Old 8th December 2006, 11:18   #4771
navin's Avatar
Thanked: 3,980 Times
Originally Posted by hydrashok View Post
2. If your budget allows, go for components in front.
3. Fix co-axials in the back. (Co-axials of the same brand and series).
4. Both companies are good, ...
And, if you don't mind spending a little extra (about 2K-3K more in total), You must give a listen to Hertz DSK165 components and DCX165 co-axials. They are worth the extra money.
Alpine Type S also competes in JBL CS and Blau GT price band.
If you are considering JBL GTO, Blau OD or Hertz, I would also look at Alpine Tpye R. Blau TH series is useful for shallow depth installs. Your swift has enough room for the OD.
Also if you are considering components for the front check with your installer on the location of the tweeters before you cut and chop the car.
Old 8th December 2006, 16:43   #4772
MustangMan's Avatar
Which one to go for? JBL CS2165C or GTO507C?
GTO a sure fit in my Palio, the CS requires some banging.
Apparently only 500bucks differance.
MustangMan is offline   Reply With Quote
Old 8th December 2006, 16:47   #4773
Sam Kapasi's Avatar
Thanked: 1,460 Times
I suggest the GTO507C for your palio.
Old 8th December 2006, 16:55   #4774
MustangMan's Avatar
That was super quick! Thanks.
Old 8th December 2006, 17:00   #4775
Technocrat's Avatar
Thanked: 2,545 Times
Ok quick question can I power my front 2 way Sony speakers(peak Power=130w, rated input power=30w) with this amp SONY 554ZR ??
Currently I am using the amp to power rear Pio coaxials & sub.
Is it a good idea or the speakers are too small for this amp ?
Old 8th December 2006, 17:02   #4776
Sam Kapasi's Avatar
You can power these speakers with an amplifier, but please make sure you have the high pass filter ON and frequency at 100Hz.
Old 8th December 2006, 17:03   #4777
Vipul.Sharma's Avatar
1. Any speaker that says 40W and upwards will do you.
Listen to all three and decide which suits your taste best.
Thanks buddy........Could u teel me which coaxials to go for rear installation (2way or 3 way)........
and say if i dont go for compo's then will it be ok if i install Coaxial 3-way in front and Coaxial 2-way at rear. [All door installation].
My knowledge bank says that rear ones are for filling only and trebble should come from front.....
Is it possible to install only woofer at rear that is one way speaker.....I don't know how it will sound......
Vipul.Sharma is offline   Reply With Quote
Old 8th December 2006, 17:04   #4778
Technocrat's Avatar
Sam but would this yield better result than current one(i.e. powering rear 6X9 by amp) i.e. will it effectively bring the sound stage to front? The front right now cant take bass that well(may be it will after the amp?) Right now am running HPF on at 125hz through HU
Old 8th December 2006, 17:05   #4779
jkdas's Avatar
Thanked: 1,433 Times
techno, power them and the sub frm amp and the rear frm HU
edit: techno,which car?..grr. alto
emm, ok. A good installer can install bigger speakers on your front doors
and techno, you have a co-ax at the rear and a sub. If aint still happy with the setup ( bass) I think your tuning aint good.
Old 8th December 2006, 17:09   #4780
Technocrat's Avatar
Nah dont want to cut anything :(
but one thing I have noticed is that these give better treble than the pioneer & Kenwood ones available
Old 8th December 2006, 17:12   #4781
jkdas's Avatar
so you want chil chil and booom booom at the same time from the front ?
Get a 6inch compo for your frnt door.
some amp support a sub along with a pair of speakers ( my pa 275 does). If you want all your speakers powered from amp without losing out on fader effect get a better amp..
me right guys?
Old 8th December 2006, 17:16   #4782
Technocrat's Avatar
Arre Baba no cutting shutting of the door.
right now I have put the fader to F4 which gives decent front stage but if its a song which I want to listen loud I need to set the fader to rear as the front cant handle it, so was wondering if powering the fronts with amp would be of any help? Also its mostly me who wants loud music the rear passengers(whenever there are any) hate it when I pump it up
Major criteria got no dough to buy anything new just want to see if doing thsi small change would bring any major difference or not.
Old 8th December 2006, 18:11   #4783
Bass&Trouble's Avatar
Thanked: 71 Times
Wow, Vipul Sharma must be an awfully attractive man to turn on a speaker.
Old 8th December 2006, 18:21   #4784
Technocrat's Avatar
oops mised this comment. No am very happy with my current setup. its just that i will soon be going to an installer to get the alternator whine removed, this might need new cabling(as cuurent one is not that great) so was toying with this idea
Old 8th December 2006, 19:36   #4785
hydrashok's Avatar
Took me a sec but you got me rolling in the chair :-D
sub enclosure advice from audio gurus clipto333 In-Car Entertainment 22 4th January 2007 11:29
