 12mm sheet of plywood, for the rear shelf?
Please explain why as well!
Thanks!
Plywood is a mess to work with, and doesn't have half the acoustical advantages of using a fiber-board. 12mm MDF should be good for a parcel tray. Never under 18mm for a subwoofer enclosure.
Old 20th March 2006, 21:13   #3078
Autophile's Avatar
Go for MDF...don't use plywood. Only plywood I like to use is Birch Plywood to make enclosures...sounds good. But MDF is more rugged and durable.
Autophile is offline   Reply With Quote
Old 20th March 2006, 21:49   #3079
Thanked: 13 Times
On that note - Yesterday I had to drive my dad & cousin to the airport, a little extra luggage and carelessness caused the suitcase to hit my rear left speaker.
Now the MDF around the four screws have all chipped out and my speaker is lose, there's no way to screw them in with the company screws. Will need to get longer screws or come up with some other idea (maybe metal paste?)
Old 21st March 2006, 11:07   #3080
navin's Avatar
Thanked: 4,266 Times
Ok my 2 paisa....
Ply is usually easier to work with than MDF. Use a power saw on MDF and see the dust fly!
However to use Ply wood for any speaker box it must be VOID FREE. There are some grades of Marine Ply available in India that are VOID FREE. Many are not. If you dont know wood. stick to MDF and use a mask.
The Thnner the wood used the more the bracing required. You can use 6mm wood but brace it evey 4" or so and see how stiff it gets.
Beyond that I have used Hardoods (incl. Rose Wood, Oak, Teak and even Ebony), SoftWoods (Birch, Beech, etc...), Plys and MDF and even aluminum and fiberglass and of these MDF has the smallest learnig curve.
Aluminum is best used in extrusions mated to SS Baffles cut on a water jet machine. I intend to make a HT/AV speaker using this technique sometime.
Fiberglass has great stregth/Stifness to weight ratio but I find that to really make fiberglass stiff as hell on can sandwich 3mm MS between 2 layers of FRP. (FRP is Fiberglass Reinforced Plastic or Reson Bonded Fiberglass). Do this before the resin hardens and you got a 9mm (3-3-3) thick material that is stiff as hell and wont resonate like SS or AL. I intend to may a car sub box (for the Octy) using this technique atleast for the baffle. Sam you'll see! :-)
FRP's great advantage really is it's ability to be moulded into just about any shape.
Beyond that some materials are a No No. Glass is a reall No No. It resonates like hell and no matter how to workit you cant kill those resonances. I tried Lead sheet (1.5mm), Dacron, Rubbers, etc... no avail. I think Plxiglass would be agreat amterial though. Gotta lay my hands on some soon.
End of Rant.
Old 21st March 2006, 12:13   #3081
Sam Kapasi's Avatar
I've got a great Pleaxiglas supplier. Let me know if you want some.
Old 21st March 2006, 12:51   #3082
I once cut up a whole 8x4 sheet of MDF inside the apartment with a circular saw and the room took about a week to clean.
Is plexiglass cheaper than MDF?
Vivekphadnis is offline   Reply With Quote
Old 21st March 2006, 12:53   #3083
Autophile's Avatar
Don't use circular saw...its very messy...use good quality Jigsaw...eg. Bosch with pendulum action.
Old 21st March 2006, 13:00   #3084
I need to get one of them jigs. Pretty useful thing. How much do they cost?
Old 21st March 2006, 13:10   #3085
Autophile's Avatar
Go for Bosch Power Tools GST-85PBE..very good jigsaw. Visit any Bosch Power Tools dealer in your city. They might have latest model also.
http://www.boschindia.com/mico/pwrto...ml/jigspec.htm
Old 21st March 2006, 14:48   #3086
Sam Kapasi's Avatar
No plexiglas is about 5 times the cost of MDF
Old 21st March 2006, 15:30   #3087
navin's Avatar
Sam you are giving me ideas. I think I will kas my wife if she will tolerate plexiglass boxes in her car. I am thinking of maybe reconfugring her woofers.
Old 21st March 2006, 18:47   #3088
Autophile's Avatar
Plexiglass enclosures are good for showing off...Still personally prefer MDF as it has much better acoustical properties than Plexiglass.
Old 23rd March 2006, 13:14   #3089
binz's Avatar
Thanked: 412 Times
Hey guys,
i aint got any time now to start a big thread and all but i thought i should let you know that im ICEing my santro...yaay!!!!.
The budget is around 30k and im sure you guys will help me!
First of i need to know whether this HU(in link below)is good.The features are great and it seems great vfm at around 10k rupees.Dads in dubai now so i want him to pick it up from there;so i need you advice real quick.
http://www.onlinecarstereo.com/CarAu...roductID=15720
Im looking at all the things i need for the system and checking their price and availablilty.Once im done i start a new thread for my car.
Need your inputs quick,
thanks!!
binz
Old 23rd March 2006, 17:02   #3090
Sam Kapasi's Avatar
I would rather buy the Alpine 9856 for $229 which is the same identical price on that website as the Pioneer 680. Go for the Alpine IMO
sub enclosure advice from audio gurus clipto333 In-Car Entertainment 22 4th January 2007 11:29
