Old 27th June 2007, 15:53   #6376
Thanked: 293 Times
Speaking of inductors, suppose instead of giving the wire straight to AMP(12V DC) I rotate it around a wooden stick 1" thick giving tight curls(20-30 curls).
This should remove high frequency noise(which I suppose most common car alternators have).
I will do this away from the amp and speakers so that the electromagnet formed does not foul up things.
Sirji not required as the devices are having them inbuilt.
Old 27th June 2007, 16:00   #6377
navin's Avatar
Thanked: 3,725 Times
Speaking of inductors, suppose instead of giving the wire straight to AMP(12V DC) I rotate it around a wooden stick 1" thick giving tight curls(20-30 curls)..
and what will prevent this wire from picking up induced noices?
Old 27th June 2007, 16:01   #6378
tsk1979's Avatar
Thanked: 15,526 Times
What about the choke then? Is the choke used similar to one which is used in tubelights?
Old 27th June 2007, 16:03   #6379
Thanked: 293 Times
no...it is a bit different aplication of the choke is used here..
Fluorescent lamp - Wikipedia, the free encyclopedia
Old 27th June 2007, 16:08   #6380
navin's Avatar
and it is usually sheilded in a metal can.
Old 27th June 2007, 16:43   #6381
bottle's Avatar
Thanked: 131 Times
sorry guys cant take a pic of the choke since its behind my dash and i have to remove the hu to take a pic .. its an old one and seems it came with old pio hus .. looked like 2 plastic blocks on a wire
bottle is offline   Reply With Quote
Old 27th June 2007, 17:32   #6382
DerAlte's Avatar
Thanked: 2,868 Times
Could be capacitors across from the Power line to ground.
Could be balun in line with the power line (not the one that is used to make chapatis :lol)
Old 27th June 2007, 17:53   #6383
DerAlte's Avatar
Originally Posted by low_bass_makker View Post
Hahahaha god one sir and the correct way to explain my setup. so when are you coming to delhi for having the laddu from inside and the outside both.
Sure, @LBM, will definitely do that one day soon. Will need to condition myself, though (like for climbing Mt.Everest):
1. Take training for escaping from cars with child lock on doors
2. Condition my ears for SPL
3. Reach 0.6 of the SQ appreciation levels of Navin, you, B&T, Sam, Gunbir, etc. etc. (I am at 0.4 and it is an uphill climb)
Old 27th June 2007, 18:03   #6384
Thanked: 293 Times
it is not uphill climb it is like a down hill , one flows with the music...
but in my car he will drown in it.
Old 27th June 2007, 18:10   #6385
DerAlte's Avatar
Oye, kya lajawaab baat kahi hai, subhanallah, qurbaan!
Old 27th June 2007, 18:16   #6386
Thanked: 293 Times
thank you sir.. so you wanna flow or drown in that.
Old 27th June 2007, 18:18   #6387
So, you will need an oxygen mask as well!
santosh.s is offline   Reply With Quote
Old 27th June 2007, 18:23   #6388
Thanked: 293 Times
Hmm not required as the air for the enclosure port is quite fresh and travels at MACH speed.
Old 28th June 2007, 12:16   #6389
Wimwian's Avatar
My ICE woes continue :-(
U guys may remember I was not happy with the bass response of my setup and was advised get the speakers checked for being out of phase... anyway, I was down with viral fever for a week and didn't get the time to do that yet... planning to get that done this weekend.
Meanwhile, the system conked out day before yesterday... suddenly the music was replaced by a very loud tut-tut-tut-tut noise (the closest i can describe it is that it sounds a bit like machine gun fire ) I immediately switched it off for fear of damaging the speakers... tried it again yesterday and it started off fine, only for the noise to return after about 5 mins of playing. Now there's no music at all... only noise!!
Any ideas what's causing this?
Tia
Wimwian is offline   Reply With Quote
Old 28th June 2007, 12:23   #6390
navin's Avatar
Check all connections esp the speaker connections. I would open it all up and plug it all together again. Does your system have an amp?
sub enclosure advice from audio gurus clipto333 In-Car Entertainment 22 4th January 2007 11:29
Please Read This Thread *Before* Posting in the "What Car?" Section adya33 What Car? 0 12th July 2006 19:12
