Old 28th October 2016, 14:12   #13291
Thanked: 92 Times
Originally Posted by deepfusion View Post
Checked. One tweeter is toast.
Now I shall have to look for tweeters that can handle the power given by gladen one-120.4.
Pls guide me on buying capable tweeters.
Please try doing a passive install with the company-provided crossovers after buying new tweeters. Going active is dangerous with inexperienced installers
HighwayofLife is offline   (1) Thanks Reply With Quote
Old 28th October 2016, 16:25   #13292
navin's Avatar
Thanked: 4,265 Times
Default Re: Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q!
Tweeters and woofers are sold as a set. Unless you know what you are doing with respect to crossovers, sensitivity and impedance correction etc do not mix and match.
navin is online now   (1) Thanks Reply With Quote
Old 28th October 2016, 16:54   #13293
deathwalkr's Avatar
Thanked: 558 Times
So i bought a kenwood unit which says it supports android music playback over usb. Connected my moto x force and it says no device connected.
Could you guys help me out with devices which support AOA?
Kenwood's site has a list of phones dated till June 2015 only.
deathwalkr is offline   Reply With Quote
Old 28th October 2016, 17:41   #13294
greenhorn's Avatar
Thanked: 1,508 Times
Are you sure the tweeter is blown, and not the crossover ( ie multimeter at tweeter terminals reads open circuit?)
What comps are you running
Navin, Just curious here -
Making some assumptions as I'm not sure what his current comps are -
if his current XO is a simple 2nd/3rd order filter, and the impedance matches, if he buys a tweeter which can go lower than his current comp's crossover point, won't the processor take care of the level mismatch between the woofer and the tweeter?
I'm assuming he's using some sort of calibration mic to help with tuning the response in the car( if he's not, here you go)
greenhorn is offline   (1) Thanks Reply With Quote
Old 29th October 2016, 10:40   #13295
navin's Avatar
Greenhorn, You got 3 big IFs there. IF the XO is simple (aka Butterworth) 2nd order and IF the impedance (which varies with frequency) matches and IF he can get a tweeter with a lower Fs (measured not published). Then the processor may compensate if he takes enough samples (for example a complete sweep in 6 locations).
It might be easier to (a) check if the voice coil is blown or if it just a terminal disconnection (b) if the tweeter is indeed damaged replace the set.
Typically what I find is that the tweeter's voice coil has detached from the terminal but the point of detachment is not accessible. This is not so much due to excessive power but more often due to some low frequency that escaped the XO (say around 1000Hz) and forced the coil to travel beyond it's physical limits.
Old 31st October 2016, 17:55   #13296
Thanked: 126 Times
I have gotten myself into the wrong field. I am completely noob at audio instals and intricacies involved. Was just experimenting based on suggestions and reads on TBHP. Never knew these things would also be needed.
The tweeter stopped giveing any sound and so it was concluded that it had blown up.
I shall buy a calibration mic also now.
I am not aware of any body repairing tweeters and speakers in Delhi NCR. I have Image Dynamics Mids also lying around which I need to get repaired.
I have been suggested Dayton audio DC28F.
deepfusion is offline   Reply With Quote
Old 31st October 2016, 18:30   #13297
greenhorn's Avatar
Not if you dont know how to use it
download audiotool on your smartphone and figure out if you can use it to tune your bit ten. Else using the mic/tuning it may be beyond your capabilities
You still havent mentioned which comps you have
Old 31st October 2016, 18:41   #13298
Thanked: 126 Times
I will download the audiotool right away. BTW, I already did instal Room Equalisation wizard on my laptop. I plan using my HT's mic with the laptop to tune the bit ten.
Sorry. I am using Illusion Audio ND 6.
Old 31st October 2016, 19:45   #13299
wrongturn's Avatar
Thanked: 517 Times
Hi Navin,
I was wondering about which is the best source through which we can get better quality sound output considering each has same format file on it. Will there be considerable difference in sound output quality when I play the same file through:
1. CD
2. AUX
3. Pen Drive/ memory card.
4. USB (specially iphones)
I won't add Bluetooth to the list as I know it doesn't belong there.
