Old 19th September 2006, 14:45   #4381
Thanked: 16 Times
WOW!!! Sam made it. But that was the first name which flashed in my mind when I read GTO's pm.
Congrats man!! And any tips for us to make it there too??
Old 19th September 2006, 15:18   #4382
harmon_bro's Avatar
Originally Posted by navin
I'm going to assume the HU is a 9856R
http://www.alpine-europe.com/content...A-Receiver.htm
This HU as per info above does not have a built in Crossover (only the 9855R has one in the present line up). Hence any filtering requires a bass blocker or an amp. A bass blocker looks like this
http://www.crutchfield.com/S-C8F9EHI...sp?g=761&avf=N
but is simply 2 470uf electrolytic caps back to back. I would add a 1uf polyester cap in parallel with the back-back-cap combo to make the cap a little less harsh. Then "wrap" the whole contraption (2 470uf camps and 1 1uf poly cap) in heat shrink.
So
a) use the above bass bloxcker for the front speakers
b) set EQ to flat and see if everything sounds ok
then report. if you need more bass blocking we can use different caps. The GUrus (B&T, Sam, Gunbir, Etc..) can post what this camp looks like. I dont know how to post pics. LBM ofcourse will surely google everything there is to know about Bass Blockers in the next 30 secs! :-)
Hi Navin,
This is the model and the specification of the system that I have. I shal check the bass blocker out too. But before going for it I need to know if I can make the most of the settings that are available instead of adding more intermediate electronics getting in the way between the system and the speakers .
http://www.alpine-usa.com/en/product...&lang=en&tab=F
harmon_bro is offline   Reply With Quote
Old 19th September 2006, 16:15   #4383
Sam Kapasi's Avatar
Thanked: 1,472 Times
lol, when i saw it, i thought they made a mistake. I toh tdo masti all the time, nothing distinguished about that
Oh well, Thanks guys. Thank you for the congratulations and the support.
Speedzak, you want serious advice on how to get there?
Keep smiling, make your posts readable and happy and informative. Just being an active member of team-BHP is not enough, you have to love this forum and spend every day making it a better place. Then only after that you have the right to figure out how to get more XXX as LBM put it lol.
Now that's said - let's get back to the reason we are here. A-U-D-I-O
Harmon_bro, I checked with someone, it seems the BBE on your unit successfully ruins the sound rather than add to it.
Navin are you sure that there is no HPF on the alpine 9856? Its got a parametric eq and a provision to put the internal amplifier off.
Old 20th September 2006, 10:37   #4384
Thanked: 161 Times
Kudos Sam on getting distinguished... and your new avtar i think says it all.. boys move aside .. let the distinguished gentleman thru... :-)
jinu_joseph is offline   Reply With Quote
Old 20th September 2006, 10:54   #4385
congratulations Sam! Its not only you who is distinguished, I am sure if GTO comes up with such recognition for logos, yours will be 1st one to bag it
santosh.s is offline   Reply With Quote
Old 20th September 2006, 11:15   #4386
jkdas's Avatar
Thanked: 1,436 Times
yah re! the distinguished TBHPian squeezed btw two galz
Old 20th September 2006, 11:49   #4387
harmon_bro's Avatar
:((, I have the BBE option off all the time. I have read in a lot of other forums that the BBE settings does not help in anyway but give sad quality sound. More inputs please, help me :(
Old 20th September 2006, 12:01   #4388
navin's Avatar
Thanked: 4,265 Times
I have not used the 9856 but as per the specs on the website they dont list a HPF/LPF. Sad huh?
Harmon, does the 9856 have HPF/LPF settings?
Old 20th September 2006, 12:03   #4389
Is it a commonly found feature or exclusive only for elite few? Do famous pio's provide this?
Old 20th September 2006, 12:35   #4390
Sam Kapasi's Avatar
Unfortunately, it is such a simple feature, but only very very few head units have it.
Old 20th September 2006, 14:04   #4391
Thanked: 294 Times
sorry Sam Bhai and Navin Ji it is a bit Off topic but what is happing....seven threads closed.....never seen this type of strictness before....
Mods if u feel that this post is not correct you can delete it...
Old 20th September 2006, 15:03   #4392
navin's Avatar
Closure helps when you need to reopen a topic like was done for KB Da DB.
LBM, you keep track of the most innocous things! :-) BTW before I get PMed to death threads that are closed are closed for good reason.
I am not the only person authorised to close a thread so dont, I reapeat, dont ask me why/when/how/what etc.. you are however free to PM me if you would like the thread to be reopened as you have something valuable to add.
Old 20th September 2006, 15:05   #4393
kb100's Avatar
.... I agree.. this is twice... and nothing is offtopic... install is in two days... YET locked!... Navfin I sure am confused - Interpretations of what is considered "valuable additions" seem to be a very fluid and covering the entire spectrum... Sure I will not ask why ... but sure would help if these so called 'reasons' can be made public... at least we'd know what to avoid! - Kind of like a continuously updated "DO-NOT-DO" list! ... You know .. somewhere a thread getting locked is vaguely insulting - IMHO
Sure must have pissed someone off... "Pichichi Syndrome"!
kb100 is offline   Reply With Quote
Old 20th September 2006, 19:48   #4394
Sam Kapasi's Avatar
Arrey KB, what is so insulting, it is your thread. When you are ready with info and pictures all you need to do is send a PM. The lock is not to insult or prevent YOU, it is to prevent useless posts (and the good lord knows we all do that often)
No big changes, just pulling up our socks a little bit for the betterment of team-BHP and our beloved ICE forum. Server Space=money you see.
Nobody's getting strict or anything LBM, I know you love the ICE forum more than everything else, help us make it better, thats all
Old 20th September 2006, 20:51   #4395
harmon_bro's Avatar
Navin,
I just checked the manual now. It does not have the HPF or the LPF settings. :( I guess they compromised them with the BBE board.
Any suggestions to compensate the non-existence of HPF?
FYI, Iam planing to get a 4 channel JBL amp to power up the compoents and the ovals. And using my old Sony 222 amp to drive my 12" sub with ported enclosure.
sub enclosure advice from audio gurus clipto333 In-Car Entertainment 22 4th January 2007 11:29
