Old 30th October 2008, 00:05   #8866
ariendj's Avatar
Thanked: 82 Times
Default FH 6050UB queries!!
i found the following features about FH-6050UB on the poineer India site which were a little confusing to me,so please do explain !!
-Direct AUX-in by mini-jack (rear)
so does that mean we have to use a cable all the way from the rear to attach to a mp3 player?
-USB direct connection: USB 2.0 (full speed)
is this feature present at the front panel or some place else too(rear)!!
-Bluetooth adapter ready
does this mean we need some extra stuff to use bluetooth feature?
-Direct Sub Drive
no clue to that either!!
- 2 RCA pre-outs: selectable (front + rear/front + subwoofer)
so does that mean amps cant be connected?
sorry for too many queries in one go but im too naive in this matter!!
ariendj is offline   Reply With Quote
Old 30th October 2008, 02:35   #8867
greenhorn's Avatar
Thanked: 1,457 Times
yes
yes again. some sort of extension cable will have to be used
yes again. you'll need to hook up a seperate bluetooth kit
-Direct Sub Drive
a rather useless feature by which the subwoofer signal is sent to the rear outputs so as to drive a small DVC sub. useless since you cant bridge the channels, and small DVC subs which can work with ~22W are hard to find
of course amps can be connected, what statement makes you think otherwise ?
Old 30th October 2008, 06:28   #8868
ariendj's Avatar
Thanked: 82 Times
just the thing that the brackets dint have such an option
Old 30th October 2008, 10:33   #8869
DerAlte's Avatar
Thanked: 2,877 Times
@ariendj, the brackets give 2 possible connection scenarios, but both scenarios need an amp. Pre-outs terminated at RCA sockets provide the signal for the external amp(s) to amplify.
Old 30th October 2008, 12:06   #8870
mohang_j's Avatar
Thanked: 18 Times
Originally Posted by mohang_j View Post
I want to run a 4ch amp for front and rear speakers and a 2ch amp (bridged) for the sub, i have Pio 3050 with 2 pre out. What is the best way to do it.
Koi to reply karo yaar (you and your ICE GO TO HELL bhi chalega)
mohang_j is offline   Reply With Quote
Old 30th October 2008, 12:21   #8871
greenhorn's Avatar
both of them are 60W/ch amps, so try mixing and matching , and choose whichever amp is better according to your ears.
I think the best option would be to use the 4 ch for your rears and sub, and reduce the volume of the rears, and apply an HPF to it, so that the channel driving the rears does not consume a lot of power , and that reserve power would be avaliable for the other 2 channels to dump into the sub.
configure one channel as sub(LPF'd ) , other for the speakers(HPF'd) . use a splitter, send one pair to the 2 channel, use it to drive the fronts
another pair to the 4 ch amp to drive the rears. remember you'll be losing fader control, so remember to set the gains on the amps appropriately
Old 30th October 2008, 12:22   #8872
Thanked: 16 Times
Default Let me try!
The easiest and the best way is to use a good 4channel amp and power your front speakers and sub using that. Power your rear speakers from the HU.
If you're adamant on going for a 2 amps setup, then 1 amp input can be taken from the speaker level outputs of the HU. Either use a line convertor or the amp should have a high level input in this case.
And of course, not to turn down your request:
you and your ICE GO TO HELL!
(copy - pasted from your post).
Last edited by speedzak : 30th October 2008 at 12:24. Reason: You and your ICE, I forgot.
Old 30th October 2008, 15:08   #8873
mohang_j's Avatar
Thanked: 18 Times
Thanks a lot for the reply
I have tried driving rear speakers from HU but the sound (loudness) is very very less (10-15%) at full volume.
I have tried using rear pre out to drive both rear speaker and sub but there is a considerable loss in BASS.
Old 30th October 2008, 15:24   #8874
greenhorn's Avatar
use one pre out for speakers, use an RCA splitter to get two of them, better IMO than using level convertors.
use the other pre out for the sub. usually one of the pre outs can be used as a sub out , with a dedicated LPF and settings for that
Old 30th October 2008, 15:25   #8875
Thanked: 16 Times
Default Rear fills! Just fills.
If you have a good front sound stage, it is better to have less volume for the rear fills.
Rear speakers are called rear fills. Yes, they just have to fill in the gap for the rear passengers. The primary sound stage should be from the front speakers. This is the optimal way of setting up speakers.
But if you have a weak front soundstage, then you may power the rears with high volumes. Then, you're moving far away from the optimal setup. So even in this case, it is better to get better front speakers.
Too much gyan and money going to be spent, right?
Old 30th October 2008, 16:12   #8876
mohang_j's Avatar
Thanked: 18 Times
Yes my front stage have illusion 4 inch compos and i need rear speakers mainly to fill mid bass.
Started with strict 10k, after 3 months now crossed 20k ++ for woofer +amp+fiberglassing+compos etc
It seems to be good idea i will try this first and then think of line level.May be i can use aux out of JBL amp insted of Y splitter
Old 30th October 2008, 23:37   #8877
govigov's Avatar
Thanked: 454 Times
hi team,
getting some ice tmrw, i went to muneem's shop galaxy and general motors. looking for a JBL 1204 in a asealed box and a good 4 channel amp. how is the JBL 60.4 and the other is a sony version of the same. galaxy said that blau gt4 is mainly used for speakers and not for sub's so kind of confused.
should i go for the JBL amp or the sony amp...
help required urgently as ICEing would start within 12 hours ie tmrw afternoon
govigov is offline   Reply With Quote
Old 30th October 2008, 23:49   #8878
Thanked: 16 Times
@Govigov.
Would suggest you to get Kenwood 8401 amp. The best bang for the buck!
Keep JBL as the next option. Then Blau and last, if nothing: Sony!
Galaxy is owned by Muneem? Never knew that!
Old 31st October 2008, 00:02   #8879
muneemmk's Avatar
Thanked: 17 Times
Oye.... I Don't Own Any ICE Shops....man does Steeroid own EndEffects and Hydra own Emperor. I am out of here.
muneemmk is offline   Reply With Quote
Old 31st October 2008, 00:52   #8880
govigov's Avatar
Thanked: 454 Times
he was always advertising that shop i thot that it was his!!! (honestly)
anything about the sub? JBL 1204 and kenwood 8401... alright.
how much should that cost me? the ikon is already amp wired. jbl in a closed box about 3500. how much for the 8401 kenwood?
sub enclosure advice from audio gurus clipto333 In-Car Entertainment 22 4th January 2007 11:29
