Old 25th June 2007, 20:49   #6316
bottle's Avatar
Thanked: 131 Times
some help needed here , planning to install a blau gta4 mk2 amp and am looking for install suggestions .. whats the best way to conceal it ? the installers said front seat is too small for it and can only be done in boot ? since i make a lot of airport trips i d like to install it somewhere else other the than boot
bottle is offline   Reply With Quote
Old 25th June 2007, 20:59   #6317
Thanked: 293 Times
what is the size of the amp???
Old 25th June 2007, 21:04   #6318
navin's Avatar
Thanked: 3,730 Times
in which car?
Old 25th June 2007, 21:11   #6319
bottle's Avatar
Thanked: 131 Times
oops some more details
car is fiat palio
heres a link to amp - Blaupunkt - Amplifier - GTA-Series - GTA 4 Special Mk II
Dimensions 190 x 56,5 x 390 mm
rest of setup (basic stuff :P)
blaupunkt maui mp36 hu
rear - blau BGx 693
front - blau GTc 542
Old 25th June 2007, 22:16   #6320
navin's Avatar
car is fiat palio
Why not stick to the rear of the rear car seat. It is only 2" high.
"Dimensions 190 x 56,5 x 390 mm"
Old 25th June 2007, 22:31   #6321
bottle's Avatar
Thanked: 131 Times
well dad has a construction company and sometimes loads metal tools and planks so dont want it to get damaged or have the wires knocked out by the people who load it
but looks like i dont really have too many other options
Old 25th June 2007, 22:32   #6322
Thanked: 293 Times
Navin Ji he fears that if mounted on the rear seat the luggage might damage it...but bottle you can put a cover over it to protect it and the cover should be ventilated...
Old 26th June 2007, 00:03   #6323
Kudos the lord of JBL,
I am Suvrajit, a bong from bangalore, I have just bought a Swift and the novice that I am, think did pretty well to buy a Pioneer 6950, and GTO607 and a pair of GTO937 for rear, cant afford a AMP right now, nor a sub(if all permits in the future for sure) now how do I get the best out of this setup, the comp is fixed in the front doors and the tweeters on top of the a pillars facing each other and the 937 in the rear MDF plank?? your advice will be much appreciated by the newbie.
Suv
Suvrajit is offline   Reply With Quote
Old 26th June 2007, 09:28   #6324
navin's Avatar
Originally Posted by Suvrajit View Post
...and the tweeters on top of the a pillars facing each other and the 937 in the rear MDF plank??
well try using the fader. I would fade to the front and then very slowly fade to the rear till the rear is barely audible.
the bottom of the A pillar would have been nicer for the tweeter but now that you have cut the holeon the top let it be.
Old 26th June 2007, 10:22   #6325
Sam Kapasi's Avatar
Thanked: 1,416 Times
Hiya Suv,
Apart from what navin says, make sure you have less or minimum masala in your music. Stay as cloose as possible to 0, on the bass and treble. Don't go beyong +2. If you like loudness, keep it on mid.
You may initially find it dull (if it was all high) but in time you will understand and appreciate the true pleasure of good listening.
Most importantly, the equipment is just a means, remember the objective is to enjoy the music
Old 26th June 2007, 10:30   #6326
Thanked: 293 Times
like my mommy`s dal is better than your mommy`s dal -> Sam Bhai.
Old 26th June 2007, 15:24   #6327
Dhar's's Avatar
Thanked: 86 Times
Hiya Suv,
rightly said Samji.
A couple of days back, after reading some similar posts in this thread and else where, I changed the equiliser set up to flat/vocal and voila!! I have actually started listening to songs.
It seems that all these days (ever since my ICE set up done), all I was listening to was dum dum and chil chil only!!!
Dhar's is offline   Reply With Quote
Old 26th June 2007, 17:02   #6328
Thanked: 16 Times
Exclamation
the tweeters on top of the a pillars facing each other Thanks
Suv
Hmmm.... That doesn't look good to me. Why on top? As Navinji said, It should be kept on the base of the pillar facing the opposite seats.
Work on this and you will get a more better sounding setup.
Old 26th June 2007, 17:35   #6329
Thanked: 293 Times
like this location.
Old 26th June 2007, 18:50   #6330
bottle's Avatar
Thanked: 131 Times
hi guys got my gta4 amp installed but having an issue , when i rev the engine there is a whining sound from speakers which increases depending on how hard i rev .. initially it was quite bad but later the installer split the power wire along one side of car and rca cables on other side but after leaving i noticed the sound is still there slightly. any thoughts on the reason ?
guess its a fault with cables ? going again tomorrow to get it redone
sub enclosure advice from audio gurus clipto333 In-Car Entertainment 22 4th January 2007 11:29
Please Read This Thread *Before* Posting in the "What Car?" Section adya33 What Car? 0 12th July 2006 19:12
