Old 4th March 2007, 05:49   #5446
tyre_on_fire's Avatar
hey guys, need some advice on getting a decent audio config for my new alto(lxi).have checked out a few options and haver decided on:
front :4" JBL
back : infinity 300 watts
HU: pioneer 5950(yeah i know its the grey market stuff and originally is 5990)
its costing about 13k.is the combo ok or could it be better for the same price?
tyre_on_fire is offline   Reply With Quote
Old 4th March 2007, 08:51   #5447
Vid6639's Avatar
Thanked: 18,661 Times
tyre on fire, this combo is perfectly fine.
Which infinity are you considering? I'm guessing 6X9 coaxial oval speakers, reference series?
Old 4th March 2007, 21:37   #5448
determinus's Avatar
Default Symphoney HU in Octy
Originally Posted by gunbir View Post
Post a pic of the HU. There are a few versions like Symphony II etc. We can give you more info once we know which one.
Here is a pic of the HU. I checked the manual, but there wasn't much info on any specs. The only thing I could get from those 25 pages was that it is 17w RMS at 4 ohms (20 peak). But for the left bottom corner that says "IO" the unit has no other markings.
(Mods: Small image, hence posted it up. Hope it is OK)
determinus is offline   Reply With Quote
Old 5th March 2007, 00:06   #5449
determinus's Avatar
front :4" JBL
Its costing about 13k.is the combo ok or could it be better for the same price?
There is a thread by Navin about ICE at various budgets. There is one for 10k as well as 15k. Just do a search.
IMO: If you can accomodate a 4" Infinity (like a 4012i) in your budget the sound will be a bit more natural. I would probably try to get an Alpine HU and compromise a little on the rear speakers. Check Navin's post first.
Old 5th March 2007, 09:47   #5450
navin's Avatar
Thanked: 3,622 Times
front :4" JBL
HU: pioneer 5950
model numbers would be nice. yet you could get JBLs in the front and the rear why did you think of getting different brands in the front and rear?
Old 5th March 2007, 10:39   #5451
Thanked: 293 Times
It means power on & off
Old 5th March 2007, 11:57   #5452
navin's Avatar
My friend had a fully sealed box for his sub..........The very next day there was a carpenter at his house for some household work n he made him make two biggg holes in his box
Maybe you should intoduce your friend to the Shigting Gears thread where some of us are trying to make a 6" 2way. That thread has now covered box design.
Old 7th March 2007, 06:05   #5453
goldsun's Avatar
Question One of the speakers not working
I have a strange problem in my recently upgraded ICE setup I have Infinity on the front and JBL on the rear driven by JBL 60.4 amp in my SWIFT. I have recently noticed that the rear right speaker was not producing sound. But when I pumped up the volume, it started working even at normal volume. and again after some time it goes off. I have not yet taken this issue with the installer, which I will do during this week end.
In the meanwhile, I thought of checking with fellow members, who would have had a similar issue.
goldsun is offline   Reply With Quote
Old 7th March 2007, 08:54   #5454
navin's Avatar
it might be leaky cap in the amp.
Old 7th March 2007, 12:15   #5455
goldsun's Avatar
Post
navin,
pls explain me as to what is leaky cap ... probably is it some loose ends on the connector end of the RC cables?
Old 7th March 2007, 12:21   #5456
tsk1979's Avatar
Thanked: 15,359 Times
Originally Posted by goldsun View Post
navin,
A leaky capacitor is one which becomes a high value resistor.
Ideally a capacitor should pass through AC and should not pass through DC.
But a leaky capacitor would pass through DC too.
The extreme case is a short circuited capacitor which will pass through current the same way a wire would.
To test such a capacitor connect two ends to an ohm-meter. The ohm-meter should measure "open connection" in case of a good capacitor, but if its leaky you will see some resistance value.
For more info
A Simple Way To Test Capacitors.
Old 7th March 2007, 12:47   #5457
goldsun's Avatar
So... the Amp's internals need to be checked. Is there any other checks' that I should do to confirm that this could be possible problem. Another observation that I have is that At times, the speaker works even at low volume.
Old 7th March 2007, 12:59   #5458
Thanked: 293 Times
it might me the loose wire also...like the rca plug....check the wiring out before taking anything major.....
Old 7th March 2007, 13:08   #5459
navin's Avatar
So... the Amp's internals need to be checked. ... Another observation that I have is that At times, the speaker works even at low volume.
leaky caps are sporadic they works sometimes not at otehr times and sometimes a good electric jolt can get them to work like when you turn upthe volume. let a good repair man look at this. BTW like LBM said above it makes sense to check all RCA plugs too before opening the amp.
Old 8th March 2007, 06:45   #5460
goldsun's Avatar
Post
I had another observation. It starts working when I just give a push on the dash board component, which mounts the HU and goes off when the car comes across few bumps. So ... I am going to check for loose connections at the HU end. Will update you after checking this out.
sub enclosure advice from audio gurus clipto333 In-Car Entertainment 22 4th January 2007 11:29
Please Read This Thread *Before* Posting in the "What Car?" Section adya33 What Car? 0 12th July 2006 19:12
