Old 31st May 2006, 10:39   #3541
jkdas's Avatar
Thanked: 1,436 Times
Originally Posted by low_bass_makker
Reduce some treble from the head unit it will help a lot. The matching of tweeter with the cone is not a matter of sound level of the amp.
hows ur tweeter placed? And as lbm said, cut the trebble frm HU. Mine's almost at teh min possible
Old 31st May 2006, 10:57   #3542
kpzen's Avatar
Thanked: 1,648 Times
Tweeter is on the dashboard near the windshield ...
Crossover under the glovebox....
Old 31st May 2006, 11:37   #3543
navin's Avatar
Thanked: 4,265 Times
does not the crossover have a -3db option for the tweeter?
try this...
1. reverse the phase on both tweeters. it is simple just connect the wires at the XO end in reverse. this could drop the upper midrange and tames the treble. the details are too complex to go into here.
2. pad the tweeter a bit more. not really difficult if you are handy with a soldering iron.
navin is online now   Reply With Quote
Old 31st May 2006, 11:43   #3544
jkdas's Avatar
try this...
and position it so that it fires not at you but to the opposite sides. Right?
Old 31st May 2006, 11:48   #3545
navin's Avatar
good idea JK. keep the tweeter off axis and it will help a lot. most car tweeters tend to beam above 6-7Khz.
Old 1st June 2006, 00:55   #3546
Thanked: 294 Times
KP I will meet u tomm and will help u to resovle ur problem of tweeter. Pm me if u r free .
I will be free after lunch. I will call u and fix the meeting.......
Old 1st June 2006, 06:17   #3547
Default Alkpine HU
How is Alpine CDA W560E Dual DIN HU? This is the model that comes with NHC Vtec.
Deepu
deepug is offline   Reply With Quote
Old 1st June 2006, 10:46   #3548
navin's Avatar
very average Deepug.
I understand that it dont even have RCA outs to add on an external amp
In fact I have not found any 2 DIN HUs that can compete with similarly priced 1 DIN HUs in sound quality.
Old 1st June 2006, 11:02   #3549
kb100's Avatar
KPZEN./..
In that snap it looks like all your wires - power,RCA,Speaker - are all bunched together.... Thats not a good thing at all... Guru's will elaborate..
kb100 is offline   Reply With Quote
Old 1st June 2006, 11:44   #3550
rareone's Avatar
Thanked: 11 Times
Question JBL T595 Wiring Problem
Hi Guyz
I have recently changed my ICE.
But i m not satisfied with the sound quality.
I think may be the wiring is not done properly.
Wud be great if someone cud help me out.
The ICE Setup for my Santro
HU - Pioneer 6850
Front - Pioneer Tweeter with Pioneer Front Speaker
Rear - JBL T595 Limited - 15 x 24cm (6"x9") 3-Way Multi-Element connected thru Sony Xplod 504 Amp
Rear - JBL 1000Watts Base Tube connected thru another Sony Xplod 504 Amp
Also soon planning to add JBL Front Components but dont knw how to fit them in Santro.
It wud be gr8 if Audio Guru's here will help me abt the wiring.
The main problem is the JBL T595 Speaker has HP and LP connectors on it, but my audio installer said u dont need 2 connect to both connectors, so he connected only 1.
Also if someone could let me knw a good place in Mumbai where i can go for wiring and solve the problem easily and enjoy a good sound from my ICE
Thanx
Waiting for Comments
rareone is offline   Reply With Quote
Old 1st June 2006, 11:46   #3551
Thanked: 294 Times
Originally Posted by kb100
KPZEN./..
Man from my personal experiance If there is no noise in the system then the wires bunch together is not a big issue..........
Old 1st June 2006, 11:48   #3552
navin's Avatar
Since the topic has come up
1. I see DAPIC RCA cable. How good is it?
2. The speaker and power cables look anemic
3. I prefer to colour code my cables and terminals so it makes for easier to follow. 4 Red cables and one wont know 6 months from now which cable is which expect by looking at the printing on the amp which can be hard to read if you have an audio problem at night.
Old 1st June 2006, 12:02   #3553
Thanked: 294 Times
Dapic which I assume is a local delhi make cable also there is some number 2 and 3 on the rca might be some indication of the front & rear channel and the power wire is the normal house-hold wire gauge can be 12 (or 4mmsq) or even could have came with the amp itself. The speaker wire he has used are the wires which comes with the speaker itself so as I presumme white to be the left channel and the grey to be right channel, Rest kp could shed a little more light to the matter.............
Old 1st June 2006, 12:20   #3554
nishant_kingpin's Avatar
Originally Posted by nishant_kingpin
My primary support need is to request suggestions for a good audio system for the Fiat Adventure. Till date I have always had basic systems like Kenwood and Sony explode fit at a dealership or accessories store. I have not had any woofers or amps on my cars till date however I am not averse to having them. I am keeping an upper cut of Rs. 20,000 which too is a little over. My view is that a good car should have a good system to it.
Thanks in advance
Hey audio gurus. Any sugestions on the bove would be great help. Waiting...
nishant_kingpin is offline   Reply With Quote
Old 1st June 2006, 13:05   #3555
rsjaurr's Avatar
Thanked: 27 Times
I will advice u top go slowely and build ur ICE in 6-12 months with this budget.
Option1-If wants to have ICE with subw and amp -
Pio HU 7k
front compo and rear coax 5-6k
sony 504 amp <5k w/o b/w
pio subw with custom made box 3k
wiring+install 1k.
Option2-If want to add subw+amp later -
Pio HU with 3 pairs of oreoutputs-9k
Front compo 6-7k blau/JBL/Hertz/alpine
Rear coax 3-4k
spk wire+install 500
rsjaurr is offline   Reply With Quote
sub enclosure advice from audio gurus clipto333 In-Car Entertainment 22 4th January 2007 11:29
