Old 11th April 2017, 11:46   #13471
heydj's Avatar
Thanked: 286 Times
Default Re: Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q!
I have a issue with sound setup in Rapid.
At times there is no sound and on restarting the car sound comes through speakers.
Generally when there is no sound I check to see if AMP is working and it has Green light or working.
Car Rapid.
HU OEM
Rainbow Components
Digital Dynamics AMP.
Installation properly done in Delhi at Driven.
Issue is when I take car to get tested then sound is coming and audio install guys are not able to figure the issue.
What to do as this problem of sound not coming has no pattern.
heydj is offline   Reply With Quote
Old 11th April 2017, 14:26   #13472
nitinralli's Avatar
Thanked: 660 Times
Car Rapid.
HU OEM
Rainbow Components
How often have you been to Driven? Was that your first time?
nitinralli is offline   Reply With Quote
Old 11th April 2017, 16:13   #13473
heydj's Avatar
Thanked: 286 Times
Does my number of visits impact the issue at hand?
Anyways used their services multiple times, back in 2009 got the install in Swift. Working flawlessly till date.
Its this peculiar issue with install in Rapid that needs to be sorted.
Old 11th April 2017, 16:16   #13474
navin's Avatar
Thanked: 3,987 Times
Originally Posted by pixantz View Post
Any idea how Sam passed away?
Please read the link in my earlier post above.
At times there is no sound and on restarting the car sound comes through speakers. Car Rapid.
HU OEM
Rainbow Components
Connect the speakers directly to the HU (bypass the amp) and see if the problem reoccurs. If so you know where to look.
navin is online now   Reply With Quote
Old 18th April 2017, 11:14   #13475
Enigmatic's Avatar
Thanked: 544 Times
Default Amplifier cuts out momentarily. Need help.
I am facing a peculiar issue of the late with my Blaupunkt GTA 470DSP amplifier.
My current set-up is as follows:
1. Head Unit - Pioneer 5890 BT;
2. Front and Rear - Focal ISS 165 components;
3. Front and Rear components are being powered by the Blaupunkt GTA 470DSP;
4. JBL CSX-1400BP - 12 inch subwoofer in the boot; and
5. JBL GX-A646SI - powering the subwoofer.
The issue
Sometimes on high volume, the components cut out for a second and then come back on. However, at mid and low volumes, the music plays well indefinitely with no issues. The subwoofer however continues to play in that interim 1 second when the components cut out.
What could be the reason for the Blaupunkt amplifier to suddenly cut out the power to the components when the JBL amplifier continues to power the subwoofer?
P.S. This issue seems to be erratic and does not occur regularly.
Best,
Enigmatic
Enigmatic is offline   Reply With Quote
Old 18th April 2017, 11:44   #13476
navin's Avatar
Default Re: Amplifier cuts out momentarily. Need help.
The issue
2 things.
a. The Amp is overheating and protecting itself.
b. The battery voltage falls below the "suggested operating voltage" of the amp and the amp goes off till the battery recharges enough.
Disconnect the subwoofer amp and see if this happens. if it does then it is (a) if not it is (b).
navin is online now   (1) Thanks Reply With Quote
Old 18th April 2017, 12:05   #13477
Enigmatic's Avatar
Thanked: 544 Times
2 things.
Thanks, Navin.
I will try disconnecting the subwoofer amp and report back.
Best,
Enigmatic
Old 20th April 2017, 14:38   #13478
Thanked: 121 Times
Pls suggest.
I have set up the equalisers as per the attached sheet.
What should I do to reduce the shrillness of some high frequencies for which I am unable to comprehend the bands for.
New Microsoft Office Word Document.docx
deepfusion is offline   Reply With Quote
Old 20th April 2017, 14:58   #13479
greenhorn's Avatar
Thanked: 1,492 Times
install frequency analyzer on phone
run sweep tone
look at response on screen for peaks
greenhorn is offline   (1) Thanks Reply With Quote
Old 20th April 2017, 21:11   #13480
Thanked: 111 Times
Guys, I am planning to install Android Head Unit on my July 2014 manufactured Skoda Rapid (1.6 TDI Elegance with steering control) soon, along with Reverse Camera; Have already ordered the HU from Aliexpress and received the below unit.
https://www.aliexpress.com/item/8-co...800366066.html
Now I am in a dilemma whether to install it as a DIY or to find an installer for the same. Prior to the actual install, I want to test the HU in my car which is fitted with RCN320 (Visteon). But I do not know whether it will ask for 'Radio Code' while reconnecting. I do not remember SA saying anything about this 'Code' during delivery of the vehicle nor do I find anything in the user manual of the HU. Also I do not remember seeing any code stuck over this HU, when I opened the same (not disconnected the cables, then) to check for the connector details.
Can someone provide some info on this HU (RCN320), whether it will ask for code or not, during reconnection, so that I can proceed with the same confidently?
Thanks.
batman is online now   Reply With Quote
Old 24th April 2017, 12:37   #13481
Enigmatic's Avatar
Thanked: 544 Times
2 things.
It is (b).
Switched off the subwoofer amplifier and the components continued playing seamlessly. Also noticed that with the subwoofer running, the components have a higher tendency of cutting out (for a second) when the car is stationary. This leads me to believe that the amplifier is falling below the "suggested operating voltage".
What should I do to rectify this?
Best,
Enigmatic
Enigmatic is offline   (1) Thanks Reply With Quote
Old 24th April 2017, 15:05   #13482
navin's Avatar
Enigmatic
The bad news: you would have to find an amplifier that is not so "sensitive" to battery voltage. GTO had a similar issue until we shifted to Steg amps which can continue to operate at low as 10VDC. See GTO's thread below.
http://www.team-bhp.com/forum/car-en...ml#post2143461 (Car audio losing sound at low rpms! EDIT : Solved by "The Steg")
The good news: Most amps that are tolerant of battery voltage have very well regulated power supplies and hence are much higher quality than less tolerant amplifiers.
Old 24th April 2017, 19:31   #13483
Enigmatic's Avatar
Thanked: 544 Times
Many thanks, Navin.
Read through the issue GTO was facing and it seems to be an inherent problem with the Civic. Good to know that Steg came to GTO's rescue however, I am not sure if I will be able to procure a Steg amplifier. Also more importantly, my current components are not worthy of Steg.
Maybe getting a 4 channel Class D amp should suffice (Infinity Kappa Four ?).
Best,
Enigmatic
Old 25th April 2017, 11:06   #13484
navin's Avatar
Since it is the TOTAL draw from the battery one option would be to get a Class D monoblock and see if that helps. You can then use either the Blau 470 or JBL 646 to drive the front and rear.
Old 30th April 2017, 21:39   #13485
Thanked: 111 Times
Quoting from my own post:
Yesterday, I tested disconnecting the OEM Head Unit and reconnected the same; The HU did not ask for any code after reconnection.
sub enclosure advice from audio gurus clipto333 In-Car Entertainment 22 4th January 2007 11:29
