Old 11th September 2005, 00:53   #1441
navin's Avatar
Thanked: 4,265 Times
nah! see my previous posts. rms ratings are a rough guide. 100W rms will drive most subs.
Old 11th September 2005, 00:56   #1442
jkdas's Avatar
Thanked: 1,436 Times
gr8. i was so confused abt subs and amp rms. anyway, i am going for CS1200 with 502Z
hope no one changes my mind again
Old 11th September 2005, 01:12   #1443
moodswings's Avatar
Exclamation
Navin in the current setup what do you recommend...or are u saying tht i should put another amp for sure.....please recommend...I want to fix this issue asap...as there is no Bassssss
moodswings is offline   Reply With Quote
Old 11th September 2005, 01:15   #1444
navin's Avatar
what recomendations do you need. just get a sony 502 and let either the Kenwoods or the subs (bridge amp) use that.
Old 11th September 2005, 01:16   #1445
Scuderia's Avatar
Default got my system... finally
Hey Junta
Got the system for my OHC...
HU - Blaupunkt Bermuda MP35
Rear - JBL GTO 936e
Front - JBL GTO 506 compos
Played Eagles and Floyd just now on a drive to Worli Seaface.... it is bliss !!!!
The Blau is a great HU to the amazing performance of the JBLs.
Just one issue... which may lead to my changing the HU too...
it does not tune in to Even Frequencies on FM... dunno whether it is designed that way or am i missing something.
But otherwise I am really satisfied with the combo... thanx to gurus here.
Total cost with B&W including discounts and bargains - 17.7k
Thanks people once again.
shine on .. crazy diamond
Scuderia is offline   Reply With Quote
Old 11th September 2005, 01:17   #1446
moodswings's Avatar
Lightbulb
i have got ur point ....6 channels in total and one for each speaker/component/woof.....also, shall i just buy the 504 rather than a 502 so then ZI will have 2 channels free if i wanna expand or add that autobahn 12"super woofer in future...whatsay Navin
Old 11th September 2005, 01:21   #1447
moodswings's Avatar
Scurdia I am facing the same issue with my Alpine 9833...these high end Mp3 players are low on Fm man.....whatsay
Old 11th September 2005, 01:23   #1448
Scuderia's Avatar
Is it an issue with all brands
If m not mistaken... these are designed on the US stds wherein the FM freqs are only odd numbered.
Anybody with Sony/JVC etc or other Blau/Alpine models facing this issue?
Old 11th September 2005, 01:24   #1449
moodswings's Avatar
I think I have got your point...will test put the 502 for the woof and see the difference
Old 11th September 2005, 01:26   #1450
moodswings's Avatar
Kenwoods and Clarions i have seen operationg FM and they are damn good
Old 11th September 2005, 01:30   #1451
moodswings's Avatar
Unhappy
Originally Posted by jkdas
navin wont he need 2 check his sub rms rating b4 going in for 502z
Jk The following are the specs of my woofer:
General TS-W306C
Short description C-Type Subwoofer
Key features TS-W306C
Composite IMPP cone using interlaced Aramid fibre with reinforcement arcs
Wide-roll, 3-layer fibre woven radial surround
Dual mass high power magnet
Extended and vented pole yoke
Enclosure use
Optional accessories:
- UD-G306 spoke grille
- UD-W301S custom enclosure box
Ohm Rating: 4Ω
Features TS-W306C
Frequency response 18 - 500 Hz
Sensitivity (1W/1m) 89 dB
Qts 0.42
Recommended sealed enclosure (Litres) 24 - 49.6
Lowest resonance frequency (FS) 32.6
Maximum Power 1.000 Watt
Nominal input power 400 Watt
Vas 55.6 l
Woofer size (cm) 30 cm
Navin please see /recommend if the 502 will be cool for this one
Old 11th September 2005, 01:33   #1452
moodswings's Avatar
Exclamation breather
Guys this might be a stupid question...but hw much breathing space does a normal 6.5"comp. woof need if i fit it on the front door panel of my scorpio.....by the way which i have already done.....do i need to dig a hole for a breather for the woofer.
Old 11th September 2005, 01:42   #1453
revtech's Avatar
Thanked: 35 Times
nope no problem at all with jvc in this matter !!
rev
revtech is offline   Reply With Quote
Old 11th September 2005, 01:45   #1454
moodswings's Avatar
[b]Aseem I am sure you will go thru'what all i have written
Old 11th September 2005, 02:39   #1455
mclaren1885's Avatar
Thanked: 34 Times
Infractions: 0/1 (10)
no problem with sony HU either with the FM thingy..i suggest u 1st try connecting the sub to the 502z..should work fine however if u can afford a 504z then there is nothing to beat it..so just try the 502 first..if ur satisfied keep or else plonk in the 504..
sub enclosure advice from audio gurus clipto333 In-Car Entertainment 22 4th January 2007 11:29
