Old 21st April 2009, 18:29   #9361
abhibh's Avatar
Thanked: 33 Times
Originally Posted by ImmortalZ View Post
The original is by Neil Sedaka. There are umpteen remixes.
Yes the original one is Neil Sedaka but the most famous remixes are by Andrew Sixty only.
Andrew Sixty - Oh Caron Original Mix
Andrew Sixty - Oh Caron Ultimate Mix
Andrew Sixty - Oh Caron Underground Mix
Andrew Sixty - Oh Caron Batucada Mix
these are the ones i found on my OLD HDD.
Clip PMing you in a min and let me know if that is the song!
Old 4th May 2009, 22:14   #9362
amit_mechengg's Avatar
Thanked: 1,545 Times
i have a small query. i have been using the GZ MK2 sub, in the ported box since 8 months.its driven via JBL 75.4. i have observed one thing. the diaphragm of the sub doesnt move much or i can say moves just a bit in normal as well as reverse phase.
today i tried stuffing thermocol in the port, blocking it completely. immediately i observed that the diaphragm is banging to a huge extent with amazing bass.
shall i close the port ?
what way shall i close the port. by mere stuffing some stuff inside it or by putting a wooden permenent lid over it?
Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q!-gz.jpg
Old 4th May 2009, 22:23   #9363
ramie2400's Avatar
Thanked: 58 Times
If you seal it or use a smaller sealed Box you will start enjoying the more
Old 4th May 2009, 23:16   #9364
OT ramie the wheelie on the scooter is amazing
well do i just put a wooden plate over the mouth of the port or stuff something inside the entire port length and then close the mouth?
Old 4th May 2009, 23:21   #9365
ramie2400's Avatar
Thanked: 58 Times
Lolz thats not me hehehehe
The best way to test it is,choose a fav. song/track and play it at a set volume,now seal it and listen to that same song/track you choose you will notice alot difference in the low's.Then the decesion is yours which one you liked.
You can put a wooden plan and seal it up,dont stuff anything inside.
Old 5th May 2009, 21:35   #9366
i played the " Madonna, Frozen" song with 320 kbps bitrate. the sound quality of song is very good and the bass is amazing.
first played it with the open port. the woofer was moving to a certain extent, say X.
then i stuffed a towel in the port. with the same song at same volume the woofer started moving at X+20-30% more.
the bass is good in quality with a better control and it leaves ripples in the whole car.
now do i continue with the towel or else a different method would prove better?
Old 5th May 2009, 23:21   #9367
ramie2400's Avatar
Thanked: 58 Times
I would suggest seal the port using a wooden plank wrapped up with the same cloth material and get rid of the towel
Old 7th May 2009, 11:01   #9368
sathee46's Avatar
I'm planning for a enclosure for my car which is going to be fixed at a certain place. I'm in a confusion. What is the best way to put the subwoofer in the boot. Facing towards the rear seat or facing towards the rear of the car?
When i had a woofer earlier I used to keep the enclosure facing to the rear, and i liked it.
sathee46 is offline   Reply With Quote
Old 7th May 2009, 13:11   #9369
karankapoor's Avatar
this will go in your fiesta right, will not make a huge difference but you can always try different position.
karankapoor is offline   Reply With Quote
Old 7th May 2009, 13:28   #9370
Sam Kapasi's Avatar
Thanked: 1,454 Times
Originally Posted by sathee46 View Post
I'm in a confusion. What is the best way Facing towards the rear seat or facing towards the rear of the car?
earlier I used to keep facing to the rear, and i liked it.
I think the best thing to do is to try all positions and see which one gives you the most satisfaction. The important thing is that you do it in the car and place it in the rear.
Let us know how it goes.
Old 7th May 2009, 13:51   #9371
muneemmk's Avatar
Thanked: 17 Times
Aren't the gurus supposed to give tips on audio installations ?
muneemmk is offline   Reply With Quote
Old 7th May 2009, 14:28   #9372
sathee46's Avatar
I found the answer Aiming a woofer box in a car trunk - bass cancelation -
Rotfl!!!!!, I'm not going to ask anymore questions on the positions
Old 9th May 2009, 02:48   #9373
redfire's Avatar
Thanked: 12 Times
hehe. Anyway I tried placing the Sub in boot (Swift) facing different directions and I liked facing rear (to hatch door) the best. Since the enclosure is a perfect square box i couldn't try angled positions, but facing rear at an angle (facing the rear glass) is also common and works fine.
redfire is offline   Reply With Quote
Old 9th May 2009, 07:49   #9374
navin's Avatar
Thanked: 3,924 Times
No keep the towel. I use old tennis socks (washed). I think there was a thread on it - at least it was discussed in detail on this fourm somewhere in 2004-5 (anyone remember CCTB - I have not forgotten).
Sam's knowledge about woofers is dwarfed by his knowledge about "extra-curricular" activities.
Old 9th May 2009, 09:35   #9375
Sam Kapasi's Avatar
Yes, it is deep in the annals of this thread and was great fun.
sub enclosure advice from audio gurus clipto333 In-Car Entertainment 22 4th January 2007 11:29
