Old 12th September 2007, 11:24   #7006
bottle's Avatar
Thanked: 130 Times
navin , any suggestions for front components that are nice and laid back ?
bottle is offline   Reply With Quote
Old 12th September 2007, 13:27   #7007
navin's Avatar
Thanked: 3,504 Times
In my expereince. Infinty Ref/Kappa, Illusion Carbon (I have not heard the lower range), Morel and Dynaudio. I am told that Rainbow and Hertz Hi-Energy are also laid back but not as much as Dynaudio or Morel.
Old 12th September 2007, 13:34   #7008
Sam Kapasi's Avatar
Thanked: 1,366 Times
I find both the Polk db series and JBL bright, but then again I find a lot of speakers (home and car) bright.
Oh Navin. The polk dB are much brighter than JBL GTO.
Old 15th September 2007, 22:24   #7009
determinus's Avatar
The Infinity Reference series -- is that really laid back when stock? I know my tweeter mounting IS bad but I found the reference 5010c to be very shrill. Even after 10 months of listening in. I always have my tone defeat ON. I asked stock because, in your case IIRC you have tweaked the XO. I listened to Moral's Illusion components and they were not really laid back, but much better than Infys. Is it just me? Sam?
determinus is offline   Reply With Quote
Old 16th September 2007, 02:29   #7010
Sam Kapasi's Avatar
Infinity by default is laid back, especially in comparison to JBL. What equipment are you using? Sometimes a HU will cause harshness.
Old 16th September 2007, 10:44   #7011
determinus's Avatar
My 5010c run directly off Alpine 9830. I specifically chose the 9830 from older batch to get the old time Alpine quality. (I have a 60.4, but it is still not hooked up)
But as mentioned, my tweeters are mounted about a foot above the dashboard which is not the ideal location, but the shrill is a bit too much for extended listening. Should I change the component set (they are still under warranty)? Thanks
Old 16th September 2007, 12:18   #7012
rocksterraghu's Avatar
Thanked: 11 Times
A foot above the dash? That is way too high and should be disturbing by default.
I may be wrong, but I generally decide the worthiness of components after connecting them to an amplifier. Why don't you try connecting it to the 60.4 amplifier to see if they sound ok?
Old 18th September 2007, 00:12   #7013
navin's Avatar
My wife's car (sail) has the 6010 in stock location and that location is not at ear level. We still found the tweeters a bit forward. so we just knocked it back a notch. The 5020 might be less forward than the 5010 but given your location the 5020 too might be too bright.
Old 19th September 2007, 12:12   #7014
Eddy's Avatar
Thanked: 4,242 Times
Default Do i need components ?
Hi Team,
I am planning on a basic ICE system in my Swift to be delivered on Sunday. I have almost finalized on these two things
Pio 4950 HU: I want a steering remote which is available with Pio only (?)/
Rear Speakers: JBL GTO 937, reason being a friend already has them. Used for around 6 months and then upgraded to better ones. So I am buying the same from him for 2 K
My question to the gurus here is : Do i need components for the front ?
- I generally will listen to FM, general music including only soft rock and the likes. I don't listen to hard rock, metal and stuff.
- I an not planning to upgrade the ICE in the near future so it totally rules out getting an Amp, a tube etc.
Does it still make sense to get components for the front ? Will their performance be limited to a large extent in absence of an amp ?
Gurus, please advice
Eddy is online now   Reply With Quote
Old 19th September 2007, 12:26   #7015
navin's Avatar
if you sit in the front getting good speakers upfront makes a lot of sense. it improves the soundstage.
if you find yourself pushing the volume past the half way mark get an amp.
Old 19th September 2007, 13:20   #7016
Eddy's Avatar
Yes, I will be driving most of the time so getting good speakers should be good.
Will rarely push it over the halfway mark so I guess I will not go for an Amp. Plus no vitamin M also .
Confusion remains, Without an amp, will there be a lot of difference in SQ between coaxials and components ? What will be the difference in the cost of two ?
Old 19th September 2007, 13:28   #7017
navin's Avatar
an amplifer improves most speakers, these are noticed in components more than coax becuase the components use better parts. your HU will drive most components fairly well.
Old 19th September 2007, 13:33   #7018
mobike008's Avatar
Thanked: 6,960 Times
There definetly would be a difference between coaxials and components. Comps have more juice and it becomes juicer when driven with an amp. Cost for coaxs in front is approx 2.5K and comps start from 5.5K
Old 19th September 2007, 13:48   #7019
Eddy's Avatar
Hmmm.. are JBL comps available without B&W ?
Old 19th September 2007, 13:57   #7020
mobike008's Avatar
I shoudn't be advising you a sans B&W JBL but yes, there was someone in this section who got those recently
sub enclosure advice from audio gurus clipto333 In-Car Entertainment 22 4th January 2007 11:29
Please Read This Thread *Before* Posting in the "What Car?" Section adya33 What Car? 0 12th July 2006 19:12
