Old 17th December 2009, 16:19   #9796
s3va's Avatar
gurus..in my car, the rear spkrs are connected directly to the HU while the front spkrs and sub are connected through the amp. If i adjust the LPF in my HU will it do any good by reducing/increasing the low signals to the front comp ? I think its a pretty obvious answer NO, if its NO why ?
s3va is offline   Reply With Quote
Old 17th December 2009, 16:39   #9797
Dhams's Avatar
Originally Posted by funnyguru View Post
Hey Mi10, back to my rescue,
But I do not want them on parcel tray. But need some bass. Budget now not helping to go for the Sub. But soon will have the amp and sub, so suggest likewise please!
Polk dual coil subw will best suit to your front polk compo. JBL also serve the purpose if u like to check option.
cutting metal to fit a 6" in the space for a 4" can get tricky.
1. there needs to enough room for the window to go up and down easily.
2. when something like this is done it make sense to add some damping to the door. you will be surprised at the efficacy of the damping in improving the quality of the bass/midbass.
3. a spacer is generally used and this needs to be installed well. a poor install will lead to rattles and buzzes.
Thanks. Actually not fed up with speaker but shrilling effect too much from this front 4"coaxial. Should changing 6.5"compo will sing smooth & sweet vocal? or any suggestion on this 4 incher. Pl advice.
Note that rear 6x9 GTx693 do awesome job on parcel tray, not feeling absent of sub woofer. Drive horse is Clarion576usb like "Kohinoor"
Edit:- Got advice to insert baffles or kick panels (pics attached) should kill sharpness of sound. is it so? I fainted!
Dhams is offline   Reply With Quote
Old 17th December 2009, 16:52   #9798
navin's Avatar
Thanked: 4,266 Times
Pionner 6050UB - 2DIN
6' Polk comps fromt door.
6' JBL co-ax at rear door.
Budget 20k.
Sounds good?
If you are going add a subwoofer and amp soon then 4 6" midbass will suffice. In general (there can be exceptions) a 6" in a door will not have the bass response of a 6x9 in a rear deck and a 6x9 in a rear deck will not have the bass capabilities of a 12" subwoofer in a corretly designed box.
Originally Posted by s3va View Post
if i adjust the LPF in my HU will it do any good by reducing/increasing the low signals to the front comp ? I think its a pretty obvious answer NO, if its NO why ?
LPF output is used for subwoofers. HPF output if used for front/rear speakers. Your query leaves me a bit confused. What do you intend to do?
Old 17th December 2009, 16:59   #9799
navin's Avatar
Attachment 247149
Attachment 247150
The picture of the wooden ring and not a kick panel. The kick panel in the car is the part of the car near the left foot (passneger side) or right foot (driver side).
The wooden ring serves 2 purposes. a. if increases the effective volume of the 'box' behind the woofer (to some extent it also stiffens the 'baffle' of the woofer) thereby allowing the woofer to perfrom better and b. ensures that the woofer's magnet will not interfere with the window wiinder/glass.
Old 17th December 2009, 17:04   #9800
Dhams's Avatar
Have u seen 2nd photo? its kick panel.
Great technical updates. Thanks. So I assume inserting baffles will sure shoot the problem i.e. reduce sharpness & improve sweetness in front stage.
Old 17th December 2009, 17:08   #9801
navin's Avatar
Yes the second photo is a kick panel. These are made for specific cars (usually big american cars or trucks like the F150) which do not have door locations for the front speakers.
The bafffle will not directly affect the sharpness (treble) of a speaker but it can change the overall tonal balance. However a shrill speaker will not magically transfrom itself and become listenable so smart speaker choice is still essential.
Old 17th December 2009, 17:14   #9802
Dhams's Avatar
noted. I think there are options like...
1. 4" coaxial, any other brand who dominated for warm sound OR
2. 6" coaxial in door, brand? OR
3. 6.5" compo in door with adding 2Ch ampl. OR
4. any other option?!
Old 17th December 2009, 17:36   #9803
s3va's Avatar
I want to prevent Low signals from going into the front and rear sprks, I want all it to go the sub, so that the spkrs dont start to distort at very high volumes. I dont know if I still didnt make sense here. FYI My HU has only LPF
Old 18th December 2009, 01:18   #9804
navan49's Avatar
Thanked: 69 Times
Hi Friends,
When I was looking for my speakers. I came across 2 way speakers ,3 way speakers and the 4 way speakers and also four way speakers.. What does the way means here for the speakers? Any one has some idea.
navan49 is offline   Reply With Quote
Old 18th December 2009, 10:07   #9805
navin's Avatar
Obviously the 6" component will offer you the best overall response. As far as brand and model are concerned nothing, and I repeat nothing, can replace listening to the various brands yourself.
Sadly that is the truth. Good brands to consider are Infinity, Alpine, Blaupunkt, JBL, etc.
A LPF is a LOW PASS FILTER meaning that it will let low signals through and STOP high frequency signals. If you want to prevent low signals you need a HIGH pass filter.
Old 18th December 2009, 10:12   #9806
navin's Avatar
4 way = four way.
1 way is a full range with no crossover
2 way = woofer + tweeter
3 way = woofer + midrange + tweeter but in car audio it is often a woofer + tweeter + super tweeter
4 way = woofer + midrange + tweeter + super tweeter etc... or even subwoofer + woofer + midrnage + tweeter.
In short 2 ways means the frequency spectrum is divided into 2 parts (not nesscarily equal), 3 ways = 3 parts, etc....
There are also 2.5 ways, 3.5 ways etc.. but that is a whole other story.
BTW subwoofer is frequencies under 100Hz, woofer is frequencies under 2khz, Midrange is frequencies from 200-5khz, tweeter is frequencies above 2kHz, and super tweeter is freq above 6kHz
Old 20th December 2009, 15:07   #9807
ariendj's Avatar
Thanked: 83 Times
i have a 5.25" pioneer speakers in front and was thinking of replacing them with 6" kenwood co axials.
have JBL 938 6x9 at rear and all this is run by pio 6050.
i wanted more clarity at front so is my speaker changing to co axials in front sufficient!!
ariendj is offline   Reply With Quote
Old 20th December 2009, 16:48   #9808
navan49's Avatar
Thanked: 69 Times
Hi Bhpian,
Good idea of Ken wood speakers in front. I have 130 W in front and back. But now I see 6" in the ken wood outlets with 150W. The model I have, is not available in the market. It is available with Maruti dealers.It is KFC 1656-NM4. For me the sound quality is wonderful with Kenwood 543 HU with USB.
Old 20th December 2009, 19:41   #9809
Hi...i need advice...I got a Swift Vdi...and i just need a head unit with Usb and 4 spk output.. i have no intentions for going in for something fancy.. my budget is 7000 max..what do u Gurus recommend??? i have pioneer speakers i brought from Dubai!
Note from the Team-BHP Support Team : Please take the time to use proper punctuation as per Team-BHP rules. Avoid...typing...like...this. Thanks.
saksh4 is offline   Reply With Quote
Old 20th December 2009, 19:57   #9810
navan49's Avatar
Thanked: 69 Times
If you have the speakers then you can go for Head unit only. If you can extend your budget to 8000 then you can blindly go for Ken wood 543 wit USB and 18 FM set up and very good out put. Mine the speakers are also Ken wood 6" all in front back doors. Very good performance. Ken wood genuine you can get from Maruti dealers as MGA accessory with Maruti mark on HU.
sub enclosure advice from audio gurus clipto333 In-Car Entertainment 22 4th January 2007 11:29
