Old 3rd October 2008, 20:14   #8761
nitinralli's Avatar
Thanked: 606 Times
Infractions: 0/1 (5)
Originally Posted by Sam Kapasi View Post
Nitin I have answered these queries in another thread, am I correct?
Yes you did. Thanks for the advice.
nitinralli is offline   Reply With Quote
Old 5th October 2008, 16:00   #8762
cooldude1988765's Avatar
Thanked: 106 Times
Originally Posted by cooldude1988765 View Post
What kind of a sub (& amp) would one need to listen to high bpm music clearly (electro). SQ or SPL ? There should be no missing a beat or blending of continuous fast bass into a single bass note.
Also which subs (brands) would be suitable for electro music in various budgets like 5k (will this even suffice ?) 10k, 15k, 20k etc.
Bump any help
cooldude1988765 is offline   Reply With Quote
Old 5th October 2008, 16:13   #8763
jkdas's Avatar
Thanked: 1,352 Times
Originally Posted by anticipation View Post
My first post
My new swift diesel is due delivery tomorrow. I needed some help on the Audio setup. i read the threads here regularly.. especially Sam Kapasi's
This is what i have shortlisted -
Sony MEX BT3600
JBL GTO 937 for rear (parcel tray)
Front (still searching which ones to go with)
All in all, this guy from milan subway is asking for 13.5k.
I read a thread on fake JBL's, how can i assure that i dont buy fakes? and also if there are any specific dealers, please suggest.
I am willing to spend around 14K for my audio setup.
Adi.
You sure missed lot of threads
Get good 6inch compos for the front.
Old 5th October 2008, 23:21   #8764
navin's Avatar
Thanked: 3,729 Times
Bump any help
many a sub will do this. you just need to tune the sub right.
get the sub in a correct box, powered by a good amp, and eqed to taste so really what I am saying is before you choose the sub, choose your installer.
navin is online now   Reply With Quote
Old 6th October 2008, 12:43   #8765
stevie's Avatar
Default Vibration in my rear left Alpine Coax speaker
Hi Guys
I have a pair of Alpine Coaxials installed in te rear of my Opel Corsa Sail. The speakers have not been hosed with screws since there is a "turn and lock" mechanism in my Opel speaker console.
The last few days, I have been hearing a bad vibration in the rear left. It begins only when i turn up the volume over 25 on a pioneer HU with aux and USB support. It is a long drawn process to remove the plastics. My last resort is to drive to Autoshop over the weeked and get the whole thing opened.
Any advice on this?
stevie is offline   Reply With Quote
Old 7th October 2008, 11:01   #8766
navin's Avatar
My wife has a Sail and I still have no idea what you are refering to. A picture would help.
Old 7th October 2008, 20:38   #8767
ankitahuja's Avatar
Thanked: 46 Times
I have a question: In a sedan, does it make considerable difference in sound if you cut out a small square/rectangle section in the parcel tray?
What I mean is, will it enhance sound if a 3 box car is turned into kind of a 2 box with this cut out?
Old 7th October 2008, 21:00   #8768
noidaboy's Avatar
Thanked: 260 Times
It should make a difference.
noidaboy is offline   Reply With Quote
Old 7th October 2008, 21:10   #8769
Thanked: 293 Times
Ya it will make a difference but it will not reach the levels of a hatchback.
Old 7th October 2008, 21:52   #8770
ankitahuja's Avatar
Thanked: 46 Times
It is advisable for me to get a small section cut on the parcel tray since I have a 12" Pio sub sitting in the boot.
Primarily, what effect will it have on the bass?
Old 8th October 2008, 00:47   #8771
abhinav.gupta88's Avatar
Thanked: 308 Times
See when you have a sedan , and the bass kicks in , the kick is produced in the boot.
and the boot and the seats are not in the same compartment.
They have to travel through the back of the car and due to the substance , much of the kick remains inside the boot and effectively you don't get that kick.
However if you are in a hatch , the seats and the boot is in the same compartment and the kick travels in the upward direction and spreads in the entire compartment. ( ensuring almost 100% transfer)
If you get a small section cut in the tray , what you will have is a semi hatch kinda thing ( not exactly semi but somewhere close )
The cut off section will act as a connector between the two compartments and will help transfer extra kick into the seating area
I'd assume
That if a sedan gives 1 pt kick ( Assumption ) ,
a hatch would give 2 pt
a notchback like octavia , laura : 1.3-1.5
and a small cut out section : 1.25
Old 8th October 2008, 09:27   #8772
Magma's Avatar
Originally Posted by abhinav.gupta88 View Post
I'd assume
now thats the most detailed "kick" values ive seen
ive always liked the idea of going "ported" in a 3 box car if you dont have enough power
Magma is offline   Reply With Quote
Old 8th October 2008, 10:43   #8773
navin's Avatar
Most of the difference will be in the midbass (50-80Hz range) you can make a 4-5" hole and cover it with a speaker grill.
Old 8th October 2008, 11:36   #8774
ankitahuja's Avatar
Thanked: 46 Times
Thanks Abhinav, it does make sense to me now.
Originally Posted by Magma View Post
Ive always liked the idea of going "ported" in a 3 box car if you don't have enough power
More light on the above please? What exactly does "not enough power" mean?
I have a Pioneer 306DVC running off a Audiobahn A8002T amplifier, feeding 400W RMS to each coil from either channel (so that's 800 RMS @ 4 ohms going to the sub).
I had a 1 Cu. ft. sealed box earlier, which I recently changed to ported enclosure (full slit on one side).
Bottom line is, I am very UNHAPPY with the bass reproduction since beginning. Pio 9650 has too many setting that I can't understand.
Navin sir, help me with settings on the HU and amp please??
Old 8th October 2008, 11:38   #8775
Thanked: 293 Times
Your sub is going to get fried very soon. Giving uncontrolled 800 rms to a 400 rms sub will make it blow.
sub enclosure advice from audio gurus clipto333 In-Car Entertainment 22 4th January 2007 11:29
Please Read This Thread *Before* Posting in the "What Car?" Section adya33 What Car? 0 12th July 2006 19:12