I also find playing audio through iphone connected via USB to be the best, but I just might be imagining that as it's an iPhone. But there is certainly an advantage there as we can use phone's equalizer to get desired sound output, even via AUX.
I did a google search but couldn't get any answers.
wrongturn is offline   Reply With Quote
Old 1st November 2016, 12:33   #13300
heydj's Avatar
Thanked: 291 Times
Originally Posted by wrongturn View Post
1. CD
2. AUX
There is no one answer as SQ depends on encoding and bitrate of songs along with source.
E.g. if via USB you play a FLAC coded song and have the necessary audio system to make the best out of that file then it should theoretically sound great.
If playing via Aux then wire matters that is being used, i.e. is it cheap stuff found on roadside or something of high quality.
Within Aux/USB/Pendrive I would suggest keeping sound coding at minimum 192 Kbps and aim for 320Kbps i.e. when ripping a song from CD or downloading stuff, but up-scaling a song coded at 128kbs to 320 kbps will have no desired result.
It also depends on DAC in source instrument, generally mp3 players and phones have some sort of DAC but quality of the same leaves lot to be desired. In recent times and since iPod classic 5th generation back in 2007, DAC in Apple phones and iPods leaves lot to be desired. Generally among all phones these days HTC One series is giving cleanest and loudest output (Source reviews on Gsmarena, PhoneArena, AnandTech, my own personal use, etc.)
I personally switch off EQ on iPod when connected to car stereo as I can feel lot of distortion and my tweeters sounding hyper active. Generally keep sound leveling option On.
heydj is offline   (1) Thanks Reply With Quote
Old 2nd November 2016, 11:00   #13301
navin's Avatar
The DC28AF is too big a tweeter to fit in a car without some serious modifications. You would ideally need something along the lines of the Vifa D26NC (which is long discontinued). See pic.
http://www.audiomania.ru/avto_tweete...6nc-05-06.html
These too are long discontinued.
Lets assume each of the 4 sources has the same music, same bit rate, same encoding, etc. I would assume a Pen Drive or SD card would offer the best output as it would be mechanically the most stable.
navin is online now   (2) Thanks Reply With Quote
Old 2nd November 2016, 11:49   #13302
Sankar's Avatar
Thanked: 4,561 Times
Default Pioneer Park Brake Wire Question
I'm installing a Pioneer AVH 8890BT HU now and need help with the park brake wire. Where do i connect it to? The manual asking me to connect ro the +side of the handbrake switch. Are there any alternatives to connecting it to the switch?
Old 2nd November 2016, 12:03   #13303
greenhorn's Avatar
Not able to find any product information on this
http://www.team-bhp.com/forum/car-en...egrity-44.html (vRs(q) Monster : Eclipse | Illusion Audio | Harman Kardon | Stereo Integrity)
this is the closest i could get
the good news is that the crossover point is 4Khz, so you have more options
the not so good news is that I'm not sure how those resistors are set up, and without seeing the underside of the PCB, or a circuit diagram, not sure how things would work.
My guess is that most probably they're used as switchable attenuation for the tweeter, but would prefer to be sure.
also, with so many jumpers, make sure that your tweeter is not dead because of a loose connection there.
Old 2nd November 2016, 13:02   #13304
Thanked: 126 Times
Every inch of wiring has been checked and reconnected wherever felt.
I have not been able to find any replacement for the tweets. Even Ramie doesn't have them, and has not been able to source them.
The only other option left is to try and get the tweeters that I have repaired. I have learnt about a person in Noida who repairs these, so would give it a try. In the meanwhile, I have ordered the Daytons, pod fabrication would have to be done for them.
Old 2nd November 2016, 16:38   #13305
greenhorn's Avatar
since the tweeters seem to be used with an L pad, you may not need to buy something with so much power handling. if we could figure out the L pad values being used, we might be able to use something with much less power handling
PS, why the dayton?
sub enclosure advice from audio gurus clipto333 In-Car Entertainment 22 4th January 2007 11:29
