Old 21st February 2007, 10:45   #5386
Originally Posted by angelfire View Post
guess its KDC-4023 or somethin..not very sure though....ITs a very basic HU nd the Sound Quality is fairly good...4200 is ok for it..But the stock factory speakers are crap....So dont buy the speakers...Get better ones.....Say a 6x9 or so...
Thanks a ton buddy. The owner wanted an ok-ok system so I guess I should tell him to go ahead.
sandeep_tyagi is offline   Reply With Quote
Old 21st February 2007, 11:20   #5387
Vid6639's Avatar
Thanked: 18,918 Times
Navinji, B&T, When you say set HPF for front and rear separately I'm guessing it's through the 4 channel amp and not through the HU?
Old 21st February 2007, 11:38   #5388
navin's Avatar
Thanked: 3,731 Times
Many HUs can do this too.
Setting the XO at the Hu allows for flexibility and ease of setting. Setting the Xo at the amp allows that when your car comes back from servicing the Xo is still set the same.
navin is online now   Reply With Quote
Old 21st February 2007, 11:55   #5389
Vid6639's Avatar
Guess that's in the higher end HU's. I didn't find that on my pio 5750. I dont think even the pio 6850 has that.
Old 21st February 2007, 13:27   #5390
revtech's Avatar
Thanked: 35 Times
yeah vid your right....its not possible on the 6850. the 6850 has jus one HPF for all four speakers. i guess this is poss on the highe end alpines and the likes..
Rev
revtech is offline   Reply With Quote
Old 21st February 2007, 14:03   #5391
Bass&Trouble's Avatar
Thanked: 65 Times
The higher end Pioneer head units and a lot of Alpine head units allow for different front and rear crossover settings in terms of cutoff frequency, slope and output level. Even most amplifiers do not feature adjustable crossover slopes. When using a head unit as described above, bypass the crossover on the amplifier since the head unit affords you greater flexibility and is always at your fingertips.
Old 21st February 2007, 20:01   #5392
harmon_bro's Avatar
On the Alpine 9856 model whhere can i find the crossover settings.
harmon_bro is offline   Reply With Quote
Old 21st February 2007, 23:09   #5393
gamerno1's Avatar
Default Wierd HU/Speaker Problem
hey guys..
got a Pioneer 8850 (7900 USA) installed along with JBL GTO 607 comps(front) & 937 coax(rear) powered by a 75.4.
now the wierd part:
as i switch on my HU, its all fine. then as soon as i will use any functions on the HU (change track/equalizer/display settings/volume up-down from the remote) the usual Pioneer "tic" sound comes out from components, & its LOUD. TEEEEK... sigh. & the worst part, it also happens when the HU volume is 0.
This is my 4th Pioneer HU in 3 years & i have not had this issue with any before. The installer says its a common problem in the 8850 (which i wont believe) or might be a Feature in the HU (which i doubt as i searched google as well as went through the HU Manual)
If i dont find a solution quickly, i will have to get this HU changed with a Pioneer P1Y or a 6950 (which i dont want to as im in love with the 8850 apart from this issue)
Also if any other 8850 owners had this kinda problem (lbm????)
Suggestions welcome, thanks!
gamerno1 is offline   Reply With Quote
Old 21st February 2007, 23:17   #5394
Sam Kapasi's Avatar
Thanked: 1,416 Times
It can happen if your gain is very high. Please check that the gain of the 75.4 is not turned up beyong 40%-50% of it's capacity.
Old 22nd February 2007, 00:05   #5395
gamerno1's Avatar
hey Sam
just checked it. that "tic" sound gets loud/soft with the gains. As soon as i zero'd the gains, the sound went away. but even when i increased it a little, the sound was back again (softer, but kept on going louder as i increased the gain)
so the thing is that the tic sound is actually following the Amp gain & not the HU volume. Very wierd, never experienced or heard before....
Old 22nd February 2007, 01:00   #5396
gamerno1's Avatar
ok guys, prob solved
it was the ASL which was causing the problem.
found a thread thru google which was discussing a similar issue
Time for a new thread/pics
Old 22nd February 2007, 01:43   #5397
iraghava's Avatar
Thanked: 151 Times
Congrats on the new system ROLand Waiting for the pics & story!!
P.S. Did you like the advice you got? Or did you not?
Old 22nd February 2007, 02:09   #5398
gamerno1's Avatar
i DID like the advice. New Thread coming up in sometime
Old 22nd February 2007, 10:20   #5399
Autophile's Avatar
There are none on Alpine 9856 / 9857
Autophile is offline   Reply With Quote
Old 24th February 2007, 17:29   #5400
abhibh's Avatar
Thanked: 33 Times
Ok Gurus a friend of mine needs help. He has M800 and an Alto. Need speakers for both of them.
Speakers will most probably go in tray. Budget for speakers 6K per car. NO components. I am suggesting him to go or 4 speakers 2 front and 2 rear.
So which ones to go for. HU is JVC in M800 and PIO in Alto. Both basic Audio / MP3 ones..
sub enclosure advice from audio gurus clipto333 In-Car Entertainment 22 4th January 2007 11:29
Please Read This Thread *Before* Posting in the "What Car?" Section adya33 What Car? 0 12th July 2006 19:12
