Old 9th August 2007, 12:41   #6826
navin's Avatar
Thanked: 3,409 Times
Originally Posted by nitrous View Post
Navin, there is no signal from the RCA connects either. :(
What do u think??
some part of your HU is damged now you need to take it to a service center.
Old 9th August 2007, 13:01   #6827
Bass&Trouble's Avatar
Thanked: 64 Times
Originally Posted by low_bass_makker View Post
I have silver ones but made in Aluminum..
Chee. These look used. I'll take the new ones from Gunbir only.
Old 9th August 2007, 13:02   #6828
Thanked: 64 Times
Sirji, yeh machine se sheet metal nahin katega, katega sirf uska blade.
This is what one should use.
Hitachi CN16SA 16 Gauge Sheet Metal Nibbler
Old 9th August 2007, 13:04   #6829
Thanked: 293 Times
Hmmm. I can get them polished for a new look and no one can make it out.
You know na Delhi wale are good in that...
Old 9th August 2007, 13:07   #6830
nura's Avatar
Thanked: 7 Times
Thanks but not sure if I can find someone here who has such a machine. Can a welding machine be used for this job & would the results be better than with a hammer & chisel?
nura is offline   Reply With Quote
Old 9th August 2007, 13:39   #6831
DerAlte's Avatar
Thanked: 2,864 Times
@Arun-babu, why do you need to cut metal?
One can, albeit very carefully, cut through with arc or gas welding. Depending on the location you need to figure out which parts to cover with wet gunny sack so that nearby combustibles don't ignite.
Old 9th August 2007, 14:12   #6832
nura's Avatar
Thanked: 7 Times
Thank you, Sir. My installer says he needs to cut the metal strip below the door-pad of my 5-year old Santro LS (with power windows) to fit the 6.5" woofer.
Old 9th August 2007, 14:56   #6833
akbaree's Avatar
Thanked: 43 Times
Default Set up for Chevy Spark
SAM/NAVIN/GUNBIR
I am buying Chevy Spark. The car will be delivered on Monday. I have started looking for the ICE setup that will go in the car.
I am planning on the following
HU - Alpine 9881
Front Components - Hertz Engergy/Infinity Reference
Rear Coaxials - Infinity Reference 6x9
4 Channel Amp - RF P450.4/Alpine MRP-F450
I have following questions
1. Which amplifier is better from the above two amplifiers? At-least what are the pros and cons of both of them.
2. The car is small and so I don't want to put a sub. Which 6x9 will give me best bass given that there is no sub
3. For front components, which would be a better choice Hertz or Infinity given that I mostly listen to bollywood music. Please pardon me as I don't understand the different genre of music like Rock, Pop, et al
4. What wiring should I go for with this set up?
5. How should I stage my rear speakers to get the best SQ?
akbaree is offline   Reply With Quote
Old 9th August 2007, 16:27   #6834
Sam Kapasi's Avatar
Thanked: 1,362 Times
Yes, he probably would need to do that.
Old 9th August 2007, 21:08   #6835
razor4077's Avatar
Thanked: 151 Times
I hope you are damping those doors well.
Hertz compos + undamped Santro door = Major vibrations!
Do take pics of the install process.
razor4077 is online now   Reply With Quote
Old 9th August 2007, 22:39   #6836
nura's Avatar
Thanked: 7 Times
I've got a few sheets of Fonomat but will probably require more.
Old 9th August 2007, 22:49   #6837
nura's Avatar
Thanked: 7 Times
This part of the door has a few parallel grooves. How can I make this surface smooth before fixing the MDF spacer ring? I presume it's not a good idea to have some hollow space under the spacer. Will Bombay putty (that's what it's called here) do?
Old 9th August 2007, 23:05   #6838
navin's Avatar
if the surface is hidden you can use "bondo".
Old 9th August 2007, 23:29   #6839
nura's Avatar
Thanked: 7 Times
I think most of it should get covered by the spacer. If some of it shows, I guess I can get it painted. Thank you, Sir.
Old 10th August 2007, 16:53   #6840
harmon_bro's Avatar
Guys,
Please share the contact details of SSPL in Bangalore. Need some information on JL Audio. Also do SSPL have a website?
Thanks.
harmon_bro is offline   Reply With Quote
sub enclosure advice from audio gurus clipto333 In-Car Entertainment 22 4th January 2007 11:29
Please Read This Thread *Before* Posting in the "What Car?" Section adya33 What Car? 0 12th July 2006 19:12
